Galant VR-4 Forums » Galant VR-4 » Newbies » 313/1000
313/1000
sleeper1ga
313/1000
Galant VR-4 org Post #: 1235143 posted 02/04/17 07:21 PM     Remind Me!  Send Private Message   Edit Post
Well been on the forum for awhile but never introduced myself or my vr4. I picked up #313/1000 back in spring and after dealing with title issues finally got it all in my name in late May. Slowly have been fixing the various issues it had when I first bought the car; Fixed the windshield, fuel pump wiring from hell, battery relocation to match the quality of the fuel pump, fan wiring as well... The paint looked very poor but after many hours of rubbing compound, polishing, and carnuba waxing it started to look less neglected. The car had previously hit a deer so the windshield was cracked, the hood is dented, and it appears that the bumper support was removed after, so currently it is held by zip ties(despite my many attempts to locate a bumper support).
Now to the better side of how I bought it, the car has a .020" wiseco pistons(8.3:1), (supposedly eagle rods however I believe they are stock rods), arp hardware, balance shafts deleted, 20g Godspeed turbo, evo 8 injectors, aem uego, aluminum radiator, lightly ported head, chip tune.
Photos of when purchased...
Daily: 313/1000 20g, dsmlink V3(soon to be SD)
Grudge/Street Car: 90 DSM HX40, Auto, Spray
Build thread links in my bio
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (131.230.68.61) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1235144 posted 02/04/17 07:27 PM     Remind Me!  Send Private Message   Edit Post
Recently picked up DSMlink v3 and have begun tuning but sadly I am 6hrs away from my car for the next few weeks, so I will not be able to finish for awhile... I also picked up SD and will be switching over to that soon. I will be picking up an electronic boost controller and will likely run around 22psi, my goal is to eventually get the car to be a 400awhp daily, however I will need a change of injectors, turbo, and a few other things before I can work towards this.
Here are some more recent photos since I worked on detailing the car and fixing some issues such as windshield, missing badges, and dogleg...
Edited by sleeper1ga (02/04/17 07:29 PM)
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (131.230.68.81) | Report this post to a Moderator
boostme
Galant VR-4 org Post #: 1236452 posted 04/07/17 11:29 PM     Remind Me!  Send Private Message   Edit Post
Sup man. The paint def looks better after the detailed job you did. Where in Illinois are you?
Posts: 26 | From: Crete, IL | Member Since: 10/04/13 | IP: (2601:244:4401:13) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1236456 posted 04/08/17 07:31 AM     Remind Me!  Send Private Message   Edit Post
ECMlink has electronic boost control built in. Buy the ER BCS, or use the stock boost control solenoid to enable the ECMlink boost control feature. It's better than any aftermarket system out there for the Galant/DSM, and basically free.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (04/08/17 07:32 AM)
Posts: 3351 | From: SoCal | Member Since: 01/02/12 | IP:
(2600:1003:b00c:4) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1236463 posted 04/08/17 05:12 PM     Remind Me!  Send Private Message   Edit Post
Quoting boostme:
Thanks I took a ton of time detailing went a little overboard and detailed the door jams and stuff too haha still need to clean the engine bay more, but ideally I'll be pulling the motor this summer to change some minor things... Car is McHenry but I'll probably have the car in Carbondale next fall.
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (131.230.68.93) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1236464 posted 04/08/17 05:14 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
Will probably end up doing the Ingroll Rand, since the cost for the stock boost controller is roughly the same and I can't find the 1/8" .025" orifice restrictor without like $10 shipping for $1 item that is vacuum connector...
sleeper1ga
313/1000
Galant VR-4 org Post #: 1236960 posted 05/06/17 09:15 PM     Remind Me!  Send Private Message   Edit Post
Well getting pretty excited after many months of not getting to be with my car, I'll be back home end of next week!!
The parts stash is pretty decent:
Aeromotive A1000 AFPR
Fuel Injector Clinic Blue Max 1450cc Injectors
Omni 4 Bar MAP sensor
GM IAT
Parking Brake cables
and potentially a bumper fix...
Haven't driven it in about 8 months... so hopefully all these installs go easy and quick, and I should be able to start tuning!!!
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (131.230.42.95) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1236969 posted 05/07/17 10:51 AM     Remind Me!  Send Private Message   Edit Post
The fittings on the AFPR look pretty sketch. I'd strongly advise replacing them before you install it. Nobody likes an engine fire...
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(207.255.187.121) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1236972 posted 05/07/17 05:29 PM     Remind Me!  Send Private Message   Edit Post
Yeah the welds are far from the best on that fitting haha also it would require me to cut the inner timing cover... Like the location of where I could see it, but I'm doing it on the firewall instead just ordered the wrong fuel rail adapter for it last night, hoping that extremepsi will get my email before they send it out, as I bought 8an instead of 6an...
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (131.230.42.98) | Report this post to a Moderator
OldHairyBastard
I take bottom on trannies
Galant VR-4 org Post #: 1236993 posted 05/08/17 03:41 PM     Remind Me!  Send Private Message   Edit Post
Welcome! Good to see more IL people.
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-200M
2008 Toyota Sequoia 5.7L V8-113M
2013 Toyota Tundra 5.7L V8-82M
2017 VW Passat 1.8L Turbo-16M
Posts: 4495 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (162.197.249.69) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1237344 posted 05/20/17 01:37 PM     Remind Me!  Send Private Message   Edit Post
Well engine bay still makes me cringe from all the wire that the previous owner mangled, but at least the center of attention won't be a peeling blue valve cover, think the wrinkle black w/polished letters turned out pretty nice!!
Also in other news, the 1450cc Injectors have been installed, still need to pick up some fittings for the aeromotive a1000 fpr, mounted the map sensor but need to route a boost/vac reference, looked into finding my fuel leak issues(still working on that)...
Edited by sleeper1ga (05/20/17 01:47 PM)
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (67.184.193.98) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1239384 posted 09/04/17 07:11 PM     Remind Me!  Send Private Message   Edit Post
Well here's a much overdue update with the fuel cell that I installed. As you can tell it's streetcar sized but it fit well and still left a little room in the trunk for my detailing supplies along with a little space for groceries!! Still need to hook up the fuel gauge I bought but for now I'm just checking visually every once in awhile... Next step fixing a nasty bit of idle surge...
Also a photo of the new pump and filter that was installed...
I apologize for the deterioration of the thread, I'll try to resubmit photos that were lost due to PB failure...
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (173.28.147.240) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1239385 posted 09/04/17 07:20 PM     Remind Me!  Send Private Message   Edit Post
Also picked up a brand new hood, bumper filler, and fender... they will be waiting on funds to be painted though...
1 registered and 41 anonymous users are browsing this forum.
Generated in 0.249 seconds in which 0.213 seconds were spent on a total of 14 queries. Turbo powered.
