Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Ecmlink and meth injection help
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1237201 posted 05/15/17 10:27 PM     Remind Me!  Send Private Message   Edit Post
I've decided to control meth injection through link using the EGR tab. I know I have the relay all hooked up correctly as when I ground the ground wire it kicks on, yet when I have it plugged into the EGR solenoid plug it won't engage. I either have the wrong plug, EGR is the one near the throttle body correct? or I actually have to directly wire the ground wire to pin 53 at the harness like ECMLINK wiki states. Can someone confirm this?
GVR4 1242/2000
Posts: 321 | From: Wasilla, Alaska | Member Since: 03/01/10 | IP: (66.58.184.202) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1237205 posted 05/15/17 11:22 PM     Remind Me!  Send Private Message   Edit Post
What color are the wires at the plug?
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock
Posts: 2761 | From: Savannah, GA | Member Since: 08/30/05 | IP: (73.21.58.201) | Report this post to a Moderator
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1237206 posted 05/15/17 11:40 PM     Remind Me!  Send Private Message   Edit Post
Yellow w/ red stripe and yellow w/white stripe.
GVR4 1242/2000
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1237226 posted 05/16/17 10:30 PM     Remind Me!  Send Private Message   Edit Post
Where is the EGR plug exactly? Picture would also be great.
I logged the EGR through link and does register the switch when parameters are met, so I'm just not hooked up to the right plug.
GVR4 1242/2000
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1237272 posted 05/18/17 02:15 PM     Remind Me!  Send Private Message   Edit Post
Just updating this, after some digging looks like only CA cars had this plug in the bay. I confirmed this by checking the pin out on my ECU and I have an empty slot, so I added a pin out and going to wire it up to that. I'll update when done to confirm it works.
GVR4 1242/2000
Generated in 0.235 seconds in which 0.221 seconds were spent on a total of 14 queries. Turbo powered.
