Galant VR-4 Forums » Galant VR-4 » Newbies » options for struts?
options for struts?
Toago
Newbie
Galant VR-4 org Post #: 1233858 posted 11/29/16 11:56 PM     Remind Me!  Send Private Message   Edit Post
hi all. first poSt here. excited to have found an active galant forum!
I do not have a vr4. I have a eagle gtx 2000 which is very similar. however only running a 2.Slow non turbo 4g63.
I need new front struts and mounts at least. I usually get stuff off of rockauto. they have prices from 30 to 60 dollars per front strut what confuses me is some are fwd, the more expensive say awd. but the kyb one id really like says both.
I am wondering can you use fwd struts on the awd platform. this is kind of my low budget winter beater so I'd like to find the most cost effective solution.
thanks for any input
Posts: 7 | From: Calgary Canada | Member Since: 11/29/16 | IP: (174.90.222.66) | Report this post to a Moderator
Galant VR-4 org Post #: 1233860 posted 11/30/16 07:07 AM     Remind Me!  Send Private Message   Edit Post
Weldcome. I have never owned a fwd Galant, but if fwd Eclipse/Talon vs awd is similar, the front struts are slightly shorter for a lower ride height (awd is higher). KYB may have made a compromise strut that adequately works on either, but not exactly the same as stock.
You didn't specifically ask about the rears, but they are definitely different in the mounting.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10562 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Toago
Newbie
Galant VR-4 org Post #: 1233975 posted 12/04/16 07:59 PM     Remind Me!  Send Private Message   Edit Post
sorry I should have clarified. my eagle 2000 GTX is AWD, so I think its pretty close to the VR-4 in what struts and mounts I should be able to use.
I think I will just step up to the KYB level VR4 struts and mounts, I specifically need the front right now as my driver side mount is quite worn and the shock has room to wiggle over bumps which makes the car a bit unstable to drive. the FWD struts are around 35$ CDN where the AWD struts are closer to 70. still not overly expensive since ill be doing the work myself
Posts: 7 | From: Calgary Canada | Member Since: 11/29/16 | IP: (68.146.80.17) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1233983 posted 12/05/16 11:20 AM     Remind Me!  Send Private Message   Edit Post
He knows what the 2000GTX is, it's the Canadian counterpart to our Galant GSX. Iceman was saying while he hasn't personally owned a fwd galant, that if they are any'thing like a fwd 1g dsm (90-94 Eclipse/talon/Laser), then the fronts off the fwd galant could work on your GTX.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2710 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (84.11.11.5) | Report this post to a Moderator
Galant VR-4 org Post #: 1233986 posted 12/05/16 01:58 PM     Remind Me!  Send Private Message   Edit Post
Yeah, that. Thanks for translating to Canadian Reed.
Toago
Newbie
Galant VR-4 org Post #: 1234049 posted 12/07/16 09:44 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the information and sorry for misreading your post. I am wondering if you can educate me a little further. If i do use the FWD struts in the front, would I still use the gsx or vr4 mounts? if this is going to lower the car could I use the rear shocks as well to even things out?
"Just to be pedantic!"
Galant VR-4 org Post #: 1234053 posted 12/08/16 12:32 AM     Remind Me!  Send Private Message   Edit Post
FWD front struts will bolt right in and will lower the car, but be aware the FWD springs are softer as they have to deal with less weight. You're likely to bottom the shocks out more frequently with the FWD struts in the front. The FWD rear struts do not fit on the AWD - the bottom mount is different.
Posts: 2090 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (220.244.112.238) | Report this post to a Moderator
Toago
Newbie
Galant VR-4 org Post #: 1234077 posted 12/08/16 03:38 PM     Remind Me!  Send Private Message   Edit Post
Okay thanks for the input,
my springs are fine and I am purchasing new struts so if the AWD springs won't work with the FWD struts its just more things to buy. currently days averaging -13 deg Fahrenheit, I don't feel like looking for a junkyard option.
my plan is to compare the VR4 vs GSX/E200GTX struts and just go kyb struts and mounts for the front with whatever boot kit is cheapest.
Posts: 7 | From: Calgary Canada | Member Since: 11/29/16 | IP: (75.158.77.72) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.229 seconds in which 0.208 seconds were spent on a total of 14 queries. Turbo powered.
