Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » BITCHIN TOOL!!!! Coolant
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 1009445 posted 08/05/11 11:12 AM     Remind Me!  Send Private Message   Edit Post
i just used this. wow. if you ever had problems burping a cooling system, you need to get one of these.
A Veteran is some one who at one point in his or her life wrote a blank check made payable to the government for any amount up to and including my life.
Remember Freedom is not Free!
Edited by number3 (08/07/11 06:44 AM)
Posts: 7529 | From: krum texas | Member Since: 02/23/01 | IP: (205.201.101.84) | Report this post to a Moderator
Muskrat
665/2000
Galant VR-4 org Post #: 1009450 posted 08/05/11 11:34 AM     Remind Me!  Send Private Message   Edit Post
Interesting. How much did I run you?
That's basically how OEM's fill cooling and brake systems.
Brian L.
91 Galant VR-4 #665/2000
Posts: 2105 | From: Lexington, KY | Member Since: 06/13/04 | IP: (63.238.139.239) | Report this post to a Moderator
Andy_S
Overcomplicated
Galant VR-4 org Post #: 1009451 posted 08/05/11 11:50 AM     Remind Me!  Send Private Message   Edit Post
That would awesome to have working on my mr2. Burping the cooling is always a pain with the radiator and engine so far apart.
I found v8's...
Posts: 982 | From: Shithole Wisconsin | Member Since: 01/30/07 | IP: (174.253.246.216) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 1009453 posted 08/05/11 11:58 AM     Remind Me!  Send Private Message   Edit Post
Quoting Muskrat:
the fittings are top notch.
Chad989of2000
blows both ways and is skilled in magic with any mention of diarrhea
989/2000
141/1000
Galant VR-4 org Post #: 1009475 posted 08/05/11 01:11 PM     Remind Me!  Send Private Message   Edit Post
I expected to see a picture of a woman when I clicked on this thread.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'15 Forester XT Touring
-'14 Fiesta ST
-'93 NSX
Posts: 1775 | From: Livermore, CA | Member Since: 01/13/05 | IP: (130.76.96.149) | Report this post to a Moderator
number3
Galant VR-4 org Post #: 1009650 posted 08/06/11 04:31 AM     Remind Me!  Send Private Message   Edit Post
Thank you. Perfect tool for my V8 miata coolant issues!
Harry
Three-speed.com
Pictures here
Posts: 7623 | From: KoP, PA | Member Since: 06/26/01 | IP: (68.84.118.26) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 1009736 posted 08/06/11 06:14 PM     Remind Me!  Send Private Message   Edit Post
this millenia has been kicking my ass. i did a water pump, and i have been chasing an airlock problem for weeks. i even bought a lisle funnel tool that didnt work. i knew it was airlock, but i just couldnt fix it. plus, it is so hot here, i didnt have any real motivation. tried all kinds of ideas to burping the system. after putting all the fittings in place, it took like a minute to vacuum the system. then i let it sit for a couple minutes to make sure there were no leaks. then, put the hose in a bucket of water, turn the valve, and that sucker filled itself up in about a minute. amazing. i could tell it took in a couple more quarts of water. road tested, no more overheat. but now i think i got a broke motor mount. this car hates me. i think i gave it the equivalent of an enema
AnotherNewb
flutterdumper
Galant VR-4 org Post #: 1009806 posted 08/07/11 12:40 AM     Remind Me!  Send Private Message   Edit Post
Quoting Chad989of2000:
I was expecting a picture of Curtis.
Every terrorist killed is a victory for Wookalar
Posts: 1469 | From: Orlando, FL | Member Since: 04/26/10 | IP: (174.252.131.42) | Report this post to a Moderator
broxma
retard monkey strength
379/1000
Galant VR-4 org Post #: 1009908 posted 08/07/11 04:54 PM     Remind Me!  Send Private Message   Edit Post
Cut bottom off 2 liter soda bottle. Invert. Place in water neck. Fill with coolant/Water. Always worked for me.
/brox
I am big into recycling though and if your not into sacrifice or burnt offerings, you may want to stick with 93 octane.
/brox
Posts: 911 | From: San Antonio Tx | Member Since: 11/16/09 | IP: (99.52.72.193) | Report this post to a Moderator
DynastyLCD
Dissapointing Member
73/1000
881/1000
Galant VR-4 org Post #: 1009909 posted 08/07/11 05:02 PM     Remind Me!  Send Private Message   Edit Post
the air lift is great. my boss had a snap on one, pulls all the air out of the system til all the hoses are collapsed, even opens the thermostat if i recall correctly. he made it manditory to use these on every car. the only issue i ever had with them is sometimes having to add an oz or two to top off the system, but other than that its a pretty sure fire way to get all the air out.
- Phil
'92 Galant VR4 - 881/1000 - 2.0/FPgreen daily
'92 Eagle Talon TSi - 2.3/3052/1600's/killmode.
'05 Honda TRX450r - pack-a-punched woods weapon
You call down the thunder, and i'll reap the whirlwind.
Posts: 761 | From: Harwinton, CT | Member Since: 05/12/06 | IP: (75.28.149.234) | Report this post to a Moderator
number3
Galant VR-4 org Post #: 1009916 posted 08/07/11 05:16 PM     Remind Me!  Send Private Message   Edit Post
Quoting broxma:
/brox
You missed the point. I can pound a nail in to the wall with a rock too but a hammer will do the job better and quicker.
Harry
Three-speed.com
Pictures here
JNR
20/1000
Galant VR-4 org Post #: 1009937 posted 08/07/11 06:28 PM     Remind Me!  Send Private Message   Edit Post
What do you suppose the maximum vacuum (in-hg) should be using something like this? I mean, it seems there may be a point of putting too much in there and 25 in-Hg seems like a lot of vacuum, where as something like 10 may do the trick...Just hate to do something and boom spring a leak somewhere (freeze plugs, thermostat, radiator, etc.) that was not designed for so much vacuum. Sounds like it works with that amount, but be interesting to know.
Otherwise, looks like a good idea and something a DYI could easily put together...I'd like it for getting all the stuff out of the block and such (never had any issues with air, as running the engine with the cap off (funnel if you don't want it splashing around) for a bit generally expels any residual). However, this is with oem type systems...When your filler is lower than the thermostat opening, then you should probably be using a remote filler or expansion tank. Otherwise, good luck getting the air out.
Posts: 9741 | From: ca | Member Since: 04/23/04 | IP: (71.103.92.175) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 1009949 posted 08/07/11 07:14 PM     Remind Me!  Send Private Message   Edit Post
ok, here is what i tried:
it didnt work. and to answer the question about the amount of vacuum, this uses a venturi type of vacuum. iow, it uses shop air to blow over a venturi, so each system will pull as much vacuum as needed. this is not like an a/c vacuum pump, where it mechanically sucks out air, whether the system can take it or not. most systems are pressurized at 1 bar or more, so they can take the vacuum. also, it will show immediately if there are any leaks. i was fighting with this for 2 weeks. since it is so hot, even overnite, the system barely cooled, so not much coolant was going back in. i think if ambient was way cooler, the normal heat cycles would have bled the system. to me, it was worth the money. i was ready to pay more than double that for the car to work. i figger i got a great deal on a great tool that i will use over and over in the future. it does it so quick, it is really amazing.
JNR
20/1000
Galant VR-4 org Post #: 1009953 posted 08/07/11 07:19 PM     Remind Me!  Send Private Message   Edit Post
OK, that makes sense about the vacuum level, since it's "pulling" from the shop air passing it and will start to create a vacuum, sucking out the fluid.
I thought I reas somewhere on that original link though that they were holding 25 in-Hg to check for leaks. I imagine the cooling system components could take that, just with the way they make radiators now with the plastic end caps and all that, was a little concerned there.
I may try this on the galant though, since it's been sitting so long and imagine there's still residual coolant in the engine block and such. This would also work well if you were to replace dex-cool, let's say, with standard 'green' stuff, to eliminate contamination issues.
Speaking of sitting so long, little worried about it eating at the aluminum components, so anxious to get that thing flushed.
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 1010049 posted 08/08/11 12:10 AM     Remind Me!  Send Private Message   Edit Post
Quoting broxma:
/brox
I do that too lol. I just can't afford all those fancy tubes lol.
1992 Galant VR4
1996 Toyota Supra TT
Posts: 1908 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (173.3.29.99) | Report this post to a Moderator
Generated in 0.245 seconds in which 0.205 seconds were spent on a total of 14 queries. Turbo powered.
