Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Widest tires I can run on my Galant
rexwagon1909
impatient cutter
Galant VR-4 org Post #: 1116475 posted 04/02/13 06:00 PM     Remind Me!  Send Private Message   Edit Post
Been searching cant really get a definite answer. I have 17 inch EVO 8 wheels, and I want to run 245/45/17 Nitto Drag radials. Anyone been agble to get 245s on? I will be runnning spacers in the rear, will the fron tneed any??
Posts: 165 | From: Hurricane, WV | Member Since: 01/22/12 | IP: (162.115.108.104) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1116477 posted 04/02/13 06:02 PM     Remind Me!  Send Private Message   Edit Post
How much power are you running to need 245 wide drag radials? I'd just stick with the 235.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
rexwagon1909
impatient cutter
Galant VR-4 org Post #: 1116479 posted 04/02/13 06:07 PM     Remind Me!  Send Private Message   Edit Post
Most drag radials I can find are 245, It will an auto car so that will help slightly, probably 500plus whp thru auto.
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1116513 posted 04/02/13 09:20 PM     Remind Me!  Send Private Message   Edit Post
You won't need spacers. If anything, the rear will sit flush and you'll need to camber the front in about 2.5 degrees to tuck, possibly more with a 245. I ran 245/40r17. They're meaty. a 245/45 is going to be really tall with that bigger sidewall. I now run a 235/40 and find it's a great balance between traction and looks.
Click the link in my sig. Any pic you see with my old 5zigen wheels have 245/40's mounted to them. The BBS's have 235's.
-Mark
1051
Edited by turbowop (04/02/13 09:21 PM)
Posts: 11858 | From: Yakima, WA | Member Since: 04/29/01 | IP: (71.92.106.100) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1116514 posted 04/02/13 09:27 PM     Remind Me!  Send Private Message   Edit Post
I ran Evo 9 wheels with 245/40s on my 2 G and they fit perfect. I swapped the same setup on the Galant and not so much. I swapped to 235/40 and am much happier. 245/45 will be too tall.
I love my crazy mother!!!
Posts: 1531 | From: Manchester, NH | Member Since: 07/17/06 | IP: (70.195.3.87) | Report this post to a Moderator
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 1116521 posted 04/02/13 10:29 PM     Remind Me!  Send Private Message   Edit Post
I have 245/40/17s on EVO VIII wheels on 1101 as we speak. As Wop mentioned the rears fit perfect without spacers. The front do stick out a bit but with more camber they would fit pretty well.
On my Talon I had EVO IX wheels with 245/45/17 and they looked really big. I had coilovers on it so fitment wasn't much of an issue. When I look ay 1101 with GR2s the tires are really close to the spring mount. I doubt a 45 series tire would fit on a stock style strut.
Michael
The rebuild of 1101
Posts: 4078 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (72.201.171.210) | Report this post to a Moderator
DynastyLCD
Dissapointing Member
73/1000
881/1000
Galant VR-4 org Post #: 1116662 posted 04/03/13 06:15 PM     Remind Me!  Send Private Message   Edit Post
FWIW, I run 255s on my 1g, Evo 8 Enkeis, no fitment issues, didn't even grind the rear trailing arms.
check out vr4play's car for width limits
- Phil
'92 Galant VR4 - 881/1000 - 2.0/FPgreen daily
'92 Eagle Talon TSi - 2.3/3052/1600's/killmode.
'05 Honda TRX450r - pack-a-punched woods weapon
You call down the thunder, and i'll reap the whirlwind.
Posts: 761 | From: Harwinton, CT | Member Since: 05/12/06 | IP: (75.9.133.154) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.219 seconds in which 0.206 seconds were spent on a total of 14 queries. Turbo powered.
