engine conversion
2badvr4
New member
sydney, nsw
Looking for some honest advice...
I've been out of the car game for a long time and I've just bought myself my second VR4. Now, I'm looking for reliability first and foremost and possibly a modern spin on a classic. So I'm thinking later model Evo engine swap?
So my questions are:
1. To the best of my knowledge, up to evo 3 is virtually the same engine, after that it's flipped 180º so intake/exhaust is on the wrong side (right?). Then I heard evo x the engine gets flipped back... is my information correct?
2. Is an engine swap cost efficient?
3. Is this just a dumb idea and should I stick to freshening up the original motor?
89Mirageman
Stantonsburg, NC
Option 3 is probably what you'll get from most on here, it's my vote anyway.
Evo X is still flipped and same as the EVO 4-9. You can put an EVO head on the stock 4g63 block. It takes a lot of work, but can be done. You could fit an EVO 8 engine in the bay and fab up mounts and all that jazz, but your talking lots of fab work that requires high skill levels.
Yep, option 3 is the best idea. In all reality, unless your a glutton for punishment and have deep pockets and want to do something new, then just build the stock engine. You'll still make any power level you want.
BogusSVO
Pensacola, Florida
The Evo X engine is not the same as the 4G63 engine, the Evo X has a 4B11T.
So drop the EVO X swap unless you want to redo and mod the whole front end.
The Evo IX has Mivec, so some fab and wire work will be needed to make that work.
Now the DSM 7 bolt and Evo 4-9 (?) are close to the DSM 7 bolts so the mounts for it are on the trans not the engine block.
So for ease and simplicity, rebuild what you have. Or think of a stroker.
gaylantvr4
Omaha ,NE
The only advantage to a evo 4-9 motor is the transmission. They where designed to hold more power stock and seem to hold up better with alot of power other than that there would be no point in the extra fab work.
raptorWagon
Oak Harbor, WA
Quoting gaylantvr4:
Tell that to the 6spd MR guys lol.
raptorWagon
Oak Harbor, WA
I know /ubbthreads/images/graemlins/wink.gif, but them Evo guys love it when their transfer cases do the death whine nonetheless /ubbthreads/images/graemlins/smile.gif.
Jesus_Negros
USA
Someone should do it. Dream and innovation guys.
Jesus_Negros
USA
And money.
r4pt0x
Bavaria / Germany
Why should a newer engine autmagically be the more reliable one?
Mitsubishi also had to start saving weight and cost over time - older parts/engines/cars often have more reserves as the newer ones have. If they are well maintained they are at least as reliable as a new engine, if not more...
I've rebuilt a VR4 engine ~3 years ago and used the car as a daily-driver even on many long-distance travels doing >1000kms on one day. and here on the german autobahn with a long gearbox i was definately not going slow - the car has often seen speeds well over 250kph...
Never had a single problem with that engine in the ~20k kms since rebuild.
Put the money in a decent overhaul of your engine with OEM Mitsubishi parts - the only parts I have seen failing were aftermarket ones: water pumps (plastic wheel!), exhaust gaskets, hydraulic tensioners etc...
SSGdave
San Diego, CA
Quoting coyotes:
LS1 it.
/ubbthreads/images/graemlins/rofl.gif
SSGdave
San Diego, CA
Quoting Turbro_Negro:
wait, I thought there was some guy in Malaysia that did an CT9A Evo engine and drivetrain into a E3X Galant? /ubbthreads/images/graemlins/confused.gif
either way it would be a lot of work and a lot of money.
gaylantvr4
Omaha ,NE
Quoting raptorreed:
They both have flaws but the awd dsm trans was designed around a 100hp awd colt where as the evo was designed around a 250 hp evo
raptorWagon
Oak Harbor, WA
Quoting SSGdave:
Someone should do it. Dreamand innovation guys.
It was a Eterna with a Evo 4+ head modified to fit a early block.
2badvr4
New member
sydney, nsw
Quoting r4pt0x:
Maybe mor reliable was the wrong word, modern, fresh technology, mivec is supposed to be the bomb, yeah?
Toronto, ON, Canada
He's in Australia (though I think the guy is actually Malaysian), and the car is actually a Galant GSR hatch. The Eterna badge is for JDM cars only.
raptorWagon
Oak Harbor, WA
Honestly though, when we all think Eterna, Galant hatch comes to mind, but say GSR and ECS FWD na 4g63 come to mind lol.
MIVEC is just valve timing, nothing special since MIVEC has been around since the 90s, they just didn't apply it to the 4g63 until the Evo 9 came out.
A later 4g63 conversion is not more modern its just a revised version of a 25+yr old motor lol.
