I think I found the problem.
Iggy
Ashland. Wi
So after replacing my rubber brake lines because one had blown, I wasn't getting any fluid to the rear wheels. The i decided to check the block on the fire wall that the lines run through, which I believe is the propositioning valve(tho I have no idea how it works.) I have fluid going into it and NONE coming out of it. I even took it off an tried to blow compressed air trough it an got nothing.
So my question is, why can I not find one for a car with ABS. Even JNZ only sell them for non ABS cars. So what's the deal? can I use a non ABS one?
heres some pics of the part.
467
Fremont Ca
If you bypass the ABS pump yes you can. Non ABS lines from a galant or 1g eclipse will bolt up, or you can carefully rebend the present lines to fit.
I'm not sure compressed air is valid test to prove it's no good.
idreamidrive
Murray, KY
Not the best way to do it, but sometimes quick stabs of the brake pedal will clear up a stuck valve.
Make sure all brake lines are connected correctly.
Bleed fronts.
Try to bleed rears. If that is a no go and you have what feels like a brake pedal do some kick ninja quick to the brake pedal to try to unstick it.
Bleed rears.
Bleed fronts again.
EMX5636
Bucks County, PA
I just had to replace one of those in a 1G because of a stuck valve. I don't remember if they are available anymore, but the part number for a new one is MB699656 (That's the Galant specific number). JNZ Tuning lists them for $73. You would have to call or email to check availability.
