Galant VR-4 Forums » Galant VR-4 » Newbies » wiring woes!
wiring woes!
se3razer
145/2000
Galant VR-4 org Post #: 1182435 posted 07/31/14 12:05 PM     Remind Me!  Send Private Message   Edit Post
So my galant has a 1g DSM dash harness installed in it. I understand mitsu like other manufacturers use many same style plug ends but just because a plug slides in doesn't mean the pins are located the same like using a 2g aem in a 1g have to swap a few things. It would be wonderful if someone has came across this because I won't hook battery up until every wire is retraced or I buy both new harnesses. Needless to say it is a hot mess.
That feeling you get when you car pulls harder than before then the BOOM
07 Scion tc - drag car
97 gst - daily
145/2000 - p
Posts: 35 | From: charleston, sc | Member Since: 07/27/14 | IP: (2600:1004:b120:c) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1182459 posted 07/31/14 02:51 PM     Remind Me!  Send Private Message   Edit Post
What is your question?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3373 | From: SoCal | Member Since: 01/02/12 | IP:
(72.45.2.251) | Report this post to a Moderator
se3razer
145/2000
Galant VR-4 org Post #: 1182477 posted 07/31/14 04:14 PM     Remind Me!  Send Private Message   Edit Post
I think I was floating between venting and if anyone knows if those dash harnesses are pinned the same other than the one plug where it meets the engine harness having a different connector. If someone says yeah totally works I did it then that's a starting point or should I just buy both harnesses?
97 gst - daily
145/2000 - p
Posts: 35 | From: charleston, sc | Member Since: 07/27/14 | IP: (2600:1004:b023:d) | Report this post to a Moderator
Galant VR-4 org Post #: 1182483 posted 07/31/14 05:26 PM     Remind Me!  Send Private Message   Edit Post
Now would be a good time to start reading the electrical manual. Why do you think its a DSM dash harness?
7 1G DSM's now a GGSX build.
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2001:5b0:22ff:2e) | Report this post to a Moderator
se3razer
145/2000
Galant VR-4 org Post #: 1182487 posted 07/31/14 05:57 PM     Remind Me!  Send Private Message   Edit Post
Because he said they took a 1g harness and swapped it in because the galant one was cut up and they had a 1g gsx dash harness and said it looked the same but that doesn't mean all the pin positions are so. I have the factory electrical manual and it is going to take days of man hours to go section by section. I just feel like it is crazy work since I didn't trace the other harness out and my last three messages have fell on deaf ears to the PO. He might have verified all the pins match but I just can't verify.
97 gst - daily
145/2000 - p
Galant VR-4 org Post #: 1182489 posted 07/31/14 06:18 PM     Remind Me!  Send Private Message   Edit Post
100s of man hours? I think not. First off identity witch connectors have been damaged or swapped. lable all conectors with masking tape lables. LOok for missing pins in the cable you think were swapped. Trace those circuits on the diagram. Sounds like an hour or 2 to me.
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2001:5b0:22ff:ef) | Report this post to a Moderator
Galant VR-4 org Post #: 1182490 posted 07/31/14 06:21 PM     Remind Me!  Send Private Message   Edit Post
Does the car run? Do things on the dash not work? Start there.
se3razer
145/2000
Galant VR-4 org Post #: 1182491 posted 07/31/14 06:46 PM     Remind Me!  Send Private Message   Edit Post
There aren't any damaged wires. Its the whole dash harness from a 1g so that's assuming the cluster HVAC and every other thing that bolts to the gsx is the same as the vr4. I didn't say hundreds days like 16 hours. I completely built a new harness for my tc but I started the job and finished it. The car doesn't run but my mind says of any power and grounds leads are different from this gsx harness I have then the vr4 stuff will then burn up so I'm trying to avoid that. So I don't know how you would get there is only two hours of work there. I will upload pics. Not trying to be a resistance just some of the stuff said didn't match up with what I was saying. The dash harness is unmolested but from a gsx. Installed in my vr4 and the engine harness is a whole different monster.
97 gst - daily
145/2000 - p
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1182492 posted 07/31/14 06:50 PM     Remind Me!  Send Private Message   Edit Post
part it out.
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (208.54.32.202) | Report this post to a Moderator
se3razer
145/2000
Galant VR-4 org Post #: 1182493 posted 07/31/14 06:54 PM     Remind Me!  Send Private Message   Edit Post
That's the engine harness as it sits when I bought he and the po told me it plugs right into the 1g gsx dash harness minus 1 connector is different. But I haven't dug into anything yet just kind of fiddled around so far like make the brake lines and going over the bolts and nuts. I would essentially have to ohm every point the dash and engine harness meet and make sure they go to the proper place in the car.
97 gst - daily
145/2000 - p
se3razer
145/2000
Galant VR-4 org Post #: 1182494 posted 07/31/14 06:56 PM     Remind Me!  Send Private Message   Edit Post
Haha part out a car I bought Sunday that doesn't sound kosher. I want done with my 2g so I can drive this daily. Just needs some work. And parts then more work.
97 gst - daily
145/2000 - p
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1182495 posted 07/31/14 07:01 PM     Remind Me!  Send Private Message   Edit Post
I hope you didn't pay too much. Car looks like it needs a lot of work. Sorry man. Hopefully you can plow through it.
1226/2000
se3razer
145/2000
Galant VR-4 org Post #: 1182496 posted 07/31/14 07:08 PM     Remind Me!  Send Private Message   Edit Post
I don't think it was too bad. 4 bolt swap new struts and shocks h&r lowering springs freshened engine has great compression spun it over with my jump pack spare engine trans and transfer case lots of misc extras for $1500. Not great but not a bad price probably about $1500 or so and I should be rock solid.
97 gst - daily
145/2000 - p
Galant VR-4 org Post #: 1182505 posted 07/31/14 08:47 PM     Remind Me!  Send Private Message   Edit Post
Well if you come up with a better idea take that route. I still think my advice was sound. My car runs off an a/t Galant harness I removed all the a/t stuff from and added all the turbo stuff to. It turns over the first time I had the computer set right and hasn't gone on fire yet.
I rtfm.
Edited by tektic (07/31/14 08:49 PM)
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1182511 posted 07/31/14 09:38 PM     Remind Me!  Send Private Message   Edit Post
I can see how that bad hair, er, I mean all those unwrapped wires might seem difficult to trace out but not really too bad. The electrical manual will allow you to trace every wire. It has wire colors, gauge, everything you need. Today I helped a friend trace out and label the two big engine compartment wiring harnesses. If I recall there were something like 70 - 80 or so connectors. That includes just about everything under the hood including all the engine connectors, ABS pump, and the front of the car (e.g., lights, horns, ABS wheel sensors, etc.) I think it will be the re-wrapping and tucking work that will take longer than actually tracing them out.
Edited by holeshotmoe (07/31/14 09:41 PM)
Posts: 1271 | From: MD | Member Since: 04/07/05 | IP: (173.66.166.10) | Report this post to a Moderator
se3razer
145/2000
Galant VR-4 org Post #: 1182560 posted 08/01/14 05:57 AM     Remind Me!  Send Private Message   Edit Post
Yeah the engine harness portion doesn't bother me that rats nest is easily combed through just going to get out there tonight and go through the dash harnessand make sure all tthe wires are going into the right spots.
97 gst - daily
145/2000 - p
Posts: 35 | From: charleston, sc | Member Since: 07/27/14 | IP: (2600:1004:b01b:8) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1182564 posted 08/01/14 07:18 AM     Remind Me!  Send Private Message   Edit Post
Quoting se3razer:
Of course he did.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(174.236.228.170) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1182583 posted 08/01/14 09:29 AM     Remind Me!  Send Private Message   Edit Post
I would search for the right harnesses and just swap them in. That's a mess. If your not very familiar with wiring and have decent experience, you will soon hate the car very passionately. There should be harnesses out there. IMHO, it's far better to pay a little more, than to sort all that mess out.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
se3razer
145/2000
Galant VR-4 org Post #: 1182588 posted 08/01/14 10:41 AM     Remind Me!  Send Private Message   Edit Post
Prove it sir you said exactly what I said at the beginning I have built harnesses but going behind someone half way through a job is much more work than starting from scratch. I am messaging with one guy for both harnesses. As for that other guy posting saying one hour I don't think so sir you are way too optimistic/unrealistic. I will get this car straight asap. I'm relentless.
97 gst - daily
145/2000 - p
Posts: 35 | From: charleston, sc | Member Since: 07/27/14 | IP: (2600:1004:b002:3) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 1182598 posted 08/01/14 11:28 AM     Remind Me!  Send Private Message   Edit Post
Sounds like you're not sure what is in place inside the car at this time.
My suggestion would be to take a picture of the drivers side underdash, shooting straight up from below the fuse box so we can identify what's there.
The etac box would be visible in a pic of that area, and from that we will be able to give you more accurate advice.
It is my understanding that the dash harness in a usdm vr4 is specific to the usdm vr4 model .
I don't believe the any models of the 1g dsm got the etac system.
The galant base models and even the galant gsx (all wheel drive/non turbo) models do not have the etac system (to the best of my knowledge).
That makes the installation of anything but a vr4 dash harness into a vr4 an involved proccess. (The etac module has it's fingers in many systems, from the wipers all the way to down to it's keeping the accesories powered for a set time after the key is turned off.)
... I'm sure it can be done, but it's much more likely that things will never work right and there will be constant gremlins and occasional smoke.
Bodging in a 1g (or other) engine harness is *fairly* straightforward, but playing fast and loose with the chassis and dash harnesses will be significantly more involved.
the bitterness of low quality remains long after the temporary joy of a low price has faded
Edited by toybreaker (08/01/14 11:29 AM)
Posts: 3532 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.38.255) | Report this post to a Moderator
se3razer
145/2000
Galant VR-4 org Post #: 1182602 posted 08/01/14 11:54 AM     Remind Me!  Send Private Message   Edit Post
Yeah I'm going to get pics tonight and try and resolve all this marklar
97 gst - daily
145/2000 - p
Galant VR-4 org Post #: 1182606 posted 08/01/14 12:13 PM     Remind Me!  Send Private Message   Edit Post
Quoting se3razer:
Quoting tektic:
I'm sorry if you misunderstood the intent of my statement. When I said it would take all of hour or two, I meant to identify what harness you have and if anything you need is missing.
The only problem you have here is you don't know what you have or if anything is missing. I'll make it as easy as I can for you.
5 easy steps to compare 2 wiring harnesses
  • Print out both pages of electrical manuals
  • disconnect the 3 or 4 plugs
  • Check the presence of each pin and it's wire color
  • If there is a discrepancy make a note of it
  • Move to the next pin position
  • Go back to step 3 and replete until done
    I there are like 25-30 pins total, most of witch will be exactly the same.
    Heres the plugs that go to the body harness. Dsm on the left Galant on the right Galant has one extra plug as far as I remember. Mine was automatic so it had extra wires for the neutral safety switch on one harness making it bigger. In fact the whole ignition circuit is wired differently on my car than the dsm. I don't remember if this was entirely because it was automatic because the starter switch wiring is different on all Galants. Compare the diagrams, trace the differences. half of the interior stuff comes from the other side of the car and doesn't go through this harness. It's been 18 months since I've looked at it but if I had the manual in front of me I could tell you seconds after I turned to the right page.
    If you don't want to make what you have work it may be easier to find the part the car was supposed to have in the first place. Up to you. I built my car because it's a big puzzle and takes time and effort to remove every single piece and put it back together exactly the way I want it. I have parts from at least 4 different types of cars grafted on to mine. Just what I like to do.
    The last thing I am is optimistic, but I work through my chaos to make order. So what are you relentless at besides complaining?
  • Edited by tektic (08/01/14 12:48 PM)
    Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
    se3razer
    145/2000
    Galant VR-4 org Post #: 1182614 posted 08/01/14 12:48 PM     Remind Me!  Send Private Message   Edit Post
    As I have my first one, there is no complaining just trying to square things away but you can be that guy kind sir. I'm not going to measure with you and go back and forth I just have to find my way with this car. I'm not much of a forum jockey I usually keep to myself and make everything work just takes more time and for these specific reasons probably. For the helpful thank you for knowledge I don't yet possess, for the peanut gallery well you know thanks for the warm welcome. I was just trying to get some insight if its been ran into before but that's wrong of me sorry I hope this doesn't sound like complaining... don't be that guy
    97 gst - daily
    145/2000 - p
    se3razer
    145/2000
    Galant VR-4 org Post #: 1182615 posted 08/01/14 12:50 PM     Remind Me!  Send Private Message   Edit Post
    I'm gonna snap some photos of this harness on the drivers side and take it from there I'm not here to puff chests or act ridiculous I just want to get this heap on the right track
    97 gst - daily
    145/2000 - p
    Galant VR-4 org Post #: 1182616 posted 08/01/14 12:51 PM     Remind Me!  Send Private Message   Edit Post
    ok cool.
    No bullshit there's like a total of 4 different wires. Just look at it. It's not a big deal.
    Pages: 1 | 2
    1 registered and 16 anonymous users are browsing this forum.
    Generated in 0.141 seconds in which 0.074 seconds were spent on a total of 15 queries. Turbo powered.
