Galant VR-4 Forums » Galant VR-4 » Newbies » symptoms of a failing/bad power transistor?
highrpm666
677/1000
Galant VR-4 org Post #: 1170709 posted 05/06/14 11:50 AM     Remind Me!  Send Private Message   Edit Post
Im having a hot start issue with 677. Whenever I drive further than say 10 miles or so and get it nice and warm I have an issue with what seems like a bad misfire and cel when trying to restart. I haven't had a chance to read the flash code/s yet, it seems to only happen when I'm away from my tools of course. If I immediately restart its ok, but if I wait more than 10 minutes or so this issue rears its head. I have figured out that if I open my hood and let it cool off for 2hrs or so I doesn't happen at all.
So im curious if anyone can relate this to a failing power transistor? I havent found many threads at all with a similar issue after google searching. I did find enough information to point me in the direction of the power transistor though. I know I need to pull the code, I'm unfamiliar on how this is done on the galant also.
So could this be my issue and what are some symptoms of failure for this part?
And what the simplest way to get my flash codes? I read somewhere that I need a test light or buzzer setup, is this correct?
VR4 677/1000-rebadged. AKA Charlie the turbo slut DD
Posts: 119 | From: Morrison, Co | Member Since: 02/19/14 | IP: (2600:100e:b003:9) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1170713 posted 05/06/14 11:58 AM     Remind Me!  Send Private Message   Edit Post
Will it crank for a while then start after sitting a while? Could be an electronic, could also be the fuel system bleeding off fuel pressure.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
highrpm666
677/1000
Galant VR-4 org Post #: 1170715 posted 05/06/14 12:03 PM     Remind Me!  Send Private Message   Edit Post
It starts right up, normal cranking time etc. It just misfires and illuminates the cel after a few seconds and it does not go away unless I let the car cool off.
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1170722 posted 05/06/14 12:31 PM     Remind Me!  Send Private Message   Edit Post
Failing crank sensor?
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1631 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (199.96.227.1) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1170752 posted 05/06/14 03:00 PM     Remind Me!  Send Private Message   Edit Post
It seems like i suggest this WAY too often, but in this case I've got to relate a personal experience. My very first GVR4 had a problem similar to this. It would start and run fine when cold. After it warmed up, and i eventually shut it off... it would NOT want to restart. When it did restart, it would stumble, run like shit, or even flat out just die after tripping some CEL codes. When i pulled the ECU i found it to be leaking capacitors.
Have you checked this yet?
97 CBR900RR
2012 Hyundai Veloster
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.95.177) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1170756 posted 05/06/14 04:08 PM     Remind Me!  Send Private Message   Edit Post
Good call, also you really should pull the code. That will at least give something to start with.
12yr+ Vr4 owner.
Family Guy
highrpm666
677/1000
Galant VR-4 org Post #: 1170773 posted 05/06/14 06:16 PM     Remind Me!  Send Private Message   Edit Post
Quoting highrpm666:
I will pull the ecu tomorrow if I get a chance to check my caps. I think its already been re capped but I will know for sure once inspected.
One thing about this issue. I can drive it all day long without any problems as long as I dont shut it off, it only happens when I re start after driving for a while. It never happens while driving, it runs like a raped ape all the time until I fire her back up without letting it cool for a few hours.
It feels like weak spark or low fuel pressure or the ignition timing is off a bit.
BluFalcon
Fantastic Parts Seller
Galant VR-4 org Post #: 1170821 posted 05/07/14 02:44 AM     Remind Me!  Send Private Message   Edit Post
Just to chime in, but here's another one for check the ECU. When I picked up my car and drove it back to Texas from Colorado, it exhibited the same symptoms the OP and Anthony described. Threw a CEL every once in awhile, cut out occasionally, and sounded like it was missing. Put up with it for awhile, and figured I'd figure it out once I got some time to mess with it. until it left me stranded while I was getting groceries.
Tried a new Ignition Power Transistor, Coil Pack, CAS and other things. The ECU didn't look like it was leaking, but I decided to try it anyway, and the problem cleared up.
Ed
93 Eagle Talon TSi/AWD
92 Dodge Stealth R/T TT
06 Mitsubishi Raider V8 DuroCross
521/1000
"SOLD"
Posts: 1307 | From: Wichita, KS | Member Since: 01/20/02 | IP: (76.187.253.168) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1170851 posted 05/07/14 11:05 AM     Remind Me!  Send Private Message   Edit Post
Quoting highrpm666:
Quoting highrpm666:
Maybe a failing coolant temp sensor.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
highrpm666
677/1000
Galant VR-4 org Post #: 1171832 posted 05/13/14 10:33 PM     Remind Me!  Send Private Message   Edit Post
OK I fabricated a code puller from an old Sega game gear. Yes really. Used the speaker from it along with leads and alligator clips. Quite the setup as I didn't disable the game gear in any way and used it semi-intact as the reader.
So it gave me the codes in a pattern of pops/double pops with silence between. The way it read out was "pop----pop/pop--pop/pop--pop/pop----pop----pop/pop----repeat" <actuall pattern. Took me a few minutes of listening to catch it.
I'm guessing I looked pretty stupid with a half disassembled game gear against my ear with my feet dangling out the drivers side! But it worked great otherwise. I have figured out unless mistaken that I may be looking at a code 11 and code 13. The 11 being an O2 fault and the 13 being an IAT fault. According to alldata, both codes can be associated with a failing ecu. But the IAT alone can be tied to a hot start issue. Alldata has a chart that mentions to check the "ecm" in both situations along with underhood wiring and connectors etc.
Looks like I'm driving it back to the shop and yanking the ecu asap. Oddly for a mechanic I don't have the tools necessary to pull the ecu at home And I've been putting off checking it out for two months now.
I've really gotta get this issue figured out so I can focus on the other needed maintenance and repairs! Man I hate intermittent issues! Especially on my own car darn it..
Posts: 119 | From: Morrison, Co | Member Since: 02/19/14 | IP: (70.196.204.135) | Report this post to a Moderator
manikbastrd
A Negro's Savior
504/1000
Galant VR-4 org Post #: 1171836 posted 05/14/14 12:19 AM     Remind Me!  Send Private Message   Edit Post
You sir are a badass. That is really cool.
Co-Founder of Shitbox Racing
1992 Galant VR4-stuff has happened...
2012 Boss 302 Mustang(DEAD)
Posts: 660 | From: Saratoga springs NY | Member Since: 11/19/09 | IP: (2601:7:1400:f5:a) | Report this post to a Moderator
highrpm666
677/1000
Galant VR-4 org Post #: 1172573 posted 05/19/14 02:47 PM     Remind Me!  Send Private Message   Edit Post
So I took the car on a spirited drive through the hills today before I tear the ecu out to send off and had another symptom I havent really mentioned before pop up again..
Under a load in 3rd or 4th gear it bucked and misfired for a brief second until I let out of it. This is happening at about 4500rpms and it just seems to fall flat on its face for a brief moment. No cel. If I let out for a second and get back into throttle it doesn't happen again. Very very intermittent. It only happens about 1 out of 20 times I load it hard and get into boost. It feels like an arcing plug wire or something along those lines. Plugs and wires are brand spanking new. Ive put 400 miles on it since getting it buttoned up and this has happened 5-6 times. Twice today.
Anyway the ecu is headed out to ecmlink this week for capping and socketing and whatever repairs to the board are needed. In the meantime I'm going to de loom the injector harness/cas harness etc and see what repairs are needed before I throw any other parts at her.
I'm praying that the ecu alone is the culprit of all these symptoms and I dont have to remake my entire engine harness from scratch.
Ill post some pics of the opened ecu later on today.
Edited by highrpm666 (05/19/14 03:23 PM)
Posts: 119 | From: Morrison, Co | Member Since: 02/19/14 | IP: (2600:100e:b02c:2) | Report this post to a Moderator
highrpm666
677/1000
Galant VR-4 org Post #: 1172584 posted 05/19/14 04:27 PM     Remind Me!  Send Private Message   Edit Post
I found quite the surprise when I opened the ecu...
looks like a recap and socket job was done already but, they installed jumper wires etc and they forgot to clean up properly. Solder job looks good but I can see corrosion setting in already in one spot from the old leakage, nothing serious though. And who knows whats jumped across the back of the board but, I can obviously see the broken traces.
Anyone local want to test the ecu in a different car for me to see if it exhibits any issues?
Edited by highrpm666 (05/19/14 05:13 PM)
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.148 seconds in which 0.08 seconds were spent on a total of 14 queries. Turbo powered.
