Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » #431: New GVR4 record holder - info & vids
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 1035505 posted 11/22/11 07:44 PM     Remind Me!  Send Private Message   Edit Post
Youtube Video: http://www.youtube.com/watch?v=4Zpb71tf7_4
We knocked off a clean pass at Etown on this last sunday, Nov 20th. We changed to a larger intercooler core, changed the rear suspension to the D2's (from KYB AGX & soft GC coil over sleeves), and set the alignment to zero at the car's maximum launch attitude. Boost was set back to 40psi and the plug gap was put to .014. Now the air temps are more reasonable at just over 100*F at the traps, which accounted for about 2mph gain at the same boost level compared to the 144mph run that had max AIT of 156*F. The rear suspension was worth some stability on the launch too, as it now leaves straight and doesn't crush the back end down. With the AGX/GC suspension it would slam the rear end down, cause the camber to go way negative, and seemed to bounce back up and upset the car. Now it just hooks and goes straight with no drama!
Unfortunately, we broke something in the trans (stock automatic), I think likely the front diff or the center transfer gear on the next pass. After the 9.3 we hung around a while expecting the tech guy to come throw us out, thankfully he didn't show. So we did the pre-run retune and got it ready to try and improve on the 9.36. I added a few psi of boost, one degree of timing, and turned the shifts up 200rpm. Nelson launched it at 12psi on the 9.3 and got a 1.37, so we decided to shoot for a 14-15psi release and hope for a 5.xxx 1/8mile and maybe a [email protected] Unfortunately, it broke right off the line.
So next year our plans are to put in all the required safety equipment to legally run in the 9's and 150+mph. (cage, chute, window net). both of us are going to get an NHRA license as well as updated helmet and fire suits. Plan to remove about 200-250lb from the car while still keeping it street-looking (much of the weight being light brakes, light wheels, removing the ABS, radio, AC parts...stuff like that). I really believe this car can run in the 8.9's @ 150+ if we can get it to hold together on a 1.2 second 60' time.
Figured I would start a new thread for the video rather than tacking it onto the end of the last thread where people might miss it.
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Posts: 2053 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (184.6.215.199) | Report this post to a Moderator
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 1035508 posted 11/22/11 08:14 PM     Remind Me!  Send Private Message   Edit Post
AWESOME DUDE!!!
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 601 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (108.68.109.184) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1035509 posted 11/22/11 08:15 PM     Remind Me!  Send Private Message   Edit Post
JZX90 Toyota Mark II Tourer V Twin Turbskie "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara" 550<
Posts: 3701 | From: Houston, Texas | Member Since: 04/07/11 | IP:
(208.54.39.211) | Report this post to a Moderator
Galantvr41062
Epic Build
1062/2000
Galant VR-4 org Post #: 1035556 posted 11/23/11 12:36 AM     Remind Me!  Send Private Message   Edit Post
To bad the stock auto could not cut it, are you going to switch to the 2g auto like all the 1g guys running mid 8s at 160+mph? So it looks like your 10mph slower in the 1/8th and 1/4 MPH and .300 quicker at the 1/8th but only .100 quicker in the 1/4? What are your tranny fluid temps? Something is hurting you big time in the last 1/8th vs what you are gaining being auto in the first 1/8th mile. Good luck over the winter, if you want help with safety over the winter just shoot me an PM or Email and I can go over what I did.
~John
Moon taxi: [email protected] mph 41psi 2011, 2012 1.5 60', then bust.. 2015 no, 2016 will be the year, maybe.
91 Gvr4 #597: sold
Posts: 410 | From: plymouth, MN | Member Since: 08/20/07 | IP: (71.49.81.124) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 1035558 posted 11/23/11 12:42 AM     Remind Me!  Send Private Message   Edit Post
^ true racer right there. willing to help out the competition.
Now why is it there always some track worker always stepping in front of a camera
Again congrats guys
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11885 | From: Clarksville TN | Member Since: 05/04/03 | IP: (8.27.208.108) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 1035566 posted 11/23/11 02:17 AM     Remind Me!  Send Private Message   Edit Post
Congrats Nate!!! Very impressive
#815/2000- Lexus Pearl White
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (72.79.181.238) | Report this post to a Moderator
RedTwo
Rangi Kiwi
Galant VR-4 org Post #: 1035574 posted 11/23/11 03:40 AM     Remind Me!  Send Private Message   Edit Post
I think things are getting a little out of hand. I doubt it's comprehensive, but there seems to be the beginnings of a pattern. A VR4 arms race if you will
Posts: 1917 | From: New Zealand | Member Since: 07/16/08 | IP: (121.74.236.75) | Report this post to a Moderator
EgonOlsen
Member +
1302/2000
Galant VR-4 org Post #: 1035581 posted 11/23/11 04:25 AM     Remind Me!  Send Private Message   Edit Post
Grats, yeah it seems there is some serious competition on this atm.
Galant '91 VR4 1302/2000
Celeste 80 1600 ST
Carisma '99 GDI (daily)
Posts: 333 | From: Denmark, Europe. | Member Since: 05/04/10 | IP: (217.61.120.138) | Report this post to a Moderator
Galant VR-4 org Post #: 1035587 posted 11/23/11 05:53 AM     Remind Me!  Send Private Message   Edit Post
Congratulations Nate. Even more impressive that you did this before the serious diet planned for the car. I reall sincerely wish you guys the best of luck for next year. I would love to see you hit 8s.
Paul
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (118.141.71.107) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 1035598 posted 11/23/11 08:39 AM     Remind Me!  Send Private Message   Edit Post
Quoting GalantVR41062:
~John
Next year we are going to start logging exhaust back pressure and trans temp, but I can't say what's up with either of those now. We have no plans to move to the 2g trans since replacements are hard to find in the junkyard and they seems to go for 3X the price. We can just keep swapping stock 1g trannies that are nearly free. We buy whole 1g auto parts cars, keep the drivetrain, and can often sell off the remainder of the car for a profit still. I think the main reason most guys were swapping to the 2g trans was the availability of the smaller diameter billet converters. Noone makes that for 1g style non-lockup anymore.
As far as the 1/8mile vs 1/4mile, I don't think it's so much a "problem" as it is just a natural advantage of a clutch car vs converter car. Your car puts 100% power down in top gear, while ours is slipping the converter. I would always expect our advantage to diminish going down the track, a manual car of close power/weight ratio should pull up on the auto car on the back half. The real comparison would be to find out how other auto guys fare at the same ET/speed to see if there is anything abnormal about the top end. I tend to think this is typical of auto cars with loose converters to have a somewhat "lackluster" top end charge. Maybe we also have a top rpm issue. still wet sump, still stock lifters, still stock oiling system in the head....maybe the sustained 8000-9000rpm in the last 400ft or so is down on power?
Our converter might even be a little looser than ideal since we are able to spool it up on the line to about 4500rpm and it flashes over 6200rpm in first gear right away. The converter is actually so loose that the last time we had the car out Nov 5th, the converter flashed up higher than the shift rpm setting! It went [email protected] in powerglidemode: it shifted 1-2 and 2-3 during the 60' and simply rode the converter out to the 1/8mile. IMHO, we could go tighter on the converter and it would improve the mph up top, but it's a fine line and I'd hate to make a change that hurts the 60' and 330' times in order to pick up mph and end up a wash on ET.
Edit: oh yeah, this trans had like 140k miles on it from the car we pulled it from. It's possible that it was just 2/3 worn out and that contributed to the failure. hopefully a freshly built trans will last a little longer and hold up to additional power off the line. We are going to put in a huge trans fluid cooler as well, can't hurt.
Edited by NateCrisman (11/23/11 08:49 AM)
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 1035600 posted 11/23/11 08:44 AM     Remind Me!  Send Private Message   Edit Post
Quoting curtis:
Again congrats guys
It took all I had in me to not swear into the camera when the track guy was pacing back and forth. Worst part is he had made me stay behind him "due to safety rules" all of 15 seconds before, so I kinda think he was screwing with me on purpose.
I think next year we will have a better video setup. We have like 4 iPhones at the track each time we go since it seems most of our crew has one (plus wives have them too). Im going to see about finding some sort of go=pro=esque suction cup mounts for iPhone that are strong. Then we can have 3-4 in car vids per run, and they are light weight compared to my heavy duty roll bar mount and a DSLR w/ fisheye.
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 1035602 posted 11/23/11 08:47 AM     Remind Me!  Send Private Message   Edit Post
Quoting RedTwo:
AWESOME GRAPH.
I hope the other guys all put some time and effort in this winter to catch up and we have a great 2012 season of the record changing hands over and over. There are like 4-5 cars all within a few tenths, this could be super fun and motivating if everyone stays interested. The record doesn't really mean much when none else is trying for it.
JSchleim18
Minor 69er
1157/2000
Galant VR-4 org Post #: 1035606 posted 11/23/11 09:47 AM     Remind Me!  Send Private Message   Edit Post
Congrats on the record Nate and Nelson!
Looking forward to 8's next year.
-Jeremy
A88 Summit White - CD (No Sunroof)
Posts: 4738 | From: Long Island, NY | Member Since: 10/16/06 | IP: (108.58.86.186) | Report this post to a Moderator
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 1035607 posted 11/23/11 09:51 AM     Remind Me!  Send Private Message   Edit Post
Awesome pass Congrats on the record..
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Posts: 4326 | From: Orlando, FL | Member Since: 04/24/03 | IP: (199.101.173.2) | Report this post to a Moderator
wevo1985
Galant VR-4 org Post #: 1035608 posted 11/23/11 09:55 AM     Remind Me!  Send Private Message   Edit Post
very nice, loving the 60ft time
| | | IP: (69.206.146.25) | Report this post to a Moderator
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 1035611 posted 11/23/11 09:59 AM     Remind Me!  Send Private Message   Edit Post
I'm itching to figure out what part we need to upgrade next in order to make it 60' in the 1.2's. Ideally, I want the front wheels UP!
SleepinGVR4
What are we going to do today Ferb?
629/2000
Galant VR-4 org Post #: 1035626 posted 11/23/11 11:21 AM     Remind Me!  Send Private Message   Edit Post
Huge congrats to you Nate and GizmoVR4.
Maybe Dan S. will get his car up and running again to add to the competition.
Sean
Posts: 2483 | From: Danville, Pennsylvania | Member Since: 02/12/03 | IP: (74.43.82.10) | Report this post to a Moderator
Gizmovr4
Member +
431/1000
584/1000
Galant VR-4 org Post #: 1035645 posted 11/23/11 12:21 PM     Remind Me!  Send Private Message   Edit Post
Thank you for the compliments guys. Nate and I are very proud of how this car has developed seeing how it was put together only six months ago.
Its funny how much Nate and I are alike. At Englishtown after the record pass we could have packed it in and gone home with record in hand. However thats not how we are we didnt care so much about the record- we were more concerned about squeezing one more pass and as much performance out of the car as we could.
With this said:
Nate is already trying to figure out how to get the car to launch better weight loss- and a ton of performance improvements-. Im looking at rebuilding the transmission using better 3rd gear clutch pack to improve the up top performance time to stop using 125k+ mile used transmissions that likely are slipping. I am also contemplating building another engine for racing only . The engine that I built this year was for street use with off the shelf cheap and used parts.
Im sure at some point we will also spray the car since we already have all the nitrous stuff anyway- might as well give it a shot...
The car is not being built for the purpose of chasing a record this is not what Im about its a fun project...If the car goes faster awesome -if not 9s are nothing to be upset about... but 8s are better ...
Stay tuned ...
Nate Crisman Racing www.performancepartout.com
Vinny Ten Racing click
431/1000 [email protected] 584/1000 556AWHP
Edited by gizmovr4 (11/23/11 02:24 PM)
Posts: 365 | From: andover,NJ | Member Since: 11/18/09 | IP: (68.195.230.122) | Report this post to a Moderator
Specter
Member +
Galant VR-4 org Post #: 1035780 posted 11/24/11 03:21 AM     Remind Me!  Send Private Message   Edit Post
Quoting NateCrisman:
Would love to see that happen!
Posts: 367 | From: Karachi, Pakistan | Member Since: 04/20/08 | IP: (203.130.1.75) | Report this post to a Moderator
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1035863 posted 11/24/11 03:30 PM     Remind Me!  Send Private Message   Edit Post
Quoting RedTwo:
AWESOME GRAPH.
Drag racing is not so much my thing, but this is getting interesting. I can totally appreciate all the work that you guys are putting in here. I like these cars and from that standpoint there is some really neat stuff happening with the contenders.
Great work guys, congrats.
2003 Evo
2018 JK Wrangler
2002 Honda Odyssey
1998 Honda CR-V
Posts: 1921 | From: Oceanside, CA | Member Since: 04/25/07 | IP: (68.5.153.146) | Report this post to a Moderator
Redwood
wannabe king of rednecks
1695/2000
Galant VR-4 org Post #: 1036582 posted 11/28/11 02:57 PM     Remind Me!  Send Private Message   Edit Post
Hell of a run man. i just watched the vid of ur pass the other day... nice work bud
1695/2000 SUMMIT WHITE
Posts: 282 | From: Moses Lake, Wa | Member Since: 10/13/11 | IP: (192.104.67.222) | Report this post to a Moderator
Blown1
Galant VR-4 org Post #: 1037145 posted 11/30/11 11:35 PM     Remind Me!  Send Private Message   Edit Post
Can't see the video
This video contains content from SME, who has blocked it
in your country on copyright grounds.Sorry about that.
| | | IP: (71.235.196.54) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 1037198 posted 12/01/11 03:21 AM     Remind Me!  Send Private Message   Edit Post
I will now never listen to Ozzy again......Holy crap you can't post crazy train in a car video. What they got assholes that sit around looking for there music. Bite my ass sme. Nate post it again but this time have the music running backwards like Satan did it.
92 GVR4 0475/1000
Jordangvr4
Member +
Galant VR-4 org Post #: 1037266 posted 12/01/11 02:43 PM     Remind Me!  Send Private Message   Edit Post
Congrats to both of you guys, great build. 2012 is going to be the year of the vr4's Ctm racing and you guys running nice numbers....good luck
1991 Gvr-4 Amg
1991 Gvr-4 Jdm rhd
Posts: 318 | From: Nassau,NYC. | Member Since: 11/02/08 | IP: (208.54.37.236) | Report this post to a Moderator
mountaineerjeff
<3 NJ
1630/2000
1844/2000
181/1000
Galant VR-4 org Post #: 1037298 posted 12/01/11 04:23 PM     Remind Me!  Send Private Message   Edit Post
Quoting curtis:
thats bull, just tell them it was playing, in the car, on the radio.
We didnt start the fire! Billy Joel:E39A expert
181/1000 half-a$$ rally-fart
1630/2000 Ballin!
1844/2000 unwillingly put in 'storage'
mirage turbo sold to a guy who will wreck it
2012 EVO, too bad its not a Mitsubishi
Posts: 1155 | From: west virginia | Member Since: 10/22/08 | IP: (108.113.200.7) | Report this post to a Moderator
Pages: 1 | 2
1 registered and 18 anonymous users are browsing this forum.
Generated in 0.157 seconds in which 0.075 seconds were spent on a total of 15 queries. Turbo powered.
