Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » What a good short shifter?
Nabeel
Member +
Galant VR-4 org Post #: 1061790 posted 04/11/12 01:20 PM     Remind Me!  Send Private Message   Edit Post
What a good short shifter? there are some on ebay. JZN little expensive. Any idea where to look for a good one?
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (77.30.174.34) | Report this post to a Moderator
Prolab
Galant VR-4 org Post #: 1061792 posted 04/11/12 01:25 PM     Remind Me!  Send Private Message   Edit Post
I just use the 91+ 1G shifter/base. I ran one with my 92 GS with no ill effects and currently have one on my 91 GSX.
Edited by Prolab (04/11/12 01:26 PM)
| | | IP: (173.32.97.124) | Report this post to a Moderator
asmo
1605/2000
Galant VR-4 org Post #: 1061796 posted 04/11/12 01:31 PM     Remind Me!  Send Private Message   Edit Post
yup what he said the 1g ones about 2.5 inches shorter. I love mine.
EVO VIII black daily
Black #1605/2000 sold
White #1807/2000 sold/missed
Posts: 87 | From: SLC, Ut | Member Since: 06/28/09 | IP: (68.178.13.126) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1061802 posted 04/11/12 02:25 PM     Remind Me!  Send Private Message   Edit Post
I feel like I am driving a truck. The stock shifter is long. But is the 1g shifter will help shifting faster? Or it is same if I just shortened the gvr4 one?
91 VR4
09 GT eclipse
91 Cefiro
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 1061804 posted 04/11/12 02:42 PM     Remind Me!  Send Private Message   Edit Post
it's just shortened height, the shift throw is the same. That's why some aftermarket ones are pricey, they are modified to be truly shorter throw.
I like a 1G shifter myself
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
GVR47111K
slurpees, hot dogs and pickled eggs are still offered
711/1000
Galant VR-4 org Post #: 1061818 posted 04/11/12 04:54 PM     Remind Me!  Send Private Message   Edit Post
1g
-Will V.
'92 #711/1000 KG
If it works, you learn something. If it breaks, you learn even more.
Posts: 457 | From: 80022, CO | Member Since: 11/07/11 | IP: (66.110.182.2) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1061819 posted 04/11/12 05:02 PM     Remind Me!  Send Private Message   Edit Post
I have a 1g and shift boot available if you are interested.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Posts: 10487 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.228) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1061915 posted 04/12/12 10:45 AM     Remind Me!  Send Private Message   Edit Post
You can modify a 3000gt shift lever to fit a gvr4 properly, and the shifter throw ends up being VERY short. I got the idea from Whoodoo, after seeing his. I believe he did a write-up on it and posted here on the forum. I did mine slightly differently than he did, and i believe we both did make use of a welder to get the job done. I think he had the added benefit of having a lathe available, so he made his own bushings as well (not required).
Simply putting a 1g short shifter assembly onto your GVR4 shifter base makes for a substantially shorter throw. They can be had on ebay for next to nothing. I ran one in 1411 for a very long time.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3507 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.95.216) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1061917 posted 04/12/12 10:53 AM     Remind Me!  Send Private Message   Edit Post
I have a 1g DSM one in mine and I love it. In fact it's the last shifter base I'll ever buy.
JZX90 Toyota Mark II Tourer V Twin Turbskie "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara" 550<
Edited by GSX_TC (04/12/12 10:54 AM)
Posts: 3701 | From: Houston, Texas | Member Since: 04/07/11 | IP:
(208.54.4.189) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1061921 posted 04/12/12 11:15 AM     Remind Me!  Send Private Message   Edit Post
I've never changed the base. Just the arms. I think the 1g short shifter can be had for cheaper than most want for a 1g shifter and base setup.
97 CBR900RR
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1061934 posted 04/12/12 02:44 PM     Remind Me!  Send Private Message   Edit Post
I think I just changed the arm on mine too.
While it might not technically be a shorter throw, it gives a much sportier feeling. The arm position is lower and seems give legitimate faster, easier shifts.
1992 Nile black w/sunroof
14xK miles. 2nd owner since 1998
Posts: 5750 | From: Lafayette, IN | Member Since: 08/06/02 | IP: (68.58.8.64) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1061935 posted 04/12/12 02:52 PM     Remind Me!  Send Private Message   Edit Post
I have an old Mofugas in 503, which I think is the same as the JNZ unit. And a 1g in 1051. I think I'm gonna switch them. The Mofugas has a much shorter throw. The DSM may be physically shorter, but the throw is the same as stock. I don't really like it other than it lowering the position of the shift knob.
-Mark
1051
Posts: 11864 | From: Yakima, WA | Member Since: 04/29/01 | IP: (74.82.68.144) | Report this post to a Moderator
TomN
ReNoonen
Galant VR-4 org Post #: 1061942 posted 04/12/12 03:52 PM     Remind Me!  Send Private Message   Edit Post
I had the JNZ short throw shifter in my old Galant. It is a very nice shifter and is a shorter throw than just a 1g shifter. Make sure you use bump stops on the shifter set properly on it though as you can easily over shift the car and break a shift fork.
Tom N
94 EVO I ( no times yet )
91 Galant VR-4
11.497 @ 119.55 (16g power)
Posts: 207 | From: North Port, Fl | Member Since: 11/21/11 | IP: (98.244.221.198) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1061954 posted 04/12/12 05:09 PM     Remind Me!  Send Private Message   Edit Post
One of the benefits i see to having an actual "short shifter" setup, is that since the part above the fulcrum is so short, and the part below is so long, this makes for a LOT less potential strain for the shift cables, rails, forks and sliders. A 1g dsm short shifter accomplishes this pretty well.
That's the route i took, but without the machining of new parts. Rather than make a new pin for the lower portion, i extracted the one from the factory GVR4 arm, and welded it in place on the 3kgt arm, after removing the one that was originally there. I don't really remember what i did in place of the custom bushings Whoodoo used, but it ended up being fine. I figured out some way to have the factory bushings work. It's not some sloppy mess, either.
This is a VERY much shorter throw than factory, and even quite a bit shorter than a 1g dsm short shifter.
97 CBR900RR
Nabeel
Member +
Galant VR-4 org Post #: 1061959 posted 04/12/12 06:10 PM     Remind Me!  Send Private Message   Edit Post
The 3000gt shift lever seems nice. But It could be hard to find.
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (94.96.11.232) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1061964 posted 04/12/12 07:08 PM     Remind Me!  Send Private Message   Edit Post
And is that shifter from the FWD 3000gt or the AWD?
dustyduff
Member +
1759/2000
Galant VR-4 org Post #: 1061966 posted 04/12/12 07:26 PM     Remind Me!  Send Private Message   Edit Post
I had a dogbox racing modified short shifter on 1g. Kept it to install in the VR4. I'll have to see if I have some pictures. The modified shifter had "stop blocks" welded onto it so you can adjust the throw to prevent braking shift forks. Dogbox is out of business now, but if you can weld, it shouldn't bee too difficult. It used two bolts (front and back) on te stop blocks to adjust the throw.
I was able to get all the bushings from JNZ to rebuild it.
Edited by dustyduff (04/12/12 07:27 PM)
Posts: 416 | From: Mantua, NJ | Member Since: 04/19/09 | IP: (68.83.57.99) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1062136 posted 04/13/12 05:20 PM     Remind Me!  Send Private Message   Edit Post
Quoting Nabeel:
I'm not sure there's a difference. There may not be a significant enough difference to matter.
Maybe if you PM whoodoo, he can tell you. I simply don't remember.
97 CBR900RR
Nabeel
Member +
Galant VR-4 org Post #: 1062193 posted 04/13/12 10:40 PM     Remind Me!  Send Private Message   Edit Post
I sent a PM to whoodoo. I think JNZ shifter is a modified 3000gt shifter. By looking at whoodoo's thread & compare the photo with THIS ONE
They seems the same
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (2.89.185.198) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1062791 posted 04/17/12 01:34 AM     Remind Me!  Send Private Message   Edit Post
That JNZ short shifter does look exactly like a 3k shifter. I think Whoodoo and i just cut ours down a bit shorter on the top side, maybe.
97 CBR900RR
Posts: 3507 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (98.237.211.124) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1062797 posted 04/17/12 02:43 AM     Remind Me!  Send Private Message   Edit Post
The JNZ piece has been talked about before.
Quoting DSSA:
Yep, the one part we start out with is from the 3KGT, which we buy new from Mitsu.
You also have to have adapter bushings machined to allow it to fit into a DSM/GVR4, new standard bushings from Mitsu, remove the larger pin for the shifter, use another machined bushing to center the new, smaller pin, make the smaller pin (yes, just cut to proper length, and center-drill for the cotter pin, but that takes time as well), reweld everything together using jigs, and re-angle the lower piece for clearancing.
Then all of the parts get powdercoated, assembled with new hardware, and pre-lubed.
I guess if using around $90 in materials, plus spending around an hour to machine, weld, powdercoat, and assembling each one using custom parts and jigs for $144.99 (that's $55 in profit before paying an employee for that hour)is ripping people off, then I guess we're guilty as charged. Then again, every other business that sells their products/time/ for money would be in the same boat as us.
I forgot to mention that we also paid more for these last parts through Mitsubishi as we had to convince them to make one more run of 30 of each of the raw parts since they're no longer in production and no longer available anywhere. Thus, they're even less profit this time around.
I didn't like how short the 1g lever was. Below the fulcrum, its the same as the GVR4, but the shorter length above the fulcrum is shorter, so you hand will travel less, giving you the impression its a short shifter.
I had the 1g for a while but then bought the JNZ piece and like it quite a bit better. The throw is still shorter, but sits a bit higher which I feel is more suitable for the Galant.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (67.171.235.101) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1062871 posted 04/17/12 03:32 PM     Remind Me!  Send Private Message   Edit Post
The JNZ sells fair price considering they are using new 3k shifter as they are not cheap from dealer. The word of expensive comes from comparing to other shifters.
91 VR4
09 GT eclipse
91 Cefiro
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (37.105.94.230) | Report this post to a Moderator
5OF2k
Member ++
5/2000
Galant VR-4 org Post #: 1062889 posted 04/17/12 05:07 PM     Remind Me!  Send Private Message   Edit Post
I always did this, on every DSM Ive owned from daily to racecar:
vfaq shifter mod
my .02
-Jake
**[B]EDIT[/B]** I just realized it only shows the main page, click on shifter, then click shifter throw mod. It also has a link for the shifter stop mod as well (necessary)
Edited by 5OF2k (04/17/12 05:10 PM)
Posts: 664 | From: colorado springs, colorado | Member Since: 03/28/12 | IP: (140.32.120.188) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1062895 posted 04/17/12 05:49 PM     Remind Me!  Send Private Message   Edit Post
5OF2k' That is very good point. 1g shifter+ vfaq mod= Great cheap shifter
Posts: 255 | From: K.S.A | Member Since: 07/14/06 | IP: (79.170.51.171) | Report this post to a Moderator
GVR4NGER694
Galant VR-4 org Post #: 1062906 posted 04/17/12 07:19 PM     Remind Me!  Send Private Message   Edit Post
I put a different shift knob that sits deeper then the stock knob.
it is at least an inch shorter.
I pulled the boot up to it.
| | | IP: (174.29.175.135) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 67 anonymous users are browsing this forum.
Generated in 0.257 seconds in which 0.209 seconds were spent on a total of 15 queries. Turbo powered.
