Galant VR-4 Forums » Galant VR-4 » Newbies » pull engine with or without tranny?
yeti
Nope still sticky fingers
Galant VR-4 org Post #: 1069568 posted 06/01/12 02:52 AM     Remind Me!  Send Private Message   Edit Post
Going to be pulling motor tommarow, just wondering whats more common.
~turbohair~
Posts: 716 | From: san diego california | Member Since: 10/13/10 | IP: (68.107.90.229) | Report this post to a Moderator
5OF2k
Member ++
5/2000
Galant VR-4 org Post #: 1069631 posted 06/01/12 03:29 PM     Remind Me!  Send Private Message   Edit Post
with. Still dont have a service manual, do you?
1993 Talon TSI, FPgreen DD
1957 VW Beetle Sedan Deluxe
1997 Civic EX, B18c/5lug swapped
2002 Yamaha Fz-1
Looking for another GVR4, or 5/2000...PM!
Posts: 664 | From: colorado springs, colorado | Member Since: 03/28/12 | IP: (140.32.120.188) | Report this post to a Moderator
DR1665
Kill him in the face with Wilson Phillips
Galant VR-4 org Post #: 1069635 posted 06/01/12 03:46 PM     Remind Me!  Send Private Message   Edit Post
Pull engine WITH tranny. Stabbing the trans is a PITA, but I have to think it's much easier when you don't have to get everything lined up mid-air.
And everyone here has a FSM. It's hosted under the Library link at the top of every page.
Brian | 98 Pajero | Gearbox Magazine
Posts: 4631 | From: Phoenix, AZ | Member Since: 10/19/05 | IP: (204.17.31.126) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1069638 posted 06/01/12 03:51 PM     Remind Me!  Send Private Message   Edit Post
I've always dropped the transmission out the bottom, and pulled the engine out the top. Installation has been reverse of removal.
It's just easier for me to get the mounts and such lined up (and not snag on anything) when there's less to deal with at once.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3526 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.54.255.35) | Report this post to a Moderator
5OF2k
Member ++
5/2000
Galant VR-4 org Post #: 1069640 posted 06/01/12 03:52 PM     Remind Me!  Send Private Message   Edit Post
^I've never done it like that, I've always dropped both right out of the bottom.... Then again, I have lifts and all of the other tools to make that my easiest option. I'd still tend to think taking it out together would be the best bet..... I dunno, call me crazy...
-Jake
2002 Yamaha Fz-1
yeti
Galant VR-4 org Post #: 1069653 posted 06/01/12 04:23 PM     Remind Me!  Send Private Message   Edit Post
^HAH i wish..
I will be pulling together since it took me two days to get the tranny back on under my camaro(only about a foot and a half of the ground, if that)
And i have the part in the manual for the engine in print but rest is online
Also how should i tie the engine up,intake and exhaust?
~turbohair~
Edited by yeti (06/01/12 04:26 PM)
Posts: 716 | From: san diego california | Member Since: 10/13/10 | IP: (208.54.39.214) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1069666 posted 06/01/12 04:56 PM     Remind Me!  Send Private Message   Edit Post
Quoting 5OF2k:
-Jake
This is the only way to go if you have a lift available, and is how i've done every car when i worked as a tech at various different places (including the mitsu dealership).
97 CBR900RR
Banthony
555/1000
Galant VR-4 org Post #: 1069669 posted 06/01/12 05:02 PM     Remind Me!  Send Private Message   Edit Post
Quoting yeti:
^HAH i wish..
What do you mean "tie the engine up" ?
There are standard lift points on the engine for removing the entire assembly. If you're lacking the one on the exhaust manifold, or do not wish to use it, it's common practice to use the bolts on the large L bracket engine mount as a lift point (above the PS pump). Just bolt down one end of the chain there, and the other end to the bracket between the head and throttle body/intake mani.
In my experience, if you're going to tear the whole engine down, it's easiest to just take the head and manifolds off together, first thing, while it's still all bolted into the vehicle. That way you can just use old head bolts to lift the assembly out.
97 CBR900RR
yeti
Galant VR-4 org Post #: 1069745 posted 06/02/12 02:09 AM     Remind Me!  Send Private Message   Edit Post
Now thats another thought.
Everything is done, only thing left are mounts i will take the head off then pull the engine.
~turbohair~
yeti
Galant VR-4 org Post #: 1069750 posted 06/02/12 02:22 AM     Remind Me!  Send Private Message   Edit Post
Was just thinking about it i was planning on holding cam sprockets and breaking crank/oil pump sprocket off..
So kinda dont know if i should take head off.
Is that my best bet on breaking those free,or would there be another way with the head off.
And my plan is to pull this motor and build the fresh rotating assembly/fresh head (but have to assemble the valvetrain first) then drop that back in the car ALL TOMARROW...wish me luck
~turbohair~
Edited by yeti (06/02/12 02:30 AM)
HHIVR4
Aluminum Lung
1280/2000
138/2000
Galant VR-4 org Post #: 1069918 posted 06/03/12 02:14 PM     Remind Me!  Send Private Message   Edit Post
You can do either way..With trans attached youll have to angle the trans lower than the engine for clearance.If your take the trans off its a straight up simple drop in..Then you can do a Polish spec trans install which takes 5 minutes.
Posts: 5446 | From: Hilton Head Island SC | Member Since: 10/06/03 | IP: (67.20.144.81) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1070134 posted 06/04/12 02:58 PM     Remind Me!  Send Private Message   Edit Post
Quoting yeti:
I just use an impact gun. I've done it without one, and it's kind of a PITA. I put something in between the crank counterweights and the block, then use a breaker bar to get flywheel and pulley bolts loose.
97 CBR900RR
yeti
Galant VR-4 org Post #: 1070301 posted 06/05/12 02:54 PM     Remind Me!  Send Private Message   Edit Post
Whats polish spec?
And i busted it free using the vents in my flywheel...
~turbohair~
Posts: 716 | From: san diego california | Member Since: 10/13/10 | IP: (68.7.134.213) | Report this post to a Moderator
Vr4junkie
writes like a tard
385/2000
Galant VR-4 org Post #: 1070311 posted 06/05/12 04:07 PM     Remind Me!  Send Private Message   Edit Post
Quoting mitsuturbo:
Quoting yeti:
So kinda dont know if I should take head off.
Yea used to have the same problem its kind of a pain without a impact gun you should invest in one of theses there like 30 to 40 bucks at harbor and work great I break fly wheel bolts,crank pulley bolts with out a problem
385/2000 click
Posts: 596 | From: Some wack town in CA | Member Since: 06/25/11 | IP: (75.54.130.45) | Report this post to a Moderator
2 registered and 19 anonymous users are browsing this forum.
Generated in 0.226 seconds in which 0.195 seconds were spent on a total of 14 queries. Turbo powered.
