Galant VR-4 Forums » Marketplace » Parts For Sale » FS: QM twin disc
FS: QM twin disc
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1030175 posted 10/31/11 01:18 AM     Remind Me!  Send Private Message   Edit Post
I have a Quartermaster twin disc that for sale that needs some attention.
I broke a clutch fork, so the cover is a bit beat up, but does not affect the function of the clutch at all.
The Shep clearanced fork did clear completely and eventually clearanced itself, so the end of the threads and top of the nuts are a little beat up. Again, this will not affect the function of the clutch.
The clutch has the TMZ gear drive disc set with about 10k miles on them.
The clutch started slipping on the dyno at 470awhp, I can't recall what the torque was. I pulled it out and upon inspection, the v-drive plate and floater plate appear to be warped, the wear is uneven.
The ring gear is welded to the flywheel.
There is some wear on the gear drive hub.
Friction plate, the other measured 5.99
Inside of floater plate
Outside of floater plate
The clutch has not seen a whole lot of heat, just daily use mostly. I never did make any passes at the track with it, just a few launches on the street. I also have the spacer to keep the flywheel bolts from bottoming in the crank.
Asking $700, make an offer though.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (67.171.235.101) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1032294 posted 11/08/11 09:34 PM     Remind Me!  Send Private Message   Edit Post
$600 shipped.
Keep in mind the TMZ discs cost $450 vs the standard discs at $285.
Send me an offer!
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1035073 posted 11/20/11 07:53 PM     Remind Me!  Send Private Message   Edit Post
Seriously, send me some low balls. I have tuition to pay for.
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (97.120.16.100) | Report this post to a Moderator
MitchooO
knows how to break em
1972/2000
Galant VR-4 org Post #: 1035327 posted 11/21/11 08:47 PM     Remind Me!  Send Private Message   Edit Post
Do you know how it got warped? Did you ride it too much when you launched it on the street or do you think the clearance was wrong for the throw outr bearing and it kept pressure on it the hole time? I'm interested in used parts that I can get rebuilt. but I'm just not sure about this one. These clutches hold alot of power ussually don't they?
If its not white. The owners not too Bright.
1972/2000- Wallet Nightmare with too big of a turbo
81 Toyota Starlet- long time search found for 500 bucks
93 Civic- Been in the family over 10 years. SOHC turbo beaten on everyday of its life
Posts: 350 | From: South Mountain, PA | Member Since: 10/10/07 | IP: (174.54.95.219) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1035393 posted 11/21/11 11:15 PM     Remind Me!  Send Private Message   Edit Post
I think just normal street use is what warped it, because I really didn't beat on it much. The pressure plate and flywheel show they were not subject to as much heat as most clutches that are replaced once they are done. I don't believe there were any clearance issues other than what happened with the clutch fork. The clutch is rebuildable and the parts that are warped can be had for pretty cheap. Realistically, the clutch can be ready to go for whatever price is agreed on plus maybe a couple hundred more for the pressure plate (a V shaped piece, not the cover), floater plate, and machined clutch fork. The clutch retails for over $1200 and I am willing to negotiate since it does need some work.
These clutches hold a lot of power. They have held up to 600+awhp DSMs without a problem and should be capable of even more.
If you would like to talk about the clutch over the phone, I'm available after 6:00pm Pacific time. threesixzero.sixzeroone.1664.
EDIT*
The parts can be had here, click
I would honestly just buy the floater for $92, the v-drive pressure plate for $120, and the clutch fork for $54. You can have one hell of a clutch for pretty cheap.
Using the 2g accumulator and 2g slave help the drivability a ton if you plan on street driving. I never did use those parts, but I did drive a non gear drive QM and it felt like an ordinary 2600/sprung disc.
Edited by 4thStroke (11/21/11 11:24 PM)
475/1000
Galant VR-4 org Post #: 1035445 posted 11/22/11 12:21 PM     Remind Me!  Send Private Message   Edit Post
Just because there warped doesn't mean you can't use them. What you need to do is find a dead flat surface. I have a headstone piece on a workbench I use. Lay it on the stone and measure with a feeler gauge. Some is allowed but you'll have to call QM to find out how much. Seems like it was .008 average when I called PTT about mine.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11885 | From: Clarksville TN | Member Since: 05/04/03 | IP: (8.27.208.108) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1035451 posted 11/22/11 12:52 PM     Remind Me!  Send Private Message   Edit Post
Curtis, I don't advise using the clutch without replacing those parts. The uneven wear is very evident on the v and floater plate and the clutch did slip at 470awhp, just around peak torque and still building power.
I appreciate you looking out, though!
Posts: 1864 | From: Vancouver, WA | Member Since: 10/22/07 | IP: (174.253.195.6) | Report this post to a Moderator
MitchooO
1972/2000
Galant VR-4 org Post #: 1035596 posted 11/23/11 07:55 AM     Remind Me!  Send Private Message   Edit Post
Ok thanks guys for the input! I was just curious to if anyone actually rebuilt one that was in this kind of shape and made out ok with it. Is it not the best decision to put this clutch in for street use? Mine is always drivin on the street. I have a clutchnet red pressure plate with a 6 puck now thats hard to drive now so im not worried about pedal feel, Just dont want to put a clutch in that will be ruined from street use
Posts: 350 | From: South Mountain, PA | Member Since: 10/10/07 | IP: (174.54.96.238) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1035743 posted 11/23/11 10:30 PM     Remind Me!  Send Private Message   Edit Post
It was probably a combination of things that caused the parts to warp. The parts the warped have over 20,000 miles on them. Twins don't like to see the street as much as the singles, but your tranny will shift like never before
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1037160 posted 12/01/11 12:53 AM     Remind Me!  Send Private Message   Edit Post
This thing needs to go. $400.
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1040040 posted 12/14/11 09:47 PM     Remind Me!  Send Private Message   Edit Post
Need some cash, send me an offer!
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1043788 posted 01/05/12 01:40 AM     Remind Me!  Send Private Message   Edit Post
Bump!
thedsmguy
Galant VR-4 org Post #: 1043798 posted 01/05/12 02:55 AM     Remind Me!  Send Private Message   Edit Post
Spence,
Whats it going to take to get this usable in another car? I guess there are more then just me that are wondering what its going to cost to run this again.
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (24.20.91.222) | Report this post to a Moderator
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1044023 posted 01/06/12 12:49 AM     Remind Me!  Send Private Message   Edit Post
It just needs the v-drive pressure plate and floater plate. Cheap and easy.
thedsmguy
Galant VR-4 org Post #: 1044024 posted 01/06/12 01:04 AM     Remind Me!  Send Private Message   Edit Post
About how much is a guy looking at for those parts?
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1044035 posted 01/06/12 01:59 AM     Remind Me!  Send Private Message   Edit Post
$212 for both parts, not that expensive at all. I posted prices and links above.
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1051285 posted 02/11/12 02:16 PM     Remind Me!  Send Private Message   Edit Post
bump
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1056427 posted 03/14/12 01:56 AM     Remind Me!  Send Private Message   Edit Post
tax returns!
4thStroke
Spence knows tools
786/2000
Galant VR-4 org Post #: 1059568 posted 03/30/12 12:04 AM     Remind Me!  Send Private Message   Edit Post
bump this up
1 registered and 42 anonymous users are browsing this forum.
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker
Generated in 0.091 seconds in which 0.06 seconds were spent on a total of 14 queries. Turbo powered.
