I've been posting on the issue for over a year now.
In short, the car just stopped running right with no changes. Compression was fine, but it sounds like it had a major miss-fire and it runs rich.
I ended up having the head rebuilt because my thermostat opened up late and the car ran hot. Some how, compression was well above the service point, but I did find coolant in one cylinder. Number 4 I think it was. I replaced the head, compression is between 150-155 on all 4. Some improvements... The exhaust is cleaner, no sweat smell. Not loosing any more coolant.
The overall problem still exist. As far as I know, all the parts have been replaced for spark and Iceman gave me a used CAS to try. I sent my ECU off to be tested and it was fine, but I'm not 100% sold that it is working right. I've asked to borrow a spare many times, but I can never get one.
The odd part, when it was failing, it would randomly start running right, even when coolant was getting past the head gasket (I suspect it was a micro leak, but not enough to lower compression to the service point). I even drove it out of town and bought new tires for it and it ran perfect. Then one day, it just never ran right. I suspect it is a sensor, electrical problem. I don't have any error codes and I'm not a logger expert, but I spent a whole weekend checking the ranges of everything with pocket logger for dummies and everything seems in spec. It's like everything looks good on paper, but the car just doesn't run right.
I can start it and rev it up, but under load, it feels like it has 50hp. It will start to pull under boost, but I've only hit like 1-2psi. I've double checked the timing probably 5 times now and I've done so many boost leak test. I can't can't find a failure.
Mods are not too big, but more important, nothing was changed in probably 5 years. Tuning is by a keydiver chip.
I also tested the TPS as well.
