Wheels an offset..
Typhoonguy
Active member
Fox Lake illinois
I know this horse has been beat to death. But for the life of me i cant find it with the search function. In the near future i will be putting wheels on my gvr4. An i need some ideas, i want to go no bigger than a 16in wheel. As far as width goes i think i can stuff an 8 in wide? But where i get lost is the offset, what would be a good offset? I want to have my wheels stick ever so slightly out of the fenders. To give you an example, i want them to stick out the width of a deck of cards. Also im going to be streaching the tires to the wheels. Can anyone give me a little advice? I think stock offset is 35mm? Also + offset pulls the wheel further out an - pushes the wheel further in?? Right?? Sorry for all the newb ?'s was never very wheel savy.. Thanks guys
Steve
My advice if your going to do the ridiculous act of hellaflush on a GVR4 is simply this:
Sell the GVR4, buy a damn Honda or VW.
We don't do that stupid crap here.
manikbastrd
/ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/applause.gif
coyotes
Seattle, WA
You can hellaflush all you like but no one is gonna help you here, Lol.
If you wanna be gangster get some 18x10.5" +18 offset on some 225/30/18. You'll need fender flares and about 10 degrees of camber. Enjoy
MellowVR4
Milwaukee, Wi
VDUB and bag it! /ubbthreads/images/graemlins/devil.gif
Typhoonguy
Active member
Fox Lake illinois
Ok im glad i got great advice, maybe everyone is missing my concept here. I want the vehicle to sit flush to the tires!! Im sick of school bus style wheel gap. I also said i dont want to go any bigger than a 16in wheel an no wider than 8in. I believe a 7in would fit nicely. If this makes me a bad person an no one wants to help so be it.
manikbastrd
Known Wheel and Tire combinations
This is google-able...Most users on this forum just don't want to see any VIP status or stretched tires on a GVR4. We try and keep the rice to a minimum around here. Stuff like this:
Civic
As opposed to this:
Galant
That is why you have received a poor response. The link above has a lot of good combinations.
Typhoonguy
Active member
Fox Lake illinois
I really want to stick 4 lug. Just to keep is stupid simple ya know. Yeah as far as ricing the galant out.... No way she is a classic!! I just want a mean stance that will make your dick wiggle a little when ya see it. I found some rota slip streams that i really like they are 16x8 with a 40 offset. Does this sound like it might fit? I have also ordered the bc coil overs
/ubbthreads/images/graemlins/uhh.gif Stance. You just had to say it.
Typhoonguy
Active member
Fox Lake illinois
Sorry i here hellaflush thrown around alot at work, kinda an old guy here. I guess i used the term wrong, but yes what i am looking for is STANCE in a 16in wheel.. Thanks for helpin an old guy out
coyotes
Seattle, WA
Quoting Typhoonguy:
You would need a lower offset to run wheels that are flush with the fenders. +40 is probably close to OEM wheel offset.
4 lug will hurt your options a bit but not too bad.
Typhoonguy
Active member
Fox Lake illinois
Ok so a 40mm off set is slightly in towrds the center of the vehicle. So if i bought like a set of 5mm spacer plates it should work. Thanks for the info so far guys, an sorry for the confusion lol
Near Seattle, Washington
Or just get wheels with 35mm offset. There are a few options out there. I know a 17x8 ET35 requires some neg. camber. about -2 to -2.5 i believe.
coyotes
Seattle, WA
You would need a 20mm or bigger spacer to flush out the stock wheels in back. 5mm won't do much.
coyotes
Seattle, WA
For reference an evo 8 17x8 +35 wheel sits pretty close to flush. Not perfect, but I guess that depends on how close you want to be:
This is the setup I'm wanting to run, I would probably add a spacer in back to perfect the fitment to my liking.
My evo 8's bolted on with no camber needed. I think they look fine as is, but will probably add 5mm spacers in the rear. I'm at stock ride height, but will be doing coilovers soon, and by looking at it, I doubt I'll need much camber or any need to "tuck" the rims.
