12v for gauge lights(boost, egt)?
Epifool
greencastle, In
Ok, heres the 32¢ question- can somebody tell me a specific wire to tap for my add on gauge lights, and egt ? Im just tryin to avoid hackin up my underdash any more than it was when i got it. <img src="/ubbthreads/images/graemlins/confused.gif" alt="" />
ronkonkoma, ny
I know on my dsm I taped into the line for the rest of the lights so it was dim-able. Don't power the gauge off that line. Use the radio or cigaret lighter, or add another fuse to the box and run a line.
jnava
Arlington, Tx
They have new fuses that run a line out of them. I'm not sure if someone here showed them.
JamesFoster
ALL
Use the radio Accessory wire, or the main accessory wire coming from the ignition column. Either will show +12v when the key is on and in the acc position.Just test them with a test light.
KiNgMaRtY
Corona, CA
Quoting jnava:
That is very cool, I had never seen one of those before!
