I have a 1987 JDM Galant VR4 RHD. When I get to 65mph it chimes until the speed decreases below 65mph. Someone must know how to easily disable this. Driving under 65mph is certainly not a viable option...lol
Posts: 2 | From: Streamwood, IL | Member Since: 04/09/18 | IP: (69.47.206.78) |
I too have a JDM VR4 and I am pretty sure that no VR4 ever came with a speed warning chime from the factory. Whatever it is making the noise at 65mph it is likely to be aftermarket. If you start poking around under the dash you should be able to track down the non-factory looking wires.
Good Luck.
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 125 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (58.28.212.87) |
brisvr4 Oceania Distict Enforcer for the Galant VR4 Mafia
posted 04/15/18 11:58 PM
There is a screw on the back of the cluster with a wire that you need to remove. The pic in JDM Chime this link will work if you click it!
Tim
1992 Auspec 11.37 @ 131.46 - E85 goodness and stock block! Official Australian home of the Ugh decal!
Posts: 939 | From: brisbane australia | Member Since: 02/13/04 | IP: (210.10.207.110) |
bobdole Old member with new to me VR4 and starting over. Respect your elders kids 504/2000
posted 04/16/18 12:22 PM
Really? Guess I need to go over 65mph see if mine has.
Great deal on BC coilovers. Hit me up. Whiteline dealer. Vibrant dealer.
Posts: 712 | From: tampa | Member Since: 08/23/07 | IP: (79.71.93.98) |
