clutch pedal welding?
MuffinMan7580 Member 570/1000
posted 08/10/11 06:55 PM
Quoting Nabeel:
From what I read before. Mostly advised to not weld & change it. But Are you sure about your issue. It seems you have leak or need to bleed your clutch line. Or may be bad clutch master/slave cylinder .
+1. From what I understand, if the pedal assembly wears out, you will still have a little bit of feel, just a lot of slow/dead play no matter how much you adjust it.
'91 Dark Cherry Talon TSI AWD-35R-->Sold
'91 Red Talon TSI AWD-EVO 3 16g
'92 GVR4 #570/1000-Project Daily Driver-HY35-->Under the knife '95 Toyota Pickup-Practicality at its finest
'01 CBR600F4i-The Toy
Posts: 142 | From: Fort Bragg, NC | Member Since: 08/06/11 | IP: (75.190.238.100) |
