Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Pressure plate question
thedsmguy
Galant VR-4 org Post #: 1074621 posted 07/06/12 10:41 AM     Remind Me!  Send Private Message   Edit Post
I have a couple plates that i took to a shop to have resurfaced. Both had a bevel on friction surface that was lower in the middle. Is this how a clutch comes? Does it "flatten" out when being used? And if so is it even possible to resurface such a thing? Right now it seems it would wear a disk in a weird way but the disk pulled seemed pretty flat still.
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (166.216.130.68) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1074624 posted 07/06/12 10:55 AM     Remind Me!  Send Private Message   Edit Post
Naw man, you should be able to put a straight edge across the surface and it should be dead flat.
Instead of having mine resurfaced, to keep the clutch geometry better in spec, i took a new (cheap) pressure plate in with my old 2600 that had cracks in the friction surface, and had them put the new friction plate on it. Worked great for a few years.
97 CBR900RR
2012 Hyundai Veloster
Edited by mitsuturbo (07/06/12 10:59 AM)
Posts: 3527 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.54.255.35) | Report this post to a Moderator
thedsmguy
Galant VR-4 org Post #: 1074652 posted 07/06/12 01:37 PM     Remind Me!  Send Private Message   Edit Post
Great idea
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (166.216.130.44) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1074663 posted 07/06/12 02:18 PM     Remind Me!  Send Private Message   Edit Post
what are the negative effects of the PP being high on the outside and low on the inside? because once the throw-out bearing presses the teeth on the PP won't that make the friction surface completely flat once again? i have no idea on this subject and would like to know so i can be more knowledgeable.
138/2000
Posts: 3499 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (68.198.227.171) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1074671 posted 07/06/12 02:29 PM     Remind Me!  Send Private Message   Edit Post
The friction surface is cast iron, if i'm not mistaken. That shit's not going to flex. It's going to wear out the the friction disc unevenly.
97 CBR900RR
JNR
20/1000
Galant VR-4 org Post #: 1074689 posted 07/06/12 04:52 PM     Remind Me!  Send Private Message   Edit Post
Don't underestimate heat and is effect on materials!
Posts: 9747 | From: ca | Member Since: 04/23/04 | IP: (108.66.96.30) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1074828 posted 07/07/12 05:18 PM     Remind Me!  Send Private Message   Edit Post
Quoting transparentdsm:
If the plate is dished (warped), it will not clamp the friction disc properly, t won't be making full contact with the friction disc. This happened with my twin disc. If with the twin, I was blowing through the clutch right around peak torque, 450ftlbs or so.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (67.171.235.101) | Report this post to a Moderator
0 registered and 31 anonymous users are browsing this forum.
Generated in 0.201 seconds in which 0.184 seconds were spent on a total of 14 queries. Turbo powered.
