Joseph Reinacher's 1991 Galant VR4
Jon
Franklin, TN, USA
Owner: Joseph Reinacher
Message Board Name:dsmsleeper
Year: 1991
Number: 782/2000
Performance mods:
[*]Ported 16G Turbo
[*]Balanced motor with
   - JE Pistons 8.5:1 compression
   - block bored 30 over
   - swirl polished stainless steel valves (1mm larger)
   - balance shafts removed
[*]Mild porting of head
[*]ARP head studs
[*]Unorthodox Underdrive pulley
[*]K&N cone filter
[*]Al Blaha modified MAS
[*]Raptor Racing intake
[*]2 1/4" lower IC pipe
[*]Spearco FMIC
[*]2 1/4" upper IC pipe
[*]GReddy Type-S BOV
[*]HKS TB elbow
[*]overbored TB
[*]3" HRC O2 eliminator downpipe
[*]3" Catco high flow cat
[*]3" RS*R muffler
[*]Magnecor 8.5 wires
[*]BPR7ES NGK plugs
[*]RRE Stainless Steel turbo oil feed line
[*]Apex-i AFC
[*]Evo IV 510cc injectors
[*]B&M fuel pressure gauge
[*]Charged Air AFPR
[*]HKS EVC IV
[*]Blitz FATT
[*]A/C removed
Driveline mods:
[*]New GVR-4 tranny w/ dual syncros
[*]JUN lightweight flywheel
[*]CFDF ball bearing clutch
[*]Mofugas braided clutch line
[*]Custom billet spacers for shifter
[*]Front dimple drilled and slotted rotors with Axxis Metal Master pads
[*]Rear cross-drilled rotors
[*]Stainless steel brake lines
Suspension mods:
[*]GAB coilovers, w/ Eibach springs
[*]Bartec rear strutbar
[*]Cusco/Greddy front strut bar
Exterior/Interior mods:
[*]HKS white-faced boost gauge
[*]Greddy 60mm Peak/Warning EGT
[*]Extreme A/F gauge
[*]GReddy peak/hold white-faced EGT
[*]MOMO Champion Wheel
[*]Razo carbon fiber pedals
[*]Razo dead pedal
[*]cabon fiber interior panels
[*]1g T/E/L shifter w/ custom leather boot
[*]Trunk-mounted Optima battery
[*]Xenon lights
[*]JDM spec corner lights
[*]JDM headlights (with city lights)
