Galant VR-4 Forums » Galant VR-4 » Newbies » Charcoal Canister
Charcoal Canister
Galant VR-4 org Post #: 1237569 posted 05/29/17 11:52 AM     Remind Me!  Send Private Message   Edit Post
I Just have a screw plugging this line in the engine bay. When I fill up my gas tank there is a long loud pressure correction. Doesn't seem like the best thing for fuel delivery. Should I just put this system back together? How do others have this system set up? Also my car was converted from NA so i think may be missing a check valve of something.
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (67.81.192.148) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1237581 posted 05/30/17 06:04 AM     Remind Me!  Send Private Message   Edit Post
If we can get away with it (like I can), we just delete the canister and leave the hose open. But, I do have a check valve and do not notice any fuel smell
Thom
Posts: 682 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1237589 posted 05/30/17 11:22 AM     Remind Me!  Send Private Message   Edit Post
I have a fuel smell when driving but not when the car sits in the garage or anywhere else.
I think it is the venting action to the canister and then it makes its way to atmosphere while driving, under the correct conditions.
Essentially I need to know if any of my vacuum hoses are attached to the correct nipples/spots on the 1990 style TB.
I have a check valve and all factory hardware installed on my C53a. Very, very similar to what you will be using, for a charcoal canister.
I think we posted about that a while back?
Looks like the same canister but different fittings and solenoids (or none) used to perform the venting in/out of the canister/motor.
When you have enough parts from multiple platforms and years, you tend to get a little tongue tie when people ask how your canister works. Haha.
C53A 1 of the ~1500
Posts: 1527 | From: THE Ottawa | Member Since: 03/05/05 | IP: (173.206.108.86) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 1237592 posted 05/30/17 11:53 AM     Remind Me!  Send Private Message   Edit Post
My tank holds pressure for some reason. I thought it was vacuum until I really looked into it.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:387:1:808::) | Report this post to a Moderator
mrt0mjones
Galant VR-4 org Post #: 1237594 posted 05/30/17 02:20 PM     Remind Me!  Send Private Message   Edit Post
I would hook up the charcoal canister.
Fuel vapors are not necessarily the "safest" thing to be venting into any area.
The hardest part of waking up is the floor.
Posts: 28 | From: Waterport, NY | Member Since: 04/17/14 | IP: (69.193.90.18) | Report this post to a Moderator
2 registered and 44 anonymous users are browsing this forum.
Generated in 0.031 seconds in which 0.018 seconds were spent on a total of 14 queries. Turbo powered.
