Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 91 Talon Tranny in GVR4
kjbtsi6686
Galant VR-4 org Post #: 1235911 posted 03/16/17 04:53 PM     Remind Me!  Send Private Message   Edit Post
I am going to be putting a 91 talon tranny and transfer case in my 91 gvr4. What all has to be changed in order to make it work?
577/2000 (getting there)
1991 Eagle Talon TSI AWD (Reaper)
2016 Ford Fiesta ST
1999 Ford F-350 PSD (Gotta haul them all around)
Posts: 39 | From: Cumming, GA | Member Since: 12/02/15 | IP: (192.12.184.7) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1235913 posted 03/16/17 06:22 PM     Remind Me!  Send Private Message   Edit Post
Nothing.
Ryan W.
Posts: 429 | From: Granby, MA | Member Since: 09/27/06 | IP: (73.142.6.86) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1235921 posted 03/17/17 05:23 AM     Remind Me!  Send Private Message   Edit Post
not true, all the shifter cable brackets need to be changed over or your gonna have a hard to impossible time shifting.
edit: you also need to change the gear selector/slide arm as the DSM has a different height then the VR4
138/2000
Edited by transparentdsm (03/17/17 06:18 AM)
Posts: 3417 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1235925 posted 03/17/17 06:05 AM     Remind Me!  Send Private Message   Edit Post
^^^This right here, or upi will have to drill holes in the leavers on the transmission and place bolts to align the cables properly.
Thom
Posts: 680 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
kjbtsi6686
Galant VR-4 org Post #: 1235927 posted 03/17/17 09:28 AM     Remind Me!  Send Private Message   Edit Post
Does anyone have pics and dimensions?
2016 Ford Fiesta ST
Posts: 39 | From: Cumming, GA | Member Since: 12/02/15 | IP: (69.254.134.150) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1235928 posted 03/17/17 09:34 AM     Remind Me!  Send Private Message   Edit Post
i can take pictures of my assembly later today when i go to my shop, but for dimensions i cant help. i'd need to take things apart to get proper measurements and im not looking to do that. do you not have a transmission in your car to take the brackets off of?
138/2000
diambo4life
476/2000
Galant VR-4 org Post #: 1235930 posted 03/17/17 10:36 AM     Remind Me!  Send Private Message   Edit Post
Quoting transparentdsm:
Didn't know this. Probably why I have issues shifting fast. I got it pretty close now it is only reverse that is a pain. So GVR4 shift cable brackets are unique?
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ in 2014, Street trim, 3400lbs!
Posts: 227 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (2600:8803:bc00:2) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1235931 posted 03/17/17 10:42 AM     Remind Me!  Send Private Message   Edit Post
correct, they have a different height, length and pitch. are your shifter cable adjustments like fully extended?
138/2000
kjbtsi6686
Galant VR-4 org Post #: 1235935 posted 03/17/17 01:04 PM     Remind Me!  Send Private Message   Edit Post
Here's what I have. The set on the left came on the '91 talon tranny, you'll notice they are taller. The one on the right was on the cables on the gvr4. So I'm thinking the shorter one is gvr4?
2016 Ford Fiesta ST
Posts: 39 | From: Cumming, GA | Member Since: 12/02/15 | IP: (73.98.21.36) | Report this post to a Moderator
1025/2000
Galant VR-4 org Post #: 1235936 posted 03/17/17 01:05 PM     Remind Me!  Send Private Message   Edit Post
Note the different angles also
Thom
138/2000
Galant VR-4 org Post #: 1235938 posted 03/17/17 02:05 PM     Remind Me!  Send Private Message   Edit Post
angle is what i was referring to when i said pitch.
138/2000
138/2000
Galant VR-4 org Post #: 1235939 posted 03/17/17 02:07 PM     Remind Me!  Send Private Message   Edit Post
Quoting kjbtsi6686:
also note the different bases on the shifter cable brackets/
138/2000
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1235948 posted 03/17/17 09:07 PM     Remind Me!  Send Private Message   Edit Post
Can't say I've ever had a hard to impossible time shifting my galants using known 1g transmissions. In fact, they shift just as good as my 1g
Ryan W.
1025/2000
Galant VR-4 org Post #: 1235981 posted 03/21/17 02:42 PM     Remind Me!  Send Private Message   Edit Post
because you are using the 1g shift cable mounts. If you use the GVR4 mount, then the shifting can be an issue without changing mounts or putting in new posts to line up with the cables at rest
Thom
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1235987 posted 03/21/17 05:18 PM     Remind Me!  Send Private Message   Edit Post
What about the shifter cables? Are the shifter cables themselves for the 1g different than the cables for the VR-4?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3312 | From: SoCal | Member Since: 01/02/12 | IP:
(2600:1003:b118:f) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1235988 posted 03/21/17 05:30 PM     Remind Me!  Send Private Message   Edit Post
Wouldn't you expect a 1g tranny to come with the mounts... IE you don't have to change anything.
Ryan W.
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1235996 posted 03/21/17 09:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
They are different part numbers, but I've never compared them side by side.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2728 | From: Savannah, GA | Member Since: 08/30/05 | IP: (73.21.58.201) | Report this post to a Moderator
1025/2000
Galant VR-4 org Post #: 1236003 posted 03/22/17 06:18 AM     Remind Me!  Send Private Message   Edit Post
VR-4 cables are a tad shorter, but they don't make a difference in shifting. As for the 1g tranny coming with everything, that is a rarity. Unbolting the bracket is the easiest thing to do before dropping the transmission so they tend to stay with the car.
Regardless, just set the cables in the bracket you have, set the lever to the neutral spot (should be where it rests) but leave the cables off the shift posts/levers at the transmission and see where they fall naturally with the transmission in neutral. Then you can see if a different transmission bracket is needed.
Here is the bracket I am using
Along with the shorter upper shift post.
Thom
pot
182/1000
Galant VR-4 org Post #: 1236015 posted 03/22/17 12:52 PM     Remind Me!  Send Private Message   Edit Post
Below is an old write up on this topic that should offer some help to the topic starter. Please see below:
Shifter cable bracket difference between gvr4 and DSM
182/1000
Posts: 1410 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (204.34.247.203) | Report this post to a Moderator
kjbtsi6686
Galant VR-4 org Post #: 1236020 posted 03/22/17 03:27 PM     Remind Me!  Send Private Message   Edit Post
Awesome info, thanks alot guys for all of the info.
2016 Ford Fiesta ST
Posts: 39 | From: Cumming, GA | Member Since: 12/02/15 | IP: (192.12.184.6) | Report this post to a Moderator
Generated in 0.081 seconds in which 0.056 seconds were spent on a total of 14 queries. Turbo powered.
