Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » turbo help
turbo help
ExplicitCC
901/2000
Galant VR-4 org Post #: 1192055 posted 10/21/14 01:21 PM     Remind Me!  Send Private Message   Edit Post
What up guys, I'm building #901 and came across a 20g but the o2 side is smaller than my EvoIII 16g, is there a reason why? Should I change it or leave it? 20g the one on the left
Posts: 49 | From: Lake elsinore, CA | Member Since: 02/24/14 | IP: (108.23.31.50) | Report this post to a Moderator
bowler31185
Galant VR-4 org Post #: 1192058 posted 10/21/14 01:36 PM     Remind Me!  Send Private Message   Edit Post
Me personally would try and change if it would fit with no issues. Otherwise you have a lot of porting to do.
Posts: 34 | From: St Petersburg, FL | Member Since: 05/04/12 | IP: (15.227.185.71) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1192066 posted 10/21/14 04:30 PM     Remind Me!  Send Private Message   Edit Post
do you know for sure if they are both TD05H turbine wheels? I would be measuring before swapping housings. How about the entry size, are they mis-matched too?
Posts: 2104 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (90.196.50.113) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1192069 posted 10/21/14 05:12 PM     Remind Me!  Send Private Message   Edit Post
That has to be a Tdoh5 housing. By the looks of it too, I'd swear its a 6cm housing. Pics of the turbine inlet, and other side of the scroll please.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 1192075 posted 10/21/14 06:12 PM     Remind Me!  Send Private Message   Edit Post
^+1 looks like a 6cm housing on left, triangular footprint on mating surface vs. rounded on 7cm.
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
ExplicitCC
901/2000
Galant VR-4 org Post #: 1192611 posted 10/28/14 09:31 PM     Remind Me!  Send Private Message   Edit Post
Here are some more pics
"You want to be happy once in your life? Seek revenge...... You want to be happy the rest of your life? FORGIVE!!!" S.H.M.J.M.E
Edited by ExplicitCC (10/28/14 09:31 PM)
Galant VR-4 org Post #: 1192640 posted 10/29/14 08:27 AM     Remind Me!  Send Private Message   Edit Post
yes that's a 6cm2 ex housing on the 20G I'm sure. I would be swapping over the EvoIII 8cm2 housing over.
Posts: 2104 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (80.175.199.105) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1192648 posted 10/29/14 10:44 AM     Remind Me!  Send Private Message   Edit Post
I don't know how that knock off housing flows. A real evo3 housing is definitely bigger than what's on the 20g, but even the real ones require significant porting.
It's pretty easy to tell given the shape of the turbine->o2 flange that the hotside isn't MHI. The fact that the "TURBOCHARGER" badge is on the front means "definitely not a real Evo3"
I'd also note that the MHI Evo3 B16g came with a 7cm^2 hotside, not 8cm^2.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Edited by slugsgomoo (10/29/14 10:45 AM)
Posts: 3643 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (209.189.196.1) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1192707 posted 10/29/14 08:38 PM     Remind Me!  Send Private Message   Edit Post
Neither turbo is a 20g. They have a 2.75" inlet and are down firing turbos that do not use a j-pipe.
I GIVE ZERO FUCKS. I HATE YOU ALL.
Posts: 1235 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (65.128.96.205) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1192710 posted 10/29/14 08:54 PM     Remind Me!  Send Private Message   Edit Post
I would agree that neither is a "real" 20G but they jam 20G compressor wheels into factory appearing housings and call them bastard 20G's. That large of a compressor wheel with the small turbine side to help spool is a recipe for poor performance though. Ever see anyone run record breaking times with one?
I love my crazy mother!!!
Posts: 1542 | From: Manchester, NH | Member Since: 07/17/06 | IP: (50.136.74.191) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1192716 posted 10/29/14 09:54 PM     Remind Me!  Send Private Message   Edit Post
The last sentence is very misleading and has nothing to do with a "recipe for bad performance".
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2325 | From: USA | Member Since: 01/07/12 | IP: (66.87.131.37) | Report this post to a Moderator
Galant VR-4 org Post #: 1192720 posted 10/29/14 11:27 PM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
a bastard 20g It's not necessarily bad performer.. compared with an evo 3 16g It adds extra flow but some extra lag comes with it. It's just a different turbo. your car will produce more power but slightly higher in the rpm range. I've had at least 2 different people tell me this was the their favorite turbo they had.
As for the Chinese casting it is like evo 3 casting with the fire ring notch ported out to start. The waste gate flapper is a 34mm but doesn't seem to work as smoothly as the mhi. I was able to get it to stick open if i moved it back and forth with my hand, however with exhaust gasses flowing this may not be possible. the waste gate area still needs to be ported on the units I have seen. The metal doesnt contain as much nickle as the mhi casting so its not as hard and more prone to rust. It's not nearly the same quality of the mhi but if your careful porting and installing it It can work just as well. I striped out the threads of one of the bolt holes way too easily. an this was the reason I didn't use it with my small 16g.
Edited by tektic (10/29/14 11:35 PM)
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
Galant VR-4 org Post #: 1192732 posted 10/30/14 06:41 AM     Remind Me!  Send Private Message   Edit Post
I have exactly that 'bastard' 20G turbo on my Galant, replacing the factory big 16G. I used a Kinugawa turbo 20G compressor wheel and cover combo (has the same part number of the Evo III housing but is clearly a knock-off, but not many would know) and the turbine was clipped/back-cut 7 degrees to help with keeping up with the extra flow. I also swapped on an Evo III exhaust manifold and high-flow O2 housing at the same time but kept the rest of the exhaust stock (cat deleted though). I noticed a huge improvement of power mid and top end and the increase of lag was minimal. I did find due to the extra air flow I was hitting boost cut much earlier at around 16psi now.
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.242 seconds in which 0.204 seconds were spent on a total of 14 queries. Turbo powered.
