Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 3 bolt lsd
3 bolt lsd
Tommyd
Galant VR-4 org Post #: 1114412 posted 03/21/13 04:45 PM     Remind Me!  Send Private Message   Edit Post
Has anyone had any luck with 3 bolt lsd/axle combos? Any big differences between the 3/4 with strength?
92 GVR4 #610 Still a work in progress
Posts: 106 | From: Fishkill, NY | Member Since: 01/18/13 | IP: (68.51.113.159) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1114414 posted 03/21/13 04:49 PM     Remind Me!  Send Private Message   Edit Post
Your new at this huh?
Very new?
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Edited by prove_it (03/21/13 04:50 PM)
Galant VR-4 org Post #: 1114449 posted 03/21/13 06:45 PM     Remind Me!  Send Private Message   Edit Post
Quoting HoosierGvr4:
Not personal experience, although I have a 3 bolt LSD in my DD, but others have commented in the past that only a 4 bolt can stand up to the loads of drag racing. But for other activities such as autocross or road racing, a 3 bolt may be sufficient.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10535 | From: Michigan | Member Since: 03/05/01 | IP: (50.45.70.13) | Report this post to a Moderator
Tommyd
Galant VR-4 org Post #: 1114460 posted 03/21/13 07:37 PM     Remind Me!  Send Private Message   Edit Post
Fairly new still to dsms, yes. I know 3 bolt rear ends suck,Im not sure whether the 3 bolt LSD and axles are any better than the open 3 bolt.
Posts: 106 | From: Fishkill, NY | Member Since: 01/18/13 | IP: (70.194.143.101) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1114467 posted 03/21/13 07:59 PM     Remind Me!  Send Private Message   Edit Post
I asked this question on tuners and was told that a 3 bolt LSD is 75% as strong as a 4 bolt...dunno if that is true or not.
I run my 3 bolt LSD with redline heavyweight shockproof (technically that has nothing to do with the LSD though). I think my rearend was in better shape without the shockproof though. Now it is noisy as heck. Maybe it had thicker fluid in there at one time from previous owner to compensate for a worn rear....who knows.
Edited by blkchr91 (03/21/13 08:05 PM)
| | | IP: (71.63.73.193) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1114472 posted 03/21/13 08:50 PM     Remind Me!  Send Private Message   Edit Post
Fairly new still to GVR4s , yes. I know 3 bolt rear ends suck,Im not sure whether the 3 bolt LSD and axles are any better than the open 3 bolt.
fixed it.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2698 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (67.183.68.117) | Report this post to a Moderator
Tommyd
Galant VR-4 org Post #: 1114477 posted 03/21/13 09:05 PM     Remind Me!  Send Private Message   Edit Post
Ha, thanks. A few years back when I had my saabaru(Saab 92x for you non subie people) I was messing around with this old awd early 90's box, which I fell in love with. After finally owning one I've come to 2 realizations. I don't know much about gvr4 drivetrain specifics, and this is probably the first of many gvr4's I'll own. I haven't been able to locate a 4 bolt rear with axles AND cups at all, but could easily get a 3 bolt LSD. Just trying to figure out what to do
Posts: 106 | From: Fishkill, NY | Member Since: 01/18/13 | IP: (70.194.136.3) | Report this post to a Moderator
Galant VR-4 org Post #: 1114483 posted 03/21/13 09:43 PM     Remind Me!  Send Private Message   Edit Post
Planned use of the vehicle?
Tommyd
Galant VR-4 org Post #: 1114491 posted 03/21/13 10:53 PM     Remind Me!  Send Private Message   Edit Post
Well, currently sitting in the garage is a built 6 bolt with a gt3071 turbo 1600cc injectors ect ect.. waiting to be dropped in. Its mostly going to be an after work/week cruising vehicle with occasional track time once or twice a month. I've been known to be fairly abusive on my vehicles so Im hesitant to run the 3 bolt set up, but I've also seen a decent amount of people get away with using them so Im trying get a consensus of how good they actually are.
donniekak
Member ++
Galant VR-4 org Post #: 1114509 posted 03/22/13 01:13 AM     Remind Me!  Send Private Message   Edit Post
I've cut lots of 1.8 60 fts with an LSD 3 bolt. I've never run lower than a 1.7 though as the passenger axle would always break.
Posts: 743 | From: surprise az | Member Since: 01/01/09 | IP: (70.190.40.227) | Report this post to a Moderator
5OF2k
Member ++
5/2000
Galant VR-4 org Post #: 1114554 posted 03/22/13 11:26 AM     Remind Me!  Send Private Message   Edit Post
3bolt rears are halfway decent, and you can get away with a fair amount of abuse on them but it's always a gamble. I've had the OEM non-lsd 3bolt in my car for over a year and lord-knows-how-many launches without issue, BUT, it is an open diff so I really dont have to worry about snapping an axle(since the wheel with the least amount of traction is ALWAYS going to spin.....and spin it does).
On a moderately modified car, under 300hp you should be fine with a 3bolt LSD, for a while. Pass that marker though, and every launch is a gamble on the life of your axles. The actual rear end isnt the weak link, it's the axles.
Honestly, based on your plans of a built motor and bigger turbo, I'd stay away from the 3bolt. Just be patient, and get a 4bolt.
-Jake
1993 Talon TSI, FPgreen DD
1957 VW Beetle Sedan Deluxe
1997 Civic EX, B18c/5lug swapped
2002 Yamaha Fz-1
Looking for another GVR4, or 5/2000...PM!
Posts: 664 | From: colorado springs, colorado | Member Since: 03/28/12 | IP: (140.32.120.188) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1114565 posted 03/22/13 12:33 PM     Remind Me!  Send Private Message   Edit Post
what was 3 bolt LSD in? I am getting old and forgetting this stuff
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Posts: 15463 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (65.127.129.246) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 1114570 posted 03/22/13 01:05 PM     Remind Me!  Send Private Message   Edit Post
^^dsm early
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (108.216.104.178) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1114623 posted 03/22/13 07:24 PM     Remind Me!  Send Private Message   Edit Post
'90 DSMs
76 Galant Coupe
94 Montero SR
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1114643 posted 03/22/13 09:33 PM     Remind Me!  Send Private Message   Edit Post
Are the spine counts and gear ratio's the same (so long as the donor is a manual)? Is the 3 bolt a direct bolt on? Aside from the AWS that is.
1992 Nile black w/sunroof
Posts: 5776 | From: Lafayette, IN | Member Since: 08/06/02 | IP: (199.27.255.204) | Report this post to a Moderator
Galant VR-4 org Post #: 1114646 posted 03/22/13 10:09 PM     Remind Me!  Send Private Message   Edit Post
Yes, same ratios if manual--> manual. Yes, bolt in if 4ws steer is gone, or else you have to swap cases.
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1114648 posted 03/22/13 10:32 PM     Remind Me!  Send Private Message   Edit Post
Yes, replaced the stock 3 bolt in 1350 for a 3 bolt LSD (AWS already removed), as iceman said, if you want to keep AWS you will have to swap pumpkins before hand.
76 Galant Coupe
94 Montero SR
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.238 seconds in which 0.204 seconds were spent on a total of 14 queries. Turbo powered.
