transmission and mount bracket questions
Kentstatetsi
Active member
Savannah, Ga.
doing a trans swap because it was popping out of 1st and 4th. I have 4 extras so no big deal on that. The mount bracket I was using was stamped 22-H. I found a bracket stamped 210H in my garage that is slightly different but both mount to 1g transmissions. Which one is correct? I've searched the factory part #md731017 with no luck on finding a picture of the stamped part.
All 4 of my spares are NPXV's but 1 has a different center case on it where the mount bracket goes. I was guessing its from an early 2g but it doesn't have the counterweight on the shift levers.
ronkonkoma, ny
Total necro on this post but could somone confirm this bracket number please.
89Mirageman
Stantonsburg, NC
22-H AWD, 210-H FWD turbo dsm. I use the 210-H mounts as cores for the csm's so if you want to part with it shoot me a pm.
ronkonkoma, ny
My 1g fwd manual has a 200h bracket.
The 22h I have is from an awd manual 1g
22h is from a vr4 as well?
89Mirageman
Stantonsburg, NC
Is your 1g fwd a turbo car? Every 1g fwd turbo dsm I've ever seen with a manual trans had a 210-H mount. 200-H is new to me. Pretty sure the 22-H is for a GVR4 too although I'm not positive.
89Mirageman
Stantonsburg, NC
Oh OK, they are flat across the bottom where they bolt to the trans. Not stepped. That's why they use a different mount.
