slowpoke
Alright guys I bought a shell and since my floor rotted out in 548/2000 I decided to bring a rust free summit white 1833/2000 back from the dead. 548 was a running and driving car I pulled the motor Friday and had the car ready to start and drive sunday. As I turned the key wouldn't start just crank for days. checked over all the basics first. I DO HAVE SPARK, MPI relay is functioning (tried 2 both known good) and I swapped 2 ecus through the car that were KNOWN good ones. im getting a good ground at the pump and im getting a 12 volt signal on the yellow/green wire and the connection.
Now im at a loss here. all my wiring SEEMS to check out as far as resistance from point to points. ecu all checks out. cam sensor is working since I have spark. I also swapped ignition switchs, added chassis grounds, YES I put gas in it. I put straight power to the power and negative on the pump and it works tried stock and walbro 255 both work when put directly to power.
Once again I am completely stumped on this car. What am I missing? I aldo had a 5 volt reference at the pump harness to. Sending unit is reading gas in the tank and the gas light came on when I had the pump out of the car. SOMEONE PLEASE HELP ME I WANNA DRIVE THIS BEAUTY!!!!
my number is 262-994-8514 if you woul dlike to contact me directly
Thanks for your time,
Joe
Joe
