Galant VR-4 Forums » Galant VR-4 » Newbies » Oil filter housing
Oil filter housing
FullPEAK
Newbie
586/2000
Galant VR-4 org Post #: 1234398 posted 12/24/16 04:55 PM     Remind Me!  Send Private Message   Edit Post
Hey everyone, so I'm putting in a new engine into my galant and it's a "cyclone". My old engine took a crap. I'm seeing a difference in the oil filter housing. I notice that the housing on the cyclone does not have what I think is a water line? Am I able to swap that out with my Housing from my other engine ? Why are they different ? Here are some pics . The black filter is the cyclone motor and the blue filter is the usdsm 6bolt I guess you wana call it lol
Thanks.
Posts: 21 | From: Rancho Cucamonga ca | Member Since: 09/28/16 | IP: (66.27.147.209) | Report this post to a Moderator
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1234400 posted 12/24/16 10:02 PM     Remind Me!  Send Private Message   Edit Post
The oil filter housing on the cyclone engine is designed for an external oil cooler. That's what those two large threaded holes are for, oil out and return. Your engine uses a water cooler for the oil. If your cyclone engine is a 6 bolt, you should be able to take your water cooled oil filter housing off and bolt it on to the cyclone engine.
796/2000 Summit White
91 Black Cherry Talon Auto AWD
94 Pearl White 3KGT
88 Fiji Blue Conquest TSi
03 Labrador Black Evo
Posts: 369 | From: Ferndale, WA | Member Since: 03/23/08 | IP: (66.114.37.210) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1234410 posted 12/26/16 01:46 PM     Remind Me!  Send Private Message   Edit Post
Many of us put the external oil cooler housing on as an upgrade. A bit more work than the water cooled version.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Posts: 10467 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
FullPEAK
Newbie
586/2000
Galant VR-4 org Post #: 1234418 posted 12/26/16 08:16 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the help guys. I started swapping out the parts. Anything else I should look out for on this engine? FYI the engine was included with ECU, complete harness/outer fuse box .. I'm assuming that I'm good to swap out my old harness and ecu correct? I saw on a past thread that there's something I may need to change with the abs? And also I will not be able to use dsmlink ? Is that true?
Posts: 21 | From: Rancho Cucamonga ca | Member Since: 09/28/16 | IP: (71.84.94.137) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1234446 posted 12/27/16 03:14 PM     Remind Me!  Send Private Message   Edit Post
the water housing is garbage, you're better off putting together an air/oil cooler with the "90-style" housing.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3593 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (160.202.136.10) | Report this post to a Moderator
FullPEAK
Newbie
586/2000
Galant VR-4 org Post #: 1234450 posted 12/27/16 04:34 PM     Remind Me!  Send Private Message   Edit Post
I see, I already started converting over the water oil housing. Hopefully it will hold up. I'll look into after market units if needed.
M
Posts: 21 | From: Rancho Cucamonga ca | Member Since: 09/28/16 | IP: (166.137.8.62) | Report this post to a Moderator
FullPEAK
Newbie
586/2000
Galant VR-4 org Post #: 1234663 posted 01/06/17 01:44 AM     Remind Me!  Send Private Message   Edit Post
Hey guys so I'm going with your advice, & sticking with external air oil cooler. I did more reading up and yep that's the way to go. So question, Do you know if this is from a galant or 3000GT I cannot find anything close to it online. Yes it does say 4g63 but but I can't find anything to compare to be sure. I'd like to use it if possible. If not I'll go with the STM kit, open for other suggestions also.
FullPEAK
Newbie
586/2000
Galant VR-4 org Post #: 1234664 posted 01/06/17 02:05 AM     Remind Me!  Send Private Message   Edit Post
It really looks like a intercooler to me
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1234666 posted 01/06/17 06:10 AM     Remind Me!  Send Private Message   Edit Post
That looks like the factory GVR4 Intercooler
Thom
Posts: 680 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1234667 posted 01/06/17 07:50 AM     Remind Me!  Send Private Message   Edit Post
The only oil cooler there is the small line attached to the big unit.
Posts: 10467 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
1025/2000
Galant VR-4 org Post #: 1234669 posted 01/06/17 08:13 AM     Remind Me!  Send Private Message   Edit Post
Those look like power steering cooler lines maybe? JDM style?
Thom
828/1000
Galant VR-4 org Post #: 1234671 posted 01/06/17 08:21 AM     Remind Me!  Send Private Message   Edit Post
Agreed, I could have been clearer. Those are likely p/s cooler lines (which are still essentially an oil cooler).
138/2000
Galant VR-4 org Post #: 1234672 posted 01/06/17 10:04 AM     Remind Me!  Send Private Message   Edit Post
It's a top mount intercooler from a jdm RVR. There are 4 mounting points and the gasket around the core is for an air tight hood seal
138/2000
Edited by transparentdsm (01/06/17 10:07 AM)
Posts: 3417 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
1025/2000
Galant VR-4 org Post #: 1234678 posted 01/06/17 11:10 AM     Remind Me!  Send Private Message   Edit Post
Completely forgot about the top mount RVR intercoolers.
Thom
138/2000
Galant VR-4 org Post #: 1234683 posted 01/06/17 02:28 PM     Remind Me!  Send Private Message   Edit Post
im such a freaking nerd, i have to know everything i can involving a 4g63t.. my favorite part is actually when im wrong and someone can prove it. i love learning new things and having to start my research over.
138/2000
1 registered and 22 anonymous users are browsing this forum.
Generated in 0.038 seconds in which 0.017 seconds were spent on a total of 14 queries. Turbo powered.
