Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Turbo Blankets
Turbo Blankets
JNR
20/1000
Galant VR-4 org Post #: 1154467 posted 01/05/14 02:15 PM     Remind Me!  Send Private Message   Edit Post
Who is using one of these and where did you purchase it? I am looking for one, but don't know who makes a better one and/or where is the best place to purchase.
I have an older Frank 4 turbo, fwiw, that uses a TD06 turbine, iirc. I mention this as I don't know if these are more universal or if they have ones that are designed to fit 'x' unit.
Posts: 9748 | From: ca | Member Since: 04/23/04 | IP: (108.162.215.244) | Report this post to a Moderator
bigblock4g63
Member +
Galant VR-4 org Post #: 1154477 posted 01/05/14 06:04 PM     Remind Me!  Send Private Message   Edit Post
PTP Cover and Got it here moralesracng.com and 3 years later no problems. Alot of the PR Teams guys here us them
Here is ptp website. click
Hope this helps
Tuned by Krispeed
Control Flow Porting - books are closed - please contact Curt Brown Racing
Morales Racing
Magnus Motorsports
Posts: 308 | From: new jersey | Member Since: 02/11/09 | IP: (173.245.52.178) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 1154481 posted 01/05/14 06:41 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the link...sounds like a T3 cover will work, according to the gentlemen I spoke with there. I am running an external wastegate, fwiw, if others were looking into one not sure the same would work or not.
Edited by JNR (01/05/14 06:42 PM)
BluFalcon
Fantastic Parts Seller
Galant VR-4 org Post #: 1154485 posted 01/05/14 07:09 PM     Remind Me!  Send Private Message   Edit Post
I had a PTP blanket on my 3052 for about 6 months or so. The car was driven occasionally, probably not more than 2K miles, when I discovered the Tial Wastegate was leaking and pulled it off to repair it. In the course of pulling the wastegate off, I noticed that the turbo blanket had burned through in several spots, and a few of the lugs used as anchor points for the safety wire to secure the blanket on the housing, had completely come apart from the blanket.
I ended up pulling the remnants of the blanket off, and chucked it into a corner of the garage. It's still there, I can take pics of what's left. The car wasn't driven hard at all, and the blanket was pretty much rendered useless after a few months. Are these blankets designed mostly for a single use and need to be replaced anytime you pull the turbo?
Ed
93 Eagle Talon TSi/AWD
92 Dodge Stealth R/T TT
06 Mitsubishi Raider V8 DuroCross
521/1000
"SOLD"
Posts: 1307 | From: Wichita, KS | Member Since: 01/20/02 | IP: (173.245.52.198) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 1154498 posted 01/05/14 08:12 PM     Remind Me!  Send Private Message   Edit Post
^^ Interesting, I've been running PTP blankets on my Subaru's for 3+ years with no failures like yours.
Note however all mine are internal WG type running less than 18psi, not sure if this affects the units. Did see they have a Lava brand blanket, high(er) direct heat rating than base model.
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Posts: 3114 | From: Portland, OR | Member Since: 09/10/07 | IP: (108.162.215.184) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 1154511 posted 01/05/14 09:28 PM     Remind Me!  Send Private Message   Edit Post
I am concerned with fitment and potential condensation build-up over time, as well. I don't want to be having to remove it more than necessary if it's silica esp., but what about those times you want to clean the engine bay? I have a small steam cleaner and thinking about getting a larger unit, so perhaps this won't be an issue (pulling it off to clean).
Edited by JNR (01/05/14 09:29 PM)
BluFalcon
Galant VR-4 org Post #: 1154537 posted 01/06/14 12:49 AM     Remind Me!  Send Private Message   Edit Post
It was a PTP blanket designed specifically for the FP30 turbine housing. Not sure if it was a Lava blanket or if they offered upgraded materials.
While it was on the car, I had no complaints. It worked as advertised, and I'm sure the alternator liked not having a huge ass heat sink radiating next to it. My only bitch about the whole thing is the durability of the product.
I forgot I snapped a picture when I pulled the wastegate a few months ago:
At this point, the blanket is pretty much useless. The T/H was ceramic coated, so I just yanked the blanket off, and it seems to be fine so far. I might pick another one up if the heat becomes an issue again, or if they offer the blanket with upgraded material.
Ed
521/1000
"SOLD"
JNR
20/1000
Galant VR-4 org Post #: 1154866 posted 01/07/14 06:41 PM     Remind Me!  Send Private Message   Edit Post
Thanks for sharing your experience on that one. I would be curious to know how effective your ceramic coating works on the housing by itself? I had thought about going that route instead initially but imagine using both would be even better. At this point, was thinking about just using the blanket though.
Have a little bit of time, but not much, to make up my mind as the turbo is off right now. Fixing a thread for one of the exh. man. studs, but soon as I do I plan to get gung ho on this.
bmxr152
975/1000
Galant VR-4 org Post #: 1154883 posted 01/07/14 08:39 PM     Remind Me!  Send Private Message   Edit Post
i built my own with a turbo insulating kit. Came with enough to do some of the downpipe too. Works as good as my previous t3 blanket except this seems to be holding up better.
92 GVR4 #975-1000
90 Rs-t Gt32 powered, fully built
Posts: 231 | From: Lake tahoe, NV | Member Since: 07/31/10 | IP: (108.162.215.182) | Report this post to a Moderator
0 registered and 29 anonymous users are browsing this forum.
Generated in 0.216 seconds in which 0.19 seconds were spent on a total of 14 queries. Turbo powered.
