Galant VR-4 Forums » Galant VR-4 » Newbies » #996/1000
#996/1000
unistylef
996/1000
Galant VR-4 org Post #: 1077704 posted 07/25/12 07:52 PM     Remind Me!  Send Private Message   Edit Post
Hello all! I'm quite pleased with my new-to-me 92 Belize Green.
No pics yet, but its in great condition.
Just wanted to say, I understand this is a community. Every member of a community should have something to contrib, so I will state that I am a confident photographer, graphic designer, and webmaster. So, if you need anything, let me know. I'll see what I can accomplish.
[P1=POWER][P2=HANDLING][P3=APPEARANCE][P4=REGULATION COMPLIANCE][P5=REBUILD]
[V=VARIABLE][P=PENDING][T=TRIAL][IP=IN PROGRESS]
CURRENT
STAGE 1: FOCUS: [P1/P5]
#_____| 996/ 1000
TRIM__| 1992 BELIZE GREEN A87
NAME__| [T] KAPPA 996 SSS (Super Street Sedan)
GOAL__| USTREET/ AUTOX/ Track, Higher Powerband, Responsive
COMMON| 30-65MPH, 90-115MPH
POWER_| EXPECTED 350-400AWHP
TURBO_| EVO3 16G @ [V] 20-21PSI+
MOTOR_| 4G63, 272 CAMS
FUEL__| (San Diego: 91 OCT) 550CC
SUSP__| [T] F: EVO8 KYB R: EVO8 BILSTEIN, SWIFT SPRINGS
TIRES_| [V/P] 225/40/R17 SUMMER PERFORMANCE
UPCOMING 2014/2015
STAGE 2: FOCUS: [P2/P3/P4]
FUEL | (SAN DIEGO: 91 OCT) / [P] E85
SUSP | [P2] F/R SWAY BAR
LSD | [P2] QUAIFE
TRANSM| [P5] EVO3 1ST/5TH GEAR
REAR | [P5] 4 BOLT
PAINT | [P/P3] Either: Brit Racing Green or BMW Forest Green, REMAIN DEBADGED
SAFETY| [P4] TUNING SPEC SEATS, 4PT HARNESS, 6pt WELD-IN ROLLCAGE, Fire Extinguisher
UPDATED DETAILED PARTS LIST:
ENGINE
    MLS HEAD GASKET
    ARP HEAD BOLTS
    NGK -7 PLUGS @.022 GAP, NGK SPARK WIRES
    272/272 CAMS (REGRINDS)
    ALUMINUM HALFMOON GASKET
    FACTORY OIL FILTER W/ SHELL ROTELLA 15W-40
EXHAUST
    EVO 3 MANIFOLD - CERAMIC COATED, PORTED,
    ARP TURBO BOLTS
    FULL 3" TURBO BACK: STAINLESS STEEL, MANDREL BENT
    3" DOWNPIPE - PAINTED & HEAT WRAPPED
    3" MAGNAFLOW CAT
    3" MAGNAFLOW MUFFLER: SINGLE TIP
FUEL
    WALBRO 255 LPH
    AFPR @ 37PSI
    EVO 8 INJECTORS 560CC (CURRENT)
    860CC (LATER FOR 22+ PSI)
AIR
    ETS FMIC (24 x 10 x 3 Bar and Plate core)
    2.5 IC PIPING
    2G MAF
    2G INJEN INTAKE
    MANUAL BOOST CONTROLLER
TURBO
    19-20PSI
    MHI EVO 3 16G: CERAMIC COATED, PORTED
    O2 SENSOR: CERAMIC COATED
DRIVETRAIN
    ALUMINUM FLYWHEEL
    METAL SHIFTER BASE BUSHINGS
    BASE BUSHINGS
    JNZ DRIVESHAFT REBUILD KIT
    ACT 2600 CLUTCH
    CUSTOM 1G SHORT SHIFTER
    TRANSMISSION: LUCAS FULL SYNTHETIC 75-90 W/ LUCAS OIL STABILIZER
    SOLID TRANNY BUSHINGS
    STAINLESS CLUTCH LINE
SUSPENSION
    EVO 8 SWIFT LOWERING SPRINGS
    FRONT: STRUT BAR, EVO 8 AGX STRUTS
    REAR: STRUT BAR, EVO 8 BILSTEIN STRUTS
    NEW BALL JOINTS
WHEELS
    5 LUG SWAP: NEW WHEEL BEARINGS & SEALS
    EVO9 ENKEI RIMS: 17"X8" 35MM OFFSET
    DUNLOP DIREZZA SUMMER PERFORMANCE: 225/40/17
BRAKES
    JNZ ABS DELETE KIT W/ PROP VALVE
    SS BRAKE LINES
    FRONT: 3000GT ROTORS 313MM, 3000GT CALIPERS 4-PISTON FIXED
    REAR: 1G STANDARD
ELECTRONICS
    REBUILT ECU
    ECM V3
    VDO BOOST GAUGE
OTHER
    '89 GSX GRILL
    '89 UNDERDASH
    DSM 1G STEERING WHEEL
    JDM HEADLIGHTS: 6k HID
    Mint Fogs: Yellow HID
    LED Bulbs throughout
    BATTERY RELOCATION: FOR 2G INTAKE
Edited by unistylef (01/17/14 08:56 AM)
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (138.162.0.41) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1077757 posted 07/26/12 08:45 AM     Remind Me!  Send Private Message   Edit Post
Haha I bet your the only one in Maine with a Galant VR4, welcome aboard man. Read this click and this click
JZX90 Toyota Mark II Tourer V Twin Turbskie "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara" 550<
Posts: 3701 | From: Houston, Texas | Member Since: 04/07/11 | IP:
(208.54.40.158) | Report this post to a Moderator
matt92vr4
Member ++
474/1000
Galant VR-4 org Post #: 1077760 posted 07/26/12 08:58 AM     Remind Me!  Send Private Message   Edit Post
Congrats on the new car and welcome!
474/1000 Summit White
1993 Stealth RT/TT
1995 Montero SR
1998 Montero
Posts: 676 | From: Venice, FL | Member Since: 10/03/10 | IP: (68.34.158.83) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1083497 posted 08/31/12 09:29 PM     Remind Me!  Send Private Message   Edit Post
Decided to post a picture of my car. New chrome grill from broken_down. A new valve cover is at the powdercoat shop; gonna have it wrinkle red with shaved lettering. Hope to have the driveshaft rebuilt next week. Still have squeaky suspension...
996/1000 A87 VR-4 Belize Green
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (63.160.236.174) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1083501 posted 08/31/12 10:18 PM     Remind Me!  Send Private Message   Edit Post
Only one picture huh? Don't show it off too much
-Craig
1501 Build Thread
Posts: 1755 | From: O-H-I-O | Member Since: 11/24/11 | IP: (151.213.205.53) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1127080 posted 06/06/13 07:34 PM     Remind Me!  Send Private Message   Edit Post
Okay, so a huge amount of things have been happening with this thing lately...
Check out this vid to hear it's first startup after cams and other exhaust elements installed.
More details once I get it looking respectable.
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (138.162.0.44) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1132386 posted 07/14/13 04:48 PM     Remind Me!  Send Private Message   Edit Post
Decide to be less reclusive and post a couple update shots. Rarely driven the past 6-9 months. Photos were touched up a lil. The car has a bunch of dings, blemishes, scuffs, and peels... but it has promises & aspirations for new paint and more custom work next year.
Displaying the beautiful 3" Stainless Steel, mandrel bent exhaust mated with a Magnaflow muffler hanging solid.
Showcasing 12.5" rotors and 3KGT Calipers on a 5 Lug swap. Rims will soon be changed out.
An above/ 45 degree shot of the car flaunting JDM headlights and a plastidipped 89 Grill. Also missing a cladding.
Underneath, the Evo 8 Bilstein struts are mated with Swift lowering springs.
Underneath, its not too shabby. You can see the car's catless setup in the distance.
The engine bay. Not glamourous, but thought out. Ceramic coating, powdercoating, porting, all wherever feasible.
Closer look, underneath is an EVO 3 16G attached to an EVO 3 exhaust manifold.
An ETS FMIC lurks behind the uncut bumper.
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (67.189.238.51) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1132443 posted 07/14/13 09:52 PM     Remind Me!  Send Private Message   Edit Post
Decided my car needed a personality when it starts taking on its new form. I like to consider this thing a monster, a green monster. I did some research and found the Kappa. It's a scaly humanoid salamander with a beak that is typically green. They are mischievous, but can be tricked into helping people. More Here
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1132469 posted 07/15/13 12:36 AM     Remind Me!  Send Private Message   Edit Post
Wow Car is looking great man! might wanna do something about that manifold heating up that pipe.
(208.54.83.203) | Report this post to a Moderator
DynastyLCD
Dissapointing Member
73/1000
881/1000
Galant VR-4 org Post #: 1132500 posted 07/15/13 11:17 AM     Remind Me!  Send Private Message   Edit Post
Good work, Brian! This car is really starting to take shape!
- Phil
'92 Galant VR4 - 881/1000 - 2.0/FPgreen daily
'92 Eagle Talon TSi - 2.3/3052/1600's/killmode.
'05 Honda TRX450r - pack-a-punched woods weapon
You call down the thunder, and i'll reap the whirlwind.
Posts: 761 | From: Harwinton, CT | Member Since: 05/12/06 | IP: (50.199.213.225) | Report this post to a Moderator
desant78
Member ++
1662/2000
995/1000
Galant VR-4 org Post #: 1132509 posted 07/15/13 12:36 PM     Remind Me!  Send Private Message   Edit Post
Dude I DD #995/1000! Just wanted to let you know lol and the car looks great man!
i wanna go fast.
Posts: 728 | From: Sewell, NJ | Member Since: 06/23/10 | IP: (138.162.8.57) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1132627 posted 07/15/13 11:11 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSX_TC:
You really think this is an issue? What is your recommendation? Ceramic the J Pipe?
EHmotorsports
Capt Fabbin Stabbin
1865/2000
Galant VR-4 org Post #: 1132659 posted 07/16/13 09:53 AM     Remind Me!  Send Private Message   Edit Post
Dei makes a reflective wrap that works pretty good.
Posts: 1272 | From: Beaverton | Member Since: 09/26/12 | IP: (50.120.49.142) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1135085 posted 08/04/13 04:25 PM     Remind Me!  Send Private Message   Edit Post
Just a couple images displaying new tires and Evo9 rims.
A big shoutout for CutlassJim (James Rushing) for making (Stage 1) of my plan happen! This guy is an expert mechanic and professional at best.
More later.
youtube video: click
Edited by unistylef (08/04/13 04:27 PM)
Nate
May I have your autograph?
Galant VR-4 org Post #: 1135092 posted 08/04/13 05:49 PM     Remind Me!  Send Private Message   Edit Post
I'm pretty sure I drove that car when it was still new at the dealership. Either that or 997. . Looks nice!
Posts: 944 | From: Worcester, Pa | Member Since: 02/23/01 | IP: (71.230.252.142) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1135333 posted 08/06/13 06:56 PM     Remind Me!  Send Private Message   Edit Post
Quoting unistylef:
Quoting GSX_TC:
I'm sure coating the pipes wouldn't hurt anything. I'd probably just get the factory manifold heatshield, since it'll bolt right onto the manifold you've got and they really do work. If you've got a factory-ish o2 housing, I'd run that one too unless alternator swaps and trips to autozone are fun for you.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3629 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (67.168.182.28) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1135501 posted 08/07/13 07:19 PM     Remind Me!  Send Private Message   Edit Post
Heres a couple badges I made to give the interior a little more character.
this nameplate will be placed behind the shifter on the console
this is the kappa. not sure where to put it yet
unistylef
996/1000
Galant VR-4 org Post #: 1147988 posted 11/09/13 11:30 PM     Remind Me!  Send Private Message   Edit Post
Hey everyone! Its been a long journey, but I am no longer in New Hampshire and now in San Diego. I cant wait to work out the kinks and start meeting people in this region!
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (173.245.48.153) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1147992 posted 11/10/13 12:10 AM     Remind Me!  Send Private Message   Edit Post
Good looking car.
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2302 | From: USA | Member Since: 01/07/12 | IP: (141.101.99.183) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1148046 posted 11/10/13 05:39 PM     Remind Me!  Send Private Message   Edit Post
What branch of the military are you in?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3346 | From: SoCal | Member Since: 01/02/12 | IP:
(173.245.54.167) | Report this post to a Moderator
Srr
Newbie
Galant VR-4 org Post #: 1148047 posted 11/10/13 05:45 PM     Remind Me!  Send Private Message   Edit Post
nice vr4 man... love that grill
Posts: 5 | From: Ct | Member Since: 01/29/13 | IP: (108.162.219.198) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1148053 posted 11/10/13 06:42 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
Navy Submarines! Cant wait to autox here in SD.
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (108.162.215.71) | Report this post to a Moderator
unistylef
996/1000
Galant VR-4 org Post #: 1148274 posted 11/12/13 02:38 PM     Remind Me!  Send Private Message   Edit Post
Damn. 91 octane? Really?
Posts: 167 | From: San Diego, CA | Member Since: 06/25/12 | IP: (108.162.215.224) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1148317 posted 11/12/13 07:08 PM     Remind Me!  Send Private Message   Edit Post
Lolz. Welcome to California. That's just the beginning, wait until you have to pass smog with your car. Get ready to shell out a hefty bribe. That's is, if you are lucky enough to find a tech who will hook you up.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(173.245.56.130) | Report this post to a Moderator
BpuVR4
Rolled by Accord while sauced
Galant VR-4 org Post #: 1148329 posted 11/12/13 08:25 PM     Remind Me!  Send Private Message   Edit Post
damn is that seriously what the New Hampshire plates say? "Live free or die"...pretty cool.
06 V70 2.5T/96 850 Turbo
formerly: 372/2k, 555/2k, 957/1k
Posts: 805 | From: Chicago | Member Since: 07/11/05 | IP: (173.245.55.171) | Report this post to a Moderator
Pages: 1 | 2 | 3
Generated in 0.25 seconds in which 0.204 seconds were spent on a total of 15 queries. Turbo powered.
