Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Top mounted intercooler, very short route and hood scooped! *UPDATE*
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027421 posted 10/20/11 07:20 PM     Remind Me!  Send Private Message   Edit Post
So...I run a fabrication shop and I ended up making this set-up myself. I have 9" of piping total and my cooler is 11"X15" with out the end tanks. I have a 11"X2 1/2" opening in my hood to get air to the cooler and I like my temps so far. I may put a puller fan on the bottom of the cooler if need be. I did a test run before I finished the hood scoop and seems like my IAT were pretty good. On an 85 degree day at 17psi I was running 120 degree's under boost and cooled down to 88 degree's within about 7 seconds. Would have done a longer pull but my tape that was holding the make shift hood scoop started to blow off. As it turns out it was only 105 MPH tape!!!
I'm sure this will get some negative input...As it has already. I have a bung welded in on the inlet tank so that I can see what my temps are before and after, but the sensor that I received didn't read for some reason. I did do some driving before I was able to have any air getting to the cooler and my temps quickly went up to around 200 degrees and didn't come down very quickly as one would expect.With the air getting to it I think it's doing ok. I never saw temps over 122 degree's. Will hopefully do some more testing tomorrow before I tear apart the car to paint it!
My reasoning......Seams logical to have as little plumbing to charge and I was not going to cut my front bumper support to put in a larger cooler. Many people do and that's fine but I wasn't going too. The factory plumbing was 98" the best I could measure. I'm now less that 10% of that with 3 times the factory cooler and a direct path of air to it and nothing really hot behind it (A/C condenser, radiator, turbo, exhaust, etc.)
EVO III 16G, manifold and O2 housing, 3" exhaust, Evo 9 IC, 3" GM MAF, GM IAT, GM MAP, LC1 wideband, V3 Full, RC 750's, Aeromotive 340 fuel pump, Adj. FPR. Stock internals. Baer front brakes, Evo 9 Ohlin's.
Edited by rdomeck (08/07/12 11:19 AM)
Posts: 620 | From: Indianapolis, In. | Member Since: 06/01/11 | IP: (68.58.124.90) | Report this post to a Moderator
agent23
Galant VR-4 org Post #: 1027442 posted 10/20/11 07:50 PM     Remind Me!  Send Private Message   Edit Post
i think it looks good specaly the low profile of the scoop
| | | IP: (24.14.111.84) | Report this post to a Moderator
kartorium
hillbilly racer
334/1000
Galant VR-4 org Post #: 1027451 posted 10/20/11 08:04 PM     Remind Me!  Send Private Message   Edit Post
I think it turned out great, and will work fine for what you're trying to accomplish. You did an awesome job building the setup too! Very clean.
I was going to do this exact same thing back in like 2004 or so using a starion core. I ended up not doing it cause my car at the time got totaled and the new car I got already had a front mount.
Glad to see you followed through.
Posts: 2962 | From: ellensburg,wa | Member Since: 01/14/02 | IP: (71.80.198.245) | Report this post to a Moderator
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1027465 posted 10/20/11 08:27 PM     Remind Me!  Send Private Message   Edit Post
That is a really cool set up. I think you did a hell of a job putting it together. It looks well thought out and well executed. Good on ya!
My car eats turbos
1991 Galant VR4 (1968/2000 NB)
2006 Galant SE
1986 Chevy C10
Posts: 255 | From: Denver, CO | Member Since: 01/14/10 | IP: (75.71.188.11) | Report this post to a Moderator
bobdole
Old member with new to me VR4 and starting over. Respect your elders kids
504/2000
Galant VR-4 org Post #: 1027479 posted 10/20/11 08:56 PM     Remind Me!  Send Private Message   Edit Post
This is really neat. Great job. Looks like the intercooler fit's nice under the hood.
Great deal on BC coilovers. Hit me up. Whiteline dealer. Vibrant dealer.
Posts: 743 | From: tampa | Member Since: 08/23/07 | IP: (92.25.139.252) | Report this post to a Moderator
Diego
Mad Hatter Suite Touche Debackle Guage filled by Justin
1309/2000
Galant VR-4 org Post #: 1027489 posted 10/20/11 09:09 PM     Remind Me!  Send Private Message   Edit Post
Quoting Okayplayer:
This! Great job thinking outside the cookie cutter version types!
"I love blackjack. But I'm not addicted to gambling. I'm addicted to sitting in a semi circle."
91 nile black vr4, 1309/2000
Posts: 2132 | From: In a van down by the river, Io... | Member Since: 12/09/07 | IP: (76.25.120.127) | Report this post to a Moderator
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027490 posted 10/20/11 09:09 PM     Remind Me!  Send Private Message   Edit Post
I could have went a little larger on the cooler, but I don't think it would have been as clean and the plumbing would have much longer and that would have defeated my plan. I'm thinking about painting it Dover White Pearl...The color that is on the newer Galants!
Wow, this post made me a member.........
Edited by rdomeck (10/20/11 09:12 PM)
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1027534 posted 10/20/11 11:19 PM     Remind Me!  Send Private Message   Edit Post
Hahaha, That's funny, I've been on this forum for almost 2 years and just getting close to being "member" status, I guess I'm antisocial. SMH
My car eats turbos
2006 Galant SE
1986 Chevy C10
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1027541 posted 10/20/11 11:41 PM     Remind Me!  Send Private Message   Edit Post
thats pretty neat, there was a guy at this years shootout that had a very similar setup like that. here are the pics i took of it.
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3703 | From: Houston, Texas | Member Since: 04/07/11 | IP: (24.249.34.170) | Report this post to a Moderator
AWDPower
739/1000
Galant VR-4 org Post #: 1027562 posted 10/21/11 12:21 AM     Remind Me!  Send Private Message   Edit Post
I like it, very well executed. The hood looks like it could be factory. Did you notice a big difference in throttle response?
Jason K.
739/1000
Posts: 107 | From: Vacaville, CA | Member Since: 03/01/11 | IP: (75.33.196.176) | Report this post to a Moderator
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027630 posted 10/21/11 08:58 AM     Remind Me!  Send Private Message   Edit Post
I did notice much better throttle response, but I also changed a bunch of other stuff at the same time! Not the way I like to modify things, but it's just the series of events that happened! I'll be doing some more driving today to see how it does!
Posts: 620 | From: Indianapolis, In. | Member Since: 06/01/11 | IP: (96.11.83.39) | Report this post to a Moderator
gramkrakr89
Now with Jelly next week is roasted marshmallows and hershey bars
689/1000
Galant VR-4 org Post #: 1027639 posted 10/21/11 09:24 AM     Remind Me!  Send Private Message   Edit Post
Very nice indeed, definitely not a run-of-the-mill DSM hack-job
I'm curious to see how your setup turns out performance wise... aesthetically, it's an A+ for sure
Posts: 308 | From: Cincinnati, OH | Member Since: 01/25/10 | IP: (129.137.167.43) | Report this post to a Moderator
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027682 posted 10/21/11 01:29 PM     Remind Me!  Send Private Message   Edit Post
Quoting AWDPower:
A factory job was exactly what I wanted it to look like! Thanks for the comment!
zberto
Galant VR-4 org Post #: 1027711 posted 10/21/11 03:01 PM     Remind Me!  Send Private Message   Edit Post
Interesting. The hood turned out good. I first saw the mock up with those sharp edges and I was like uh oh. Im eager to see the hood on the car.
You mentioned that there is nothing hot behind the intercooler but the trans is right below there.
Do you still have ac?
And do you feel like snapping a pic of your engine bay with the ic out so I/we can see what the intake pipe and mounting points look like?
Edited by zberto (10/21/11 03:04 PM)
| | | IP: (70.162.164.213) | Report this post to a Moderator
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027811 posted 10/21/11 08:46 PM     Remind Me!  Send Private Message   Edit Post
I'm sure at some point I will have the intercooler out and I will take some pics. The transmission is below there, but it's not like the FMIC that has an A/C condenser and Radiator right behind it. The air flow out the bottom is much more unobstructed than a FMIC.
I do still have A/C
I drove the car today with the hood on and will probably start the body work on it next week. I will post up some pics of the car with the hood on before I start!
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1027829 posted 10/21/11 09:49 PM     Remind Me!  Send Private Message   Edit Post
I'm glad this came out well, so how much would you charge to make a hood like this, hmmm
My car eats turbos
2006 Galant SE
1986 Chevy C10
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027832 posted 10/21/11 09:57 PM     Remind Me!  Send Private Message   Edit Post
If there were any interest at all I would make a mold of this one and cast it in fiberglass. I had a day in metal work and body work to get it into primer. That was once I had most everything figured out. I probably had 10-12 hours in it total. So probably in the $500-600 range. Would certainly be worth casting a mold to make some....Something that happens all the time in my business!
Interest anyone?
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1027838 posted 10/21/11 10:16 PM     Remind Me!  Send Private Message   Edit Post
It has a real rally look to it, not fanboy, but rally, I dig it. I wonder if my Evo front mount would fit in there. Hmmmm.
My car eats turbos
2006 Galant SE
1986 Chevy C10
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1027843 posted 10/21/11 10:29 PM     Remind Me!  Send Private Message   Edit Post
11" wide X 15" long was about all I could easily fit in there. I feel like I could make my own core and go bigger, but this is just a street car! I believe you could go at least 16 wide and maybe 18-20 long. This would require some different length tubes or fins and some thought on the end tanks. I was trying hard not to modify the chassis just in case I needed to back up!
PreskitVR4
Member +
501/2000
Galant VR-4 org Post #: 1028071 posted 10/22/11 11:45 PM     Remind Me!  Send Private Message   Edit Post
Looks awesome sir. Excellent execution, and good job on breaking the cookie cutter for FMICs!
"Hey your the guy with the.....the B13 Sentra?"
Posts: 272 | From: Prescott, Northern AZ | Member Since: 06/28/08 | IP: (76.178.104.124) | Report this post to a Moderator
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1028095 posted 10/23/11 02:18 AM     Remind Me!  Send Private Message   Edit Post
Let's see what this bad boy looks like on your car. Pics please
My car eats turbos
2006 Galant SE
1986 Chevy C10
138/2000
Galant VR-4 org Post #: 1028115 posted 10/23/11 07:49 AM     Remind Me!  Send Private Message   Edit Post
i may just have to do this to my laser in a few months. forget the big front mount, im going to make room under that hood and slap in a top mount. where did you get that intercooler is it a wrx one??
138/2000
Posts: 3472 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (24.176.249.118) | Report this post to a Moderator
rdomeck
Member ++
692/1000
Galant VR-4 org Post #: 1028122 posted 10/23/11 10:02 AM     Remind Me!  Send Private Message   Edit Post
I will get some photo's tomorrow. As far as were the intercooler came from....I purchased a core and made everything else.
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 1028135 posted 10/23/11 12:48 PM     Remind Me!  Send Private Message   Edit Post
Looks great. Am curious to see some data on this setup.
Its great to see stuff like this and the shortened bumpers thread (coughwriteupcough) coming up lately, 20 years in and people are still innovating.
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
Boost4U
Galant VR-4 org Post #: 1028176 posted 10/23/11 05:07 PM     Remind Me!  Send Private Message   Edit Post
both examples here look very cool and original I look forward to seeing the final product.
90 GSX, 91 Mustang Lx 5.0 Turbo
Jack Stand Racing Inc.
Posts: 133 | From: Hampton, VA | Member Since: 06/25/11 | IP: (71.176.49.51) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4
3 registered and 17 anonymous users are browsing this forum.
Generated in 0.34 seconds in which 0.288 seconds were spent on a total of 15 queries. Turbo powered.
