Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 1g to evo x turbo manifold.
TwoSeventyFive
Newbie
275/2000
Galant VR-4 org Post #: 1166628 posted 04/07/14 10:07 PM     Remind Me!  Send Private Message   Edit Post
I know alot of people are going to flame this but I'm building my car for "stockish turbo class" for the dsm/evo shootouts. I'm going to ask if this would fly but the class is group together with dsm and evo's so I dont see why I should not be able to use the evo x turbo. The evo x turbo sits the right way for the downpipe unlike the evo 8 and 9. So I will be welding up a manifold and buying a evo 10 manifold. This turbo hold boost better because of the 12t exhaust housing in the upper range and can be upgraded latter to make more power and with have the best spool time. My first design will be unequal length manifold for stock location bolt on. I have a ETS Galant vr4 front mount kit with a short route kit so I have to shorten and maybe even rotate the 2 bolt flange.
White/Sunroof
Posts: 8 | From: Falling Waters, WV | Member Since: 03/10/14 | IP: (68.34.106.214) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1166666 posted 04/08/14 08:13 AM     Remind Me!  Send Private Message   Edit Post
You must have got a free evo X turbo then, I take it?
Cause otherwise if your spending $1k on an evo X turbo set-up then why not just buy a FP green.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 1166707 posted 04/08/14 12:01 PM     Remind Me!  Send Private Message   Edit Post
^^ FP green is not "stockish" as per his race class desire.
I know the SCCA is a bit funky on "stock" turbos, TD05 turbo from an EVO3 is considered a mod even on a TD05 1g vehicle.
Mike O.
#464/1000 - Sold
05 Legacy GT - 6MT swap
#86/2000 - Sold ( again )
Posts: 3103 | From: Portland, OR | Member Since: 09/10/07 | IP: (192.55.60.26) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1166723 posted 04/08/14 01:04 PM     Remind Me!  Send Private Message   Edit Post
Yea, an evo X turbo won't be stock either. It will be obvious to the tech guy. Why not get a basterd 20g? that will look stock, unless they pull the intake off and inspect.
Just saying...
12yr+ Vr4 owner.
Family Guy
desant78
Member ++
1662/2000
995/1000
Galant VR-4 org Post #: 1166734 posted 04/08/14 01:38 PM     Remind Me!  Send Private Message   Edit Post
I've put a lot of thought into this, and hopefully next summer will make this jump. I can't speak from expierence that there are benefits, but people online claim to have pretty decent spool improvements.
Me personally, I want a twin - scroll vr4, that is why I want to go this route. I also know evo x's in the area, sourcing a turbo personally won't be very hard.
In my head, the best way to accomplish this is to find a stock evo x exhaust manifold, and cut the flange off. Then find a DSM exhaust manifold, and cut the flange off. then weld the DSM flange on the evo x manifold. Someone on tooners (use google to find it) has done this. I'd like to have the advantage of using all these new twin scroll turbos available for evo x's on my vr4. But, I'll warn I don't how this will compare to current cheaper options. I don't really drag race, so I'm not sure how much the increased spool would benefit that style of racing.
Good luck!
i wanna go fast.
Posts: 728 | From: Sewell, NJ | Member Since: 06/23/10 | IP: (138.162.8.58) | Report this post to a Moderator
TwoSeventyFive
Newbie
275/2000
Galant VR-4 org Post #: 1166801 posted 04/08/14 09:00 PM     Remind Me!  Send Private Message   Edit Post
The class is the busher racing shootout stock appearing turbo class which is all dsm and evo against each other so since the turbo is still a to5 then it should be fine. To bad we can just use a evo 8 manifold and the evo 10 turbo but I think the flanges are flipped or I may just use a evo 8 turbo
White/Sunroof
715/1000
1284/2000
Galant VR-4 org Post #: 1166860 posted 04/09/14 09:08 AM     Remind Me!  Send Private Message   Edit Post
Why not throw a stock appearance basterd 20g in tdoh5 trim?
12yr+ Vr4 owner.
Family Guy
dsmless
gay without homosexual tendencies
96/1000
Galant VR-4 org Post #: 1167017 posted 04/09/14 11:29 PM     Remind Me!  Send Private Message   Edit Post
I tossed this idea around alot, was about to get a cheap tubular ebay evo X and dsm header. Chop the flanges off and weld the dsm flange on the evo X header. And also use a evo X O2 housing, also from ebay as thats the cheapest way sonif it does not work your not our much money. The hardest part was sourcing a evo X turbo locally. But still just an idea
96/1000 back in the driveway jsb getting a
lego motor
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (68.228.251.252) | Report this post to a Moderator
Galant VR-4 org Post #: 1167042 posted 04/10/14 02:07 AM     Remind Me!  Send Private Message   Edit Post
I think it really depends on what your priorities are. If you want to be competitive at the shootout I think you could make more power for less money with some of the suggestions above. Similarly, if you are looking to upgrade later you could do that with either platform. However if you are looking to keep your car for some time and build it into a spirited fun daily driver I think the idea has a lot of merit. With the cost of stock EVO III 16Gs going up and given how hard it is to find nice uncracked housings to be rebuilt, I think there is a LOT to be said for investing in a custom twin scroll manifold and downpipe to fit the Evo X turbo on the VR4. Sure it won't be cost effective in terms of the power it makes but it would make for a damn good daily driver setup, and probably would pay for itself in the long run because there are plenty of second hand Evo X stock turbos around either in good condition or at minimum with decent housings. You would have an almost unlimited supply of reasonably cheap fast spooling 16G turbos if you are happy at that power level.
I'm very happy with the power my daily makes and because I have a nice collection of new/rebuilt 16G, 18G and 20G turbos on my shelf, I see no reason to change configurations at this stage but I am certainly thinking that this is THE way to go in terms of future supply of quick spooling, efficient and reliable snails in the 300-350 hp range.
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (218.189.72.4) | Report this post to a Moderator
SSGdave
1855/2000
Galant VR-4 org Post #: 1167043 posted 04/10/14 04:03 AM     Remind Me!  Send Private Message   Edit Post
It can be done but I do not think it will qualify you for a stock appering class.
I was going to do this with 1855 during its rebuild, but I ran out of time (long story)
so this is how you make it possible without hacking up the oem evoX manifold...
You are going to need an addaptor to make the transision from Head to Manifold. I have a Toyota background so I could already see it, because with the 4AGE there is an addaptor to use the Small port head with the large port intake manifold. I knew the same cound be done for the DSM/Evo X exhaust manifold. I had a friend that was going to mill one out for me but like I said, I ran out of time.
The other major piece you would need is a custom 02 housing.
I actually have 2 EvoX turbos and a OEM manifold. One day I was going to revisit this setup but for a 4AGE I have in storage.
Yeah its me "SGTdave". ...and I still don't fuck around when there's work to be done.
1991 GVR4 1855/2000 - Daly Driver "Frankie"
1990 GGSX(turbo)- Project/Serious Road Race Car "Uncle Randy"
Edited by SSGdave (04/10/14 04:04 AM)
Posts: 137 | From: San Diego, CA | Member Since: 05/31/11 | IP: (143.81.0.41) | Report this post to a Moderator
ade
Carbon Fiber Phallus Group Buy Member
Galant VR-4 org Post #: 1168531 posted 04/23/14 10:58 AM     Remind Me!  Send Private Message   Edit Post
kinda off topic but i could see a twin scroll flanged manifold & o2 housing in our future if there's demand for it, maybe someone can talk to fp about it.
posting and you...
Posts: 303 | From: Paumanok NY | Member Since: 08/16/11 | IP: (201.229.37.2) | Report this post to a Moderator
SSGdave
1855/2000
Galant VR-4 org Post #: 1168834 posted 04/25/14 04:02 AM     Remind Me!  Send Private Message   Edit Post
Oh I totally forgot about this but, there is a company in Europe that makes a Manifold and 02 housing for the DSM to run the EVO X turbo. It was all tubular and expencive.
Not really worth the coin though really.
0 registered and 41 anonymous users are browsing this forum.
Generated in 0.267 seconds in which 0.225 seconds were spent on a total of 14 queries. Turbo powered.
