Galant VR-4 Forums » Galant VR-4 » Technical Discussions » FP Race manifold
FP Race manifold
Galant VR-4 org Post #: 1103051 posted 01/15/13 08:51 AM     Remind Me!  Send Private Message   Edit Post
For those that are using one, what are your real world performance observations? Any obvious improvements over an EVO III or stock manifold and any disadvantages? I know you can't fit the upper heat shield to it so I guess I would need to wrap or ceramic coat it. For anyone who has run one and then had it coated or wrapped, again any obvious improvement in performance as a result of the coating? I understand that it is better to get an unused manifold coated to avoid the risk of contaminants messing up the coating at a later date.
I would be using this on the daily driver so assume that it will be used with an EVO III 16G if that affects anything. I would probably get the O2 housing and turbine housing on the turbo ceramic coated at the same time again if that makes a difference.
Just want to know if this is a worthwhile upgrade for a street car.
Paul.
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (120.88.223.52) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1103057 posted 01/15/13 09:32 AM     Remind Me!  Send Private Message   Edit Post
I love my Fp manifold that I bought used. I cant compare it to an evo 3 manifold, but it made a difference in top end over the ported 2g manifold I was running. I haven't wrapped it, only used some high temp paint to clean it up. They are built very well and I've had no warping issues or leaks at all, after about 10k miles of daily use. Underhood temps don't raise really high. I wish I could post numbers, but don't have any. It did make a noticeable exhaust change when I installed too. I do recommend having it coated, not sure if its the paint I used, but mines starting to turn a light gray/white color. My two cents.
Oh, only disadvantage I can really think of is that the middle lower manifold to head studs are hard to get to, I wasn't able to torque one of them. Not a huge deal like I said 10k+ no leaks or warp.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Edited by prove_it (01/15/13 09:36 AM)
Galant VR-4 org Post #: 1103059 posted 01/15/13 09:37 AM     Remind Me!  Send Private Message   Edit Post
I think the 2G manifold is pretty similar to the EVO III one to be honest. Thanks for posting! No loss of power lower down the rev range then, just more top end? If so that sounds good!
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1103069 posted 01/15/13 10:28 AM     Remind Me!  Send Private Message   Edit Post
Paulie - The FP manifold is very affordable and such. But, one reason I don't like the FP manifold is the lack of ability to install a heat shield. I guess you could do the elevnteen coating from FFWD etc, but it adds to money(atleast for me). I am leaning to go with all Evo3 in the my build when it needs a new turbonium someday - Manifold/turbo/02. But, seems like FP is not selling the Evo3 16G anymore. They have some new mutant turbo out that spools even faster or something - its like 1300 bux, though!
EDIT - Also, from what I have read - a well-ported 2G performs like an evo3 manifold. As long as there are no cracks, its all good.
Anyone know if the FP manifold is lighter than the OEM manifolds? Just wondering...
1992 Galant VR-4. 205/1000. Nile Black. Sunroof.
Edited by blacksheep (01/15/13 10:30 AM)
Posts: 15454 | From: Urbandale, Iowa 50323 | Member Since: 05/01/02 | IP: (65.127.129.246) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1103071 posted 01/15/13 10:30 AM     Remind Me!  Send Private Message   Edit Post
Because FP had to sell the 16g at 1000-1300 also lol.
1990 Summit White Galant GSX
Chipped EPROM ECU/2g maf/550cc injectors/3in exhaust /E316G/FMIC/Wally255/AeromotiveAFPR/lower shores MBC
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (166.147.123.26) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1103072 posted 01/15/13 10:32 AM     Remind Me!  Send Private Message   Edit Post
^^^ Well, I just don't know who a good source for a MHI Evo3 16G is anymore, seems like ExtremePsi has them for now at 900 or something...I don't know if I should snatch one up and stash it now. Anyways, doesnt matter - sorry for going off-topic. I will stop now!
460GVR4
Galant VR-4 org Post #: 1103076 posted 01/15/13 11:05 AM     Remind Me!  Send Private Message   Edit Post
Had an extremely ported 2g manifold noticed huge difference over stock. Added my FP race manifold and didn't notice a difference and lost my heat shield. I guess it looks better?
1991 GVR4 460/2000 SOLD
1990 Eagle Talon TSi SOLD
1993 Eagle Talon TSi SOLD
Posts: 87 | From: tacoma, wa | Member Since: 01/30/12 | IP: (66.233.28.179) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1103078 posted 01/15/13 11:30 AM     Remind Me!  Send Private Message   Edit Post
Heres a wrap for the fp manifold on ebay,
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1625 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.122) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1103084 posted 01/15/13 11:51 AM     Remind Me!  Send Private Message   Edit Post
Hmm, interesting but that looks hideous, plus you have to use metal ties or something - taking it on and off will suck I feel.
JNR
5 star (English Professor) member
20/1000
Galant VR-4 org Post #: 1103086 posted 01/15/13 11:55 AM     Remind Me!  Send Private Message   Edit Post
I haven't ran mine yet, but am impressed with it, except it does and can use some work still as far as porting (matching) and polishing, etc...I mean, it'll *work*, but if you're into the details and want everything 100%, then I'd prepare to do that...Still better than an EVOIII, etc. as-is, but just saying...That and get a good coating on it.
Posts: 9738 | From: ca | Member Since: 04/23/04 | IP: (108.66.96.30) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1103090 posted 01/15/13 12:15 PM     Remind Me!  Send Private Message   Edit Post
Quoting blacksheep:
i guess when ever you do take it off you can just cut the metal ties and get new ones, it dont look that bad lol, better then rusted or uncoated manifolds.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
James
Does lots of head
Galant VR-4 org Post #: 1103098 posted 01/15/13 01:24 PM     Remind Me!  Send Private Message   Edit Post
Wonder why FP... Or anyone for that matter.. Doesn't start fabbing up some shields. Seems like a fairly simple job for someone in that business. And they are always wanted by people with FP manifolds. FP could run a special where you buy both at the same time and get it a little cheaper.
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (166.147.123.15) | Report this post to a Moderator
RayH
561/1000
Galant VR-4 org Post #: 1103100 posted 01/15/13 01:34 PM     Remind Me!  Send Private Message   Edit Post
I found from owning the Mini that there's a company making insulating blankets from Aerogel and from there found that you can get samples of the raw material relatively cheaply. Might be worth experimenting with.
Pyrogel XT
Posts: 2697 | From: NJ | Member Since: 04/09/01 | IP: (68.198.243.102) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 1103102 posted 01/15/13 01:35 PM     Remind Me!  Send Private Message   Edit Post
Somebody made a SS unit, but IMO looked like crap...I think these look best not covered up (eg coated), as they are nice looking units. Besides, just slapping on a piece of SS doesn't do much for the heat retention you want for a turbo, although suppose it helps a little with keeping the engine bay slightly cooler right above it, but the heat has to go somewhere; it doesn't just disappear of course...maybe putting some alum. foil on top (this does work), some insulation, then a shield could work, but again, it just doesn't look as nice as the manifold being exposed, IMO.
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1103107 posted 01/15/13 01:44 PM     Remind Me!  Send Private Message   Edit Post
Your right the manifold does look sweet without any blanket or shield on it, but i would still get a blanket like the one on ebay. The heat thats not all over the engine bay would actually help the turbo spool more effitiently.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
JNR
20/1000
Galant VR-4 org Post #: 1103111 posted 01/15/13 01:54 PM     Remind Me!  Send Private Message   Edit Post
definitely functional, although if it's not coated, I'd worry about any condensation on the surface with corrosion (rust), but doubt it's be enough to be of concern.
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1103117 posted 01/15/13 02:02 PM     Remind Me!  Send Private Message   Edit Post
oh yeah, some VHT paint coating is a must.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
boostin4door
870/1000
Galant VR-4 org Post #: 1103763 posted 01/18/13 11:01 PM     Remind Me!  Send Private Message   Edit Post
I ran a FP when they first came out on the group buy[w/my HX35]. Very good product. Car ran great w/it compared to my 2g. had it ceramic coated and it held up well.
Posts: 150 | From: Chicago, Il. | Member Since: 10/07/06 | IP: (108.70.88.67) | Report this post to a Moderator
thecman02
too lazy to look
580/1000
Galant VR-4 org Post #: 1104112 posted 01/21/13 05:34 PM     Remind Me!  Send Private Message   Edit Post
I've had once since 08. It finally cracked a little on the very front in the collector area. As far as spool it was 50-100rpm quicker then the unported 2g manifold that was on the car when i bought it. I would say its very durable since it has been daily driven in Michigan for 40k miles. I had a local ceramic coater put a "high temp 2000*F" coating on it when I got it brand new. That flaked off within a couple weeks which was a huge disappointment. If you were going to get a coating I'd do a swaintech white lightining coat. A friend of mine got his done and its held up flawlessly for many years. He even painted it with some black grill paint so it looked more appealing. That coating is awesome. I was planning on picking up that manifold blanket, but I'm switching to a tubular t4ts setup this spring and didn't feel like dropping anymore money into this setup. The temps can get quite nasty with no heat shield and would recommend that blanket or a good coating before running.
580/1000
2013 Max Effort Winner
-Chris
Posts: 911 | From: Kalamazoo,MI | Member Since: 11/03/07 | IP: (69.128.217.6) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1104254 posted 01/22/13 01:27 PM     Remind Me!  Send Private Message   Edit Post
That's where hood vents would help out a bunch. I love my bare manifold in the winter, helps to get it up to running temp quickly...
12yr+ Vr4 owner.
Family Guy
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 1104293 posted 01/22/13 04:47 PM     Remind Me!  Send Private Message   Edit Post
Don't forget that objects near an uncovered manifold will experience a large amount of heat flux due to radiative heat transfer. So even though an object doesn't get much hot air from the manifold, it can get baked.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (198.232.211.130) | Report this post to a Moderator
jnava Galant VR4.org Moderator
57/2000
Galant VR-4 org Post #: 1104711 posted 01/24/13 08:25 AM     Remind Me!  Send Private Message   Edit Post
Recently purchased an FP manifold and Amber from FP said to get rid of the wrap that was on the manifold. She said that the wraps will help increase the likelihood of crack on the manifold. She also said that the best option is to use a blanket or modify the stock shield to cover it.
Posts: 2031 | From: Arlington, Tx | Member Since: 04/18/08 | IP: (76.184.18.252) | Report this post to a Moderator
blacksheep
Baraqsheep
205/1000
Galant VR-4 org Post #: 1104733 posted 01/24/13 10:24 AM     Remind Me!  Send Private Message   Edit Post
Would welding bungs on the manifold be easy to allow for bolts for a custom heatshield? It is cast, so I don't know how easy it would be? Also, would it hurt the integrity of the manifold?
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1104841 posted 01/24/13 11:54 PM     Remind Me!  Send Private Message   Edit Post
brianawd went from a ported Mitsu manifold (can't remember which one) to a tubular DNP and noticed a big difference. Zach, who used to work at English dynod his FP and swapped it out for a tubular DNP, hoping it would make better numbers (this was on a 450awhp/500+awtq 16g DSM), the numbers were very close, enough to say that the changing condition attributed to the different numbers, it was within a few horsepower.
The FP holds heat very well, and thus sending hotter exhaust through the turbine which makes a big difference (another example of this is with retarded timing, the turbo spools faster). The tubular manifolds have longer and more equal length runners which work better for our application, but they dissipate heat too quickly and the gas cools off more so than the cast manifolds.
It ultimately ends up being a wash, but with the durability of the the cast manifold, it is enough reason to stick with a cast manifold until I'm ready for a T3 or T4 setup.
I have ~35k miles on my FP manifold and have not had a single issue with it. No rust, no cracks, although the discoloration is less than desirable.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (67.171.235.101) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1104888 posted 01/25/13 01:39 PM     Remind Me!  Send Private Message   Edit Post
You "can" weld to it without hurting the manifold. I'd be more worried about the welds cracking though. I've seen some wastegate flanges welded to cast manifolds, and they've all shown cracks within a fairly short period of time.
I'd think a viable option for a heatshield would be something that uses the existing manifold to head studs. The two outer ones on the top should be able to hold a heat shield okay. I bought my coated FP GT30r bolt on turbine housing "used". For some reason, the PO had welded a little stud to the center of the forward facing part of the flange. It may have been for a turbo blanket, or some sort of heat shield. I don't really see that as a high expansion area, and a 3rd mounting point could be utilized there without substantial fear of cracking taking place on the weld. I'd think using those 3 mounting points, one should be able to come up with a halfway decent heat shield.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3511 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.94.21) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 46 anonymous users are browsing this forum.
Generated in 0.241 seconds in which 0.183 seconds were spent on a total of 15 queries. Turbo powered.
