My ECU has toggle switches ...question for previous owner of 777
moduleunknown
Elk Grove, CA
Anybody have any idea what's going on here? This might be a question for the previous owner(s) of 777/2000. Just curious...
...it also has a phone cord hanging out of it - tempted to plug in an old phone receiver and ask it some questions. /ubbthreads/images/graemlins/smile.gif
I have no idea what would happen if I started flipping switches since I only found this when pulling the ECU to swap with a DSMLink V3 ECU, so it's really a non issue now.
oh wow i've never seen anything like that before.
Jeff used to do separate images on chips that could be accessed by toggle switches. I'm guessing that is what is going on here. I actually have a chip from him setup that way, but I never ended up using it. It had two different timing profiles on it for two different types of fuel. 92octane and 110. The old RJ11 phone plug was used back in the day for datalogging...I think. The phone line was even before I started messing with these piles.
cheekychimp
East Sussex, U.K.
I'm not sure that's the case here, look at the labels on the toggle switch. I am pretty sure that when you flip that toggle switch it initiates the ground for timing so that you don't have to mess about with wires under the hood.
Quoting cheekychimp:
I think I'd rather just ground out the connector under the hood to do idle/timing changes rather than have to reach up under the dash to flip switches. /ubbthreads/images/graemlins/dunno.gif
donniekak
surprise az
There are two toggles, and one of them goes to the pin you ground on the eprom chip to use the second map. I would guess the other one labeled idle, would be for the idle timing lock.
MitchooO
South Mountain, PA
I'm not sure if its anything like the ecu in my civic, When we had the ecu chipped for the car we drove the car to him and he chipped it, Put a 2 pin connector on a jumper with a removable connector on top (like a switch) so we could drive it home stock, Then when we put the turbo setup on it and installed the big injectors we could just slide the connector on the pins to activate the chip. Maybe the previous owner like to switch the setup around from one setup to stock? /ubbthreads/images/graemlins/dunno.gif
cheekychimp
East Sussex, U.K.
Quoting donniekak:
Yeah, my bad. That second switch looked like a hole with a wire going through it at that angle. So we were all right /ubbthreads/images/graemlins/laugh.gif
Quoting turbowop:
Yeah I was thinking that when I posted it too. I think the last time I saw that done the guy remote located the toggle to make it easier. I thought then that it was stupid, I mean it isn't like you do timing 'that' often surely. Still if what donniekak is saying is correct and you had that dual map EPROM you mentioned, the switch on the dash might be useful for swapping maps.
1442 came with a serial port cable like that too but never seen toggles like that.
dsm10o0
San Jose CA
I think that's my old ecu. I found it in a junk yard and sold it since I didn't know what it was. If you remove the toggle switch board, you'll see the 2 wires has been re soldered on cause it fell out when I opened it.
moduleunknown
Elk Grove, CA
Quoting dsm10o0:
Well, if you did re-solder, you managed to match the quality of every other solder joint. There's also a chip piggybacked and soldered on to the EPROM. I'll have to stare at this thing for a bit before I toss it my pile of random junk.
Whatever was going on with the ECU, one, maybe both maps were wrong for 777, or the timing/idle toggle was inadvertently flipped to the wrong position at some point (I have no way of knowing what those switches really did), but just putting in my DSMLink ECU instantly made a world of difference. I feel like I've made a huge leap forward in getting the car back to running as it should.
I had originally purchased DSMLink so that I could replace the ECU with a known good (repaired and tested) ECU, and to use as a diagnostic tool while getting the car sorted out and running correctly. So glad I did.
...just a few more things to sort out and then maybe I can start modding this car. Bone stock under the hood for now - still fun though! /ubbthreads/images/graemlins/smile.gif
jepherz
KC, Missouri
Ah, so there you go. No way to know what dual maps were for on the eprom though unless you actually read the code.
