Galant VR-4 Forums » Galant VR-4 » Technical Discussions » A/T Swap Parts List
A/T Swap Parts List
Mark
Trying To Sell Out
Galant VR-4 org Post #: 444939 posted 02/16/07 04:49 PM     Remind Me!  Send Private Message   Edit Post
So recently I converted my Galant Vr4 to Automatic and I couldnt seem to find any good info on the internet or really anywhere else on how to do or what parts I needed so I have decided to create this lil faq to give out all the information I have learned through my experience.
Now first of all you may be asking yourself why the hell anyone with a fast car would want to swap to automatic? Well its simple, for drag racing it cant be beat, not only can a auto trans shift faster than you ever will be able to but it also is more consistent and since during the lauch the entire driveline is preloaded you are far less likely to brake parts like axles, driveshafts t-cases etc etc.
First of all I will list all of the parts that are needed and their part numbers:
-A/T FlexPlate x2 MD735674
-Crank Bushing MD732972
-A/T Plate – MD952138
-Rear Engine Mount Bracket – MD143793
-Both Passenger Side mounts – MD143844 Trans Bracket, Body Side Mount
-Starters are Same
-The Inner shaft on the Axel on the Drivers Side
-Shifter w/Cable and Brackets
-Transfer Case
-A/T Rear Differential
-A/T Trans
-Torque converter bolts
-Automatic crankshaft bolts (to hold flexplates)
Now I will break down all parts of the swap and what needs to be done.
Motor Mounts - Some of the motor mounts on the trans are completely different and are impossible to swap over from your manual trans. Luckily both pieces to the front mount are the same and the mount on the drivers side for the engine can obviously be left alone. But both passenger side mounts are different. And on the rear of the trans the bracket that mounts on the trans is different but the mount that stays on the body of the car can stay.
Transfer Case and Differential - Both the transfer case and differential will need to be changed.
Shifter - Obviously you will need to install a shifter, which will bolt right in and then you will also need the single cable to connect it to the trans, you will also need to make sure you have the bracketry to connect the cable to the trans.
Shift control - Now this is where the swap may get a little difficult, there are two different ways to go about controlling the trans. You can either A) Buy a Transmission control computer, wiring harness and all sensors and let the computer control it. Or B.) Buy a IPT Shift controller, make some plates to cover the holes for the speed sensors on the trans and call it a day. I myself went with the Shift controller, it was the easiest method and now I can control my trans as if it were a stick by the push of a button. If you decide to try to piece together the computer system for the trans then all I can say is good luck, it wont be easy. There is one other method to control the trans and that would be with a AEM EMS or other Stand alone system but I wont even go into that.
Links to help out:
IPT Transmissions - http://www.importperformancetrans.co...ishiauto.shtml
I maybe missing something will double check and update.
Edited by Mark (01/08/09 08:02 PM)
Posts: 2515 | From: Naperville, IL | Member Since: 10/11/05 | IP: (72.16.169.241) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 444960 posted 02/16/07 05:51 PM     Remind Me!  Send Private Message   Edit Post
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11885 | From: Clarksville TN | Member Since: 05/04/03 | IP: (24.159.50.110) | Report this post to a Moderator
dsm_drew
Galant VR-4 org Post #: 444981 posted 02/16/07 06:58 PM     Remind Me!  Send Private Message   Edit Post
Nice info. But the IPT link doesn't work. So the IPT controller allows you to shift the trans by pushbutton, kinda like a sequential trans? Very interesting. I love driving a manual, but it would be cool to have a built auto controlled by paddle shifters.
| | | IP: (72.190.58.126) | Report this post to a Moderator
johnnyRacer
Member +++
50/2000
Galant VR-4 org Post #: 453006 posted 03/17/07 02:38 PM     Remind Me!  Send Private Message   Edit Post
any pics?
91 GVR4 SW 0050/2000 -sold
-3gMAS/K&N,680cc,BSE,chip,255lph,3"Exh(no cat),H.MBC,evo8/tein-S
87 Conquest TSI
92 Mustang LX Convt-sold
95 BMW E36 Convt-sold
13 F-150 Coyo
Posts: 776 | From: Chicago | Member Since: 01/09/05 | IP: (67.173.18.222) | Report this post to a Moderator
Galant VR-4 org Post #: 453196 posted 03/18/07 12:17 PM     Remind Me!  Send Private Message   Edit Post
IPT Link
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (218.2.137.102) | Report this post to a Moderator
digit
Galant VR-4 org Post #: 453476 posted 03/19/07 07:13 AM     Remind Me!  Send Private Message   Edit Post
Mark - Just so you know the auto starter and manual starter are not the same. The nose of the starter is longer on the auto starter then the manual since the ring gear is on the converter on an auto so it has to extend farther to get it. This is especially important for people who are running two flexplates instead of one thus moving the ring gear even farther away from the starter.
Edited by digit (03/19/07 07:15 AM)
| | | IP: (71.42.34.186) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 453512 posted 03/19/07 08:47 AM     Remind Me!  Send Private Message   Edit Post
I am running 2 flexplates and a manual starter with no issues..
Mark
Trying To Sell Out
Galant VR-4 org Post #: 454314 posted 03/21/07 10:25 AM     Remind Me!  Send Private Message   Edit Post
Trans is coming out today.. I will take some pictures from under car and what not..
daenan
Galant VR-4 org Post #: 502477 posted 07/07/07 12:39 PM     Remind Me!  Send Private Message   Edit Post
Comparing both 5spd and automatic intermediate shafts yielded some actual differences last night. Not sure if you knew this or not Mark.
Both are identical with the exception of the size/position of the cast mounting bracket (to the block). The automatic shaft is ~3/8" further away from the block when mounted. Keep in mind that the A/C (or whatever) bracket mounts in between the shaft mount and the block.
This means that to run the 5 spd intermediate shaft on the automatic, you will need some strong 3/8" spacers (nut). Mine currently doesn't have AC so I am using spacers either way.
Hopefully, Digit will be able to confirm this for us.
| | | IP: (68.62.239.118) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 502489 posted 07/07/07 01:38 PM     Remind Me!  Send Private Message   Edit Post
Yea I know they are different I wasn't sure what it was called.. I found that out when we couldn't get it to line up and was on a frantic search to find a auto one.. It's hard to tell they are different but hey are..
As you can see on list..
Posts: 2515 | From: Naperville, IL | Member Since: 10/11/05 | IP: (24.15.208.35) | Report this post to a Moderator
digit
Galant VR-4 org Post #: 502493 posted 07/07/07 01:59 PM     Remind Me!  Send Private Message   Edit Post
We can see that on the list. This is a viable option for people wanting to do this swap that might not have all the resources as most of us when sourcing an automatic intermediate shaft. If I'm feeling frisky I'll try to jack up the trans this afternoon and do some measuring with the trans mounted up to verify what Daenan was saying. This was after comparing the automatic and manual shaft side by side with the help of a caliper that looks like it was used by Benjamin Franklin.
Mark - What were the problems with lining up when you tried to use the manual intermediate shaft? Was is a bracket mount bolt hole location or just bracket offset?
| | | IP: (74.185.151.198) | Report this post to a Moderator
91vr4evolution
Galant VR-4 org Post #: 502518 posted 07/07/07 02:57 PM     Remind Me!  Send Private Message   Edit Post
It's the offset, the front diff sits more "rearward" than the manual cars. You can use a manual shaft in an auto, you just have to pack the bracket out from the block, just like when you remove the AC bracket. You can't use an auto shaft in a manual though.
| | | IP: (124.197.8.18) | Report this post to a Moderator
digit
Galant VR-4 org Post #: 502548 posted 07/07/07 03:52 PM     Remind Me!  Send Private Message   Edit Post
That's the same conclusion we came up with about the offset from the block. Thanks
Mark
Trying To Sell Out
Galant VR-4 org Post #: 502587 posted 07/07/07 06:59 PM     Remind Me!  Send Private Message   Edit Post
Yea we noticed that to when doing the swap.. If you use all the auto engine brackets like I did the engine sits a little more forward to
Mark
Trying To Sell Out
Galant VR-4 org Post #: 502681 posted 07/08/07 02:55 AM     Remind Me!  Send Private Message   Edit Post
Perhaps this could be a write ups... seem gto be more comon after me and deanon did.
475/1000
Galant VR-4 org Post #: 502703 posted 07/08/07 08:23 AM     Remind Me!  Send Private Message   Edit Post
Ok what was done to the insides to make it live. I started to do this a few years ago when there was a Galant GSX at the junkyard but the guys at the only transmission shop in town I trust told me to run and not think of it again. A list of mods inside might help someone considering all this. For example
Drilling out the drums to release fluid faster, the chevy and ford guys always do this.
Upgrade clutch plates?
Upgrade valve body or shift kit?
Torque converter, how much stall are you running and is it a non lock up converter.
Fluid cooler?
external filter?
Upgraded input output shafts?
92 GVR4 0475/1000
Posts: 11885 | From: Clarksville TN | Member Since: 05/04/03 | IP: (24.183.205.195) | Report this post to a Moderator
digit
Galant VR-4 org Post #: 502733 posted 07/08/07 10:10 AM     Remind Me!  Send Private Message   Edit Post
I will be doing a full write up with pictures soon of the swap process. Probably around the end of this month or the end of august depending on how motivated I get. Write up will include trans upgrades and the such, what route I went with certain parts and why. Some information will have to be kept a secret through for proprietary information purposes.
daenan
Galant VR-4 org Post #: 502778 posted 07/08/07 12:37 PM     Remind Me!  Send Private Message   Edit Post
4500RPM stall, end clutch upgrade, translab shift kit.
2G automatics have a lock up, 1Gs don't.
digit
Galant VR-4 org Post #: 598994 posted 02/02/08 09:31 AM     Remind Me!  Send Private Message   Edit Post
Anybody got the part number for the A/T starter/spacer plate I need a new one and mitsu is useless and I don't have caps on my laptop.
| | | IP: (216.220.216.156) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 743177 posted 01/08/09 07:56 PM     Remind Me!  Send Private Message   Edit Post
Sorry to bump a old thread. Ive had few pm's about this here is the list.
Edited by Mark (01/08/09 07:59 PM)
Posts: 2515 | From: Naperville, IL | Member Since: 10/11/05 | IP: (67.184.86.21) | Report this post to a Moderator
3rdstrikedsm
Now mandatory for Wendy's Chili to come with cheese
Galant VR-4 org Post #: 743253 posted 01/08/09 10:40 PM     Remind Me!  Send Private Message   Edit Post
I have been thinking on this, Do you use a 1g or 2g trans and which converter?
1994 supra 6spd 612whp and more to come soon!
1995.5 Audi s6 Vi-pec powered!
Posts: 3402 | From: 32159, FL | Member Since: 02/18/08 | IP: (66.253.202.249) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 743285 posted 01/09/09 12:02 AM     Remind Me!  Send Private Message   Edit Post
I used a 1g trans.. You can use stock converter but it isnt gonna stall worth shit. I would recomend a restalled stock of some sort. It really all depends on what turbo you go with.
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 743397 posted 01/09/09 11:12 AM     Remind Me!  Send Private Message   Edit Post
Mark, did you ever switch to the MMF converter?
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2742 | From: Savannah, GA | Member Since: 08/30/05 | IP: (71.229.63.35) | Report this post to a Moderator
Mark
Trying To Sell Out
Galant VR-4 org Post #: 743528 posted 01/09/09 04:44 PM     Remind Me!  Send Private Message   Edit Post
One of them the stall was to low. I have another MMF converter here I am going to try when spring comes.
Posts: 2515 | From: Naperville, IL | Member Since: 10/11/05 | IP: (74.7.44.169) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 744144 posted 01/11/09 01:29 PM     Remind Me!  Send Private Message   Edit Post
Wish you would have kept the car for sale. It would be sitting in Savannah right about now.
Pages: 1 | 2
0 registered and 39 anonymous users are browsing this forum.
Generated in 0.261 seconds in which 0.201 seconds were spent on a total of 15 queries. Turbo powered.
