Galant VR-4 Forums » Galant VR-4 » Newbies » Hylomar non-setting on mls
Galant VR-4 org Post #: 1200002 posted 01/28/15 04:59 PM     Remind Me!  Send Private Message   Edit Post
My block surface was just resurfaced very smooth but there are still some slight scratches from previous decking. I'd like to use a Nippon mls and think this Hylomar product may be a better choice over the commonly used copper spray.
7 1G DSM's now a GGSX build.
Edited by tektic (01/29/15 10:23 AM)
Posts: 1392 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.35.210) | Report this post to a Moderator
turbohf
anyone even read this?
613/2000
Galant VR-4 org Post #: 1200033 posted 01/28/15 10:04 PM     Remind Me!  Send Private Message   Edit Post
i like to use Hondabond
i have been doing it like that for years. something an engine builder had told me (think maybe i seen Larry at Endyn post something?). had several others that say they do the same.
i dont like the copper spray, seen it make a mess in a cooling system, and it pissed me off.
i have also put headgaskets on virgin at others request. and never really had issues that didnt involve a slightly warped head to begin with.
edit: btw, that is a super thin layer. you probably dont want that squeezing out into the oil drain passages.
Dustin
1991 GVR4 #613
1966 Chevrolet Chevy II Nova 400 4dr Sedan V8
Edited by turbohf (01/28/15 10:07 PM)
Posts: 540 | From: Lake Stevens, WA | Member Since: 11/18/11 | IP: (184.78.169.242) | Report this post to a Moderator
Galant VR-4 org Post #: 1200053 posted 01/29/15 06:12 AM     Remind Me!  Send Private Message   Edit Post
Does Honda bond dry like glue?
Posts: 1392 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.35.3) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1200056 posted 01/29/15 07:58 AM     Remind Me!  Send Private Message   Edit Post
Wtf is Honda bond?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3337 | From: SoCal | Member Since: 01/02/12 | IP:
(174.236.193.73) | Report this post to a Moderator
EHmotorsports
Capt Fabbin Stabbin
1865/2000
Galant VR-4 org Post #: 1200058 posted 01/29/15 08:16 AM     Remind Me!  Send Private Message   Edit Post
Just like yamabond only for Honda.
Posts: 1272 | From: Beaverton | Member Since: 09/26/12 | IP: (98.246.179.90) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1200064 posted 01/29/15 08:45 AM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
no, it dries to a rubber.
Dustin
1991 GVR4 #613
turbohf
613/2000
Galant VR-4 org Post #: 1200079 posted 01/29/15 11:19 AM     Remind Me!  Send Private Message   Edit Post
Dustin
1991 GVR4 #613
Posts: 540 | From: Lake Stevens, WA | Member Since: 11/18/11 | IP: (208.54.83.187) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1200113 posted 01/29/15 04:36 PM     Remind Me!  Send Private Message   Edit Post
There are two kinds, be sure it's the HT as shown the pics. The other stuff will run like goo at engine temp. I don't even know why they make it.
Also Honda Ultra Flange II is similiar but has better sealing capabilities, if used just right. Comes in a cheese can so it's easier to handle.
Like mentioned, use only a minimal layer on HGs due to squishing out into ports and drains. I personally don't like it and it makes me nervous, but I've heard and seen it done lots of times.
I've used this a lot and it works damn good. Smells like wet cardboard when used. Good example is a buddy of mine blew his HG on his 420A Turbo neon at the track. Coolant was a stream out the gasket. He had a can of this, so we pulled the head at the track, wiped it all down, sprayed this on and put it back together. Damn thing stopped leaking and drove 40 miles back the shop with no leak. (we still fixed it right after that)
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1200115 posted 01/29/15 04:40 PM     Remind Me!  Send Private Message   Edit Post
Can you really put the word Mopar on a can that also contains the phrase "There's no substitute for quality"?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(72.45.2.251) | Report this post to a Moderator
Galant VR-4 org Post #: 1200129 posted 01/29/15 06:57 PM     Remind Me!  Send Private Message   Edit Post
So what do you guys think of the updated pics in the first post?
I just moved the block into my basement and by handling it and a bunch of black crumbs started falling out. Spent the last three hours grinding and sanding flashing out of the block. What a mess. I sprayed with brake cleaner and ran some brushes through it but I think I'm going to have it jet washed again tomorrow.
Posts: 1392 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1200130 posted 01/29/15 07:52 PM     Remind Me!  Send Private Message   Edit Post
was thinking about the Mopar sealer but forgot what they called it. had people swear by that stuff.
I used the Honda Ultra-flangeII on my oil pan on the Galant. good stuff also.
Dustin
1991 GVR4 #613
dandanger
Galant VR-4 org Post #: 1200145 posted 01/30/15 01:00 AM     Remind Me!  Send Private Message   Edit Post
Yeah, Honda bond HT is the shit, but unfortunately it's not under production anymore. With good luck you can find old stock somewhere. I was working in a motorcycle shop for over 10 years(Honda..) and this was the only thing we used. Can be used even to surfaces without paper gasket.
Kent makes something similar, called Sili-gasket. We used that when Honda stopped shipping the Bond.
Galant '91 VR4 JDM
Posts: 59 | From: Finland | Member Since: 11/02/11 | IP: (80.220.99.149) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1200171 posted 01/30/15 11:29 AM     Remind Me!  Send Private Message   Edit Post
really? we have 5 of those on the shelf. computer days Portland warehouse has a bunch. you guys are getting boned.
Dustin
1991 GVR4 #613
715/1000
1284/2000
Galant VR-4 org Post #: 1200182 posted 01/30/15 12:51 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
That's cause Mopar has someone make the sealant. The stuff is awesome. I haven't used it in a couple years and I think they have a new can design, so not sure if it's the same formula or not.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Galant VR-4 org Post #: 1200184 posted 01/30/15 12:51 PM     Remind Me!  Send Private Message   Edit Post
He is in Finland, btw.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10526 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1200185 posted 01/30/15 12:56 PM     Remind Me!  Send Private Message   Edit Post
ahh, did not notice that.
Dustin
1991 GVR4 #613
Posts: 540 | From: Lake Stevens, WA | Member Since: 11/18/11 | IP: (172.56.33.252) | Report this post to a Moderator
G
obsessed with the turds of others
486/1000
Galant VR-4 org Post #: 1200254 posted 01/30/15 11:31 PM     Remind Me!  Send Private Message   Edit Post
All this hon/ yam bond you are talking about is made by click It's a bad idea to be putting anything on those surfaces in the block pics above. Whoever is teaching that practice needs to be spanked.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8822 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
dandanger
Galant VR-4 org Post #: 1200257 posted 01/31/15 03:49 AM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
Could be also because of that. Some other Honda chemicals and all of the oils were also dropped some years ago, guess something to do with eu-restrictions. Then they started a new oil line locally in eu. But we were told that production had stopped for honda bond .
Galant '91 VR4 JDM
Posts: 59 | From: Finland | Member Since: 11/02/11 | IP: (66.249.81.145) | Report this post to a Moderator
Galant VR-4 org Post #: 1200271 posted 01/31/15 08:57 AM     Remind Me!  Send Private Message   Edit Post
Quoting G:
I didn't ask about Hondabond. Hondabond is not an option. It is not going on my head gasket. Don't get me wrong it has it's place. It would probably work well on the valve cover gasket, but I digress.
The product I originally asked about is aerosol, designed for head gaskets, and designed not to dry. I guess no one here has any experience with it. It is made in the UK as far as I know. I saw some positive but brief mentions of it on other Mitsubishi boards but mostly over seas.
I did however ask for opinions on the surface finish of my block. The guy who did it says the MLS will seal fine clean and dry but I'd like a second opinion before I bolt down a new gasket dry again.
I have yet to see a comment on the surface finish.
diambo4life
476/2000
Galant VR-4 org Post #: 1200311 posted 01/31/15 12:52 PM     Remind Me!  Send Private Message   Edit Post
I use Permatex copper spray (readily available from your favorite local auto-parts store) on MLS HGs and have done so for years in cars that see 40psi+ boost levels with excellent results.
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Posts: 233 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (69.174.87.60) | Report this post to a Moderator
turbohf
613/2000
Galant VR-4 org Post #: 1200316 posted 01/31/15 01:10 PM     Remind Me!  Send Private Message   Edit Post
from the pictures it seems that the deck is a little rough for a MLS gasket. when you had it machined did you tell them you where going to be using an MLS gasket? with a fresh machined block and head a viton coated (like OEM or Cometic) MLS headgasket should have no problems at all being thrown on with a clean surface.
really adding a layer of Hondabond/Mopar/copperspray/whatever is just for the paranoid or the ones that are trying to hide an imperfect surface.
on my Galant when i put the 2.4L in it i just cleaned the block surface (brake clean and red scotchbrite), threw a virgin Cometic headgasket down, and topped it off with my fresh cleaned off machined head (for MLS).
Dustin
1991 GVR4 #613
turbohf
613/2000
Galant VR-4 org Post #: 1200318 posted 01/31/15 01:14 PM     Remind Me!  Send Private Message   Edit Post
i just took another close up look of the surface you posted. do those scratch looking marks catch your finger nail? or does it feel smooth? i have never machined an iron block/head, just aluminum. and those always seem to look super smooth when machined for MLS gaskets.
Dustin
1991 GVR4 #613
Galant VR-4 org Post #: 1200343 posted 01/31/15 06:40 PM     Remind Me!  Send Private Message   Edit Post
Between holes 2 and 3 is the only rough patch. I can catch my finger nail in a few of those tooling marks. some are deeper than others. The rest of the surface is super smooth and so is the head.
donniekak
Member ++
Galant VR-4 org Post #: 1200388 posted 02/01/15 10:08 AM     Remind Me!  Send Private Message   Edit Post
Posts: 742 | From: surprise az | Member Since: 01/01/09 | IP: (71.211.94.31) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1200397 posted 02/01/15 04:13 PM     Remind Me!  Send Private Message   Edit Post
That is interesting. I hate to change what I have always done since it has worked....but, when I have the head off next week, I may try it dry.
Pages: 1 | 2
Rating: *
Generated in 0.26 seconds in which 0.213 seconds were spent on a total of 15 queries. Turbo powered.
