Galant VR-4 Forums » Galant VR-4 » Newbies » 4g63 reliability
4g63 reliability
Vr4junkie
writes like a tard
385/2000
Galant VR-4 org Post #: 1009055 posted 08/03/11 03:17 AM     Remind Me!  Send Private Message   Edit Post
I'm new to the GVR4 and 4g63 and don't have to much experience with it. My question is how reliable is the 4g63?? I been doing some research and find a mix of good and bad reviews and some horror stories here and there especially with
2g 7 bolts ohh yea mine is a 6 bolt forgot to mention that.
My plans for the car are 2gpistons,FMiC,arp studsHG,ACL Bearings,B16g, stronger timing belt etc.....shooting for 320/350hp and 450 later down the road but not soon plan on stopping there . but before I start dumping money into this thing I want to see how they hold up to reliability at this power range.with proper maintenance like oil changes and the other little things.I plan on daily driving/weekend warrior
385/2000 click
Posts: 596 | From: Some wack town in CA | Member Since: 06/25/11 | IP: (208.54.39.169) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1009056 posted 08/03/11 03:27 AM     Remind Me!  Send Private Message   Edit Post
IMO, very reliable. The engine itself is durable as hell. Most issues I see crop up due to user error. Even most alternator issues are caused by aftermarket o2 housings with no heat shields causing too much heat, or using junk Autozone replacements once the OEM unit finally goes out. As long as proper maintenance is kept up on with these cars, they'll go a long way.
As far as my cars go, 1051 is still on the stock bottom end with just a metal headgasket and ARP headstuds and sees 30psi using pump/meth all the time when I drive it during the summer. It has almost 140k now. 503 has never even had the head separated from the block and is over 190k now. I don't really worry about driving it up to all the local ski resorts during the winter and make 2.5 hour drives to Seattle and Portland with it quite a bit. I carry tools, but that's a good idea with any 20 year old car anyway.
-Mark
1051
Posts: 11884 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.186.95.190) | Report this post to a Moderator
Vr4junkie
writes like a tard
385/2000
Galant VR-4 org Post #: 1009058 posted 08/03/11 03:59 AM     Remind Me!  Send Private Message   Edit Post
30 psi on stock bottom end nice .Have you ran into any other problem running that type of boost? ? By the way Props on 1051 hope 385 looks half as good one day
385/2000 click
Posts: 596 | From: Some wack town in CA | Member Since: 06/25/11 | IP: (208.54.39.166) | Report this post to a Moderator
dsm10o0
Member ++
705/2000
556/1000
Galant VR-4 org Post #: 1009060 posted 08/03/11 05:19 AM     Remind Me!  Send Private Message   Edit Post
Like wop said. it all depends on the maintenance. 4g63s are very reliable if taken care of right.
I plan on running 35psi on my stock block with compressions of 110psi or so on e85. Ive overheated the car numerous times on the same motor due to a bad fan and sensor. but other than that, its been reliable. Currently running 20 psi on 91pump gas. The car is my daily driver and gets abuse pretty much everyday.
91 VR-4 705/2000
92 VR-4 556/1000
03 Evo 8 -New toy
05 Nissan Armada toy hauler
Edited by dsm10o0 (08/03/11 05:20 AM)
Posts: 680 | From: San Jose CA | Member Since: 06/16/10 | IP: (24.23.203.127) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 1009063 posted 08/03/11 06:27 AM     Remind Me!  Send Private Message   Edit Post
Meh, 30psi on the stock bottom end is sooo last week .
Mine is still going strong at a tad over 35 on the stock bottom end. I've just had to change to H11 studs as it was starting to lift the head.
It's also run 131 in thr 1/4 with more in it I hope.
But it's really all down to the tune and how you set everything else up. If you do it wrong it can go boom way earlier than that.
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Posts: 944 | From: brisbane australia | Member Since: 02/13/04 | IP: (58.174.36.216) | Report this post to a Moderator
R34P3R62
Galant VR-4 org Post #: 1009123 posted 08/03/11 12:52 PM     Remind Me!  Send Private Message   Edit Post
Like everyone on this forum and the world will say, a motor will go a long way if cared for and maintenance is done routinely. You also have to look at the 4G63 from a mechanical stand point. What type of block is better, V-type or Inline? Majority says inline motors are better for strength and reliability while v6 or v8s are more suited for reducing the space an inline 6 motor takes making the vehicle more compact.
| | | IP: (24.8.42.31) | Report this post to a Moderator
Happy Birthday jepherz Galant VR4.org Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 1009130 posted 08/03/11 01:43 PM     Remind Me!  Send Private Message   Edit Post
All of my cars have always been very reliable, even beyond the engine itself. Two things that affect reliability of these cars are the massive number of systems on them (Turbo, ABS, AWS) which you're just increasing your number of gaskets, bolts, etc. and crappy maintenance and constant abuse from prior owners. People that have issues with reliability on these cars are usually the guys running a stock timing belt with some huge aftermarket turbo setup and dumping their ACT 2900 clutch at every stop light. Any car is going to have issues when you're doing that.
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.96) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1009139 posted 08/03/11 02:36 PM     Remind Me!  Send Private Message   Edit Post
IMO they are great, just have to keep up with the maintaince and these motors rock people that dont have good luck with them usually MOD the engine before the maintence and thats where the issues come out. Like turbowop said users error.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1631 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.122) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 1009159 posted 08/03/11 04:52 PM     Remind Me!  Send Private Message   Edit Post
Like they taught me many years ago in high school computer class, "Garbage In, Garbage Out". Build the car with quality parts (i.e. not Chinese ebay knockoffs), maintain it, and remember that you can easily double the stock HP output with a few bolt-ons so don't blame the car when the rear end that was made for 200hp and no dump the clutch launches breaks at 400hp while doing your best John Force impression. Same goes for the entire drivetrain.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (108.21.34.39) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 1009172 posted 08/03/11 06:56 PM     Remind Me!  Send Private Message   Edit Post
As everyone else has been saying, Very reliable. I traveled all over the east coast with my GVR4. I kept up on maintenance and it never let me down. Only major issue I had i the 4 years of owning her was my clutch exploding due to a failed design and abuse. I sold mine a month or so ago just to look for another one. They are great engines and will handle almost anything you throw at it if done properly
Cory McGee
1997 Jeep Cherokee - DD/Tow Rig
1992 Galant VR4 #623 - SOLD
1992 Galant VR4 #199 - Parted and Gone
Posts: 204 | From: Bradenton FL | Member Since: 01/27/08 | IP: (97.97.88.121) | Report this post to a Moderator
RedTwo
Rangi Kiwi
Galant VR-4 org Post #: 1009191 posted 08/03/11 09:00 PM     Remind Me!  Send Private Message   Edit Post
I went 400km without an oil pump... ...and it didn't die
Edited by RedTwo (08/03/11 09:00 PM)
Posts: 1917 | From: New Zealand | Member Since: 07/16/08 | IP: (210.54.239.228) | Report this post to a Moderator
4Grim
I deliver.
1948/2000
Galant VR-4 org Post #: 1009201 posted 08/03/11 09:57 PM     Remind Me!  Send Private Message   Edit Post
Any of the "saturn" motors mitsu produced which most were coded with the "4G" are very good motors. Majority of the time if you see a story of a failed motor..if you can trace its history its most likely because the owner didnt do proper maintenance or used poor quality parts or beat the living crap out of it without proper precaution of right parts and tuning. 4G63's have been running for more than 2 decades with minor design changes...thats says alot. I met 2 owners 1 with a n/a dohc 4g63 6g galant gs and a older guy with 4g64 mighty max...both over 500k miles with just routine timing belt, front & rear seals, and fluids changed. Same motor and tranny and they ran just as good the day they were brand new.
91 GVR4 1948/2000
96 Galant 5sp DOHC 4G64T
2002 Montero Limited
1998 Montero "Winter Package"
Posts: 2471 | From: Orlando FL | Member Since: 09/30/04 | IP: (97.101.15.118) | Report this post to a Moderator
Justin
Galant VR-4 org Post #: 1009204 posted 08/03/11 10:23 PM     Remind Me!  Send Private Message   Edit Post
You just have to be setup up properly. Alot of people make good power with a boost controller and some simple bolt-ons. They don't understand that tuning and larger fuel injectors become necessary even before the 275 whp mark, and before they know it, compression starts falling off and the rear view mirror starts filling with smoke.
But don't ask me. I wouldn't know anything about that.....
| | | IP: (208.54.38.145) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 1009206 posted 08/03/11 10:32 PM     Remind Me!  Send Private Message   Edit Post
I will also agree that the 4g63t and the E39a is an awesome combo. The only time my car was on a flatbed was when the t-case locked up. And that was because my mechanic did not tighten the fill bolt up and it fell out. ( needless to say, I now do all my own maintain.).
Even when I exploded 1st gear, I was able to find 3rd and limp it home. And that happened because I dropped the hammer with 4 people and well over 300whp.
Properly cared for, they will last forever.
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (216.221.64.3) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1009208 posted 08/03/11 10:43 PM     Remind Me!  Send Private Message   Edit Post
Quoting 4Grim:
Incorrect buddy, you got your info mixed up. The 4g61/62/63/64, etc motors are in the "Sirius" family, 4g33, 4g32, 4g37,etc are "Saturn" engines. The "4" represents it being a four cylinder and "G" for gasoline fuel.
Edited by raptorreed (08/03/11 11:03 PM)
Posts: 2708 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (198.228.209.222) | Report this post to a Moderator
ma70t
Newbie
Galant VR-4 org Post #: 1009289 posted 08/04/11 03:04 PM     Remind Me!  Send Private Message   Edit Post
very reliable if it was taken care of. im on 21+psi with a 50 trim turbo been nothing but fun just minor bugs hahaha but its a good motor
Posts: 10 | From: springfield va | Member Since: 10/07/10 | IP: (72.219.252.9) | Report this post to a Moderator
Galant VR-4 org Post #: 1009348 posted 08/04/11 06:26 PM     Remind Me!  Send Private Message   Edit Post
Quoting vr4junkie:
Strength wise, the 4G63 is good for about 400 hp in stock form (and plenty of people have made even more power than that on the stock bottom end) so 300-350 hp should really not pose any issues whatsoever as long as the engine is in good condition.
There is the 'crank walk' phenomena supposedly associated with 7-bolt engines but no-one has really come up with a definite conclusion as to the cause of crank walk and it has occurred in both 6-bolt and 7-bolt engines.
The biggest issue in my opinion as far as the reliability of this engine is maintenance. Take a look through this forum and others and you will find countless instances of guys buying a 4G63 powered car that has issues and before they resolve those issues and get it running well they pour a shitload of money into turbos intercoolers, injectors, pumps, pistons, rods. If it doesn't run well with a 14B in it because the base timing is set wrong and the cams have jumped a tooth, the AFR is off and the plugs are gapped wrong then it won't run well with an FP Green and a fancy FMIC and the same issues.
When these engines are looked after they run just great. I just did a 160 mile round trip in my NA powered 4G63 Galant GTi and on the way home I took off next to a Renault Clio Sport from a stop light. He was alone in a 187 bhp car that is considerably lighter than the Galant and I was four up with just 145 bhp under the hood. I let up at about 90 mph but he never got away and my car was built in 1989. I reckon his car was built in 2007 or later.
Edited by cheekychimp (08/04/11 06:28 PM)
Posts: 7314 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (78.147.99.227) | Report this post to a Moderator
Vr4junkie
writes like a tard
385/2000
Galant VR-4 org Post #: 1009487 posted 08/05/11 02:14 PM     Remind Me!  Send Private Message   Edit Post
That's awsome to hear that theses motors are reliable one thing I'm after is reliability I plan on taking my time on this car and building it right and not half ass it.
My Mod list so far wat kind of Hp can I pull safe with this set up? And what else I'm I missing
2G nippon pistons
Gates racing timing belt
Acl race bearings M/R
Walbro 255 pump
Arp head studs
Cometic head gasket
750cc injectors
Xtd Stage 4 clutch
Big 16g
FMiC
2g mainfold
Gasket set
6 bolt crank journals damaged on old one
385/2000 click
Posts: 596 | From: Some wack town in CA | Member Since: 06/25/11 | IP: (208.54.39.224) | Report this post to a Moderator
IanM
Galant VR-4 org Post #: 1009502 posted 08/05/11 03:19 PM     Remind Me!  Send Private Message   Edit Post
Say no to Gates, and steer clear of Topline. My .02
Posts: 66 | From: CFB Petawawa, Ont | Member Since: 06/30/11 | IP: (67.193.69.121) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1009521 posted 08/05/11 04:22 PM     Remind Me!  Send Private Message   Edit Post
OEM belt works fine on any type of build.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2708 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (198.228.209.49) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1009524 posted 08/05/11 04:28 PM     Remind Me!  Send Private Message   Edit Post
Quoting raptorreed:
Quoting 4Grim:
^^ What he said.
I actually wrote out just about that very same reply and posted as soon as I saw his post, but didn't check that someone else could have covered what I said already haha.
Posts: 2090 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.14.191) | Report this post to a Moderator
Vr4junkie
writes like a tard
385/2000
Galant VR-4 org Post #: 1009527 posted 08/05/11 04:34 PM     Remind Me!  Send Private Message   Edit Post
So there's no need for a Performance timing belt like Gates,Greedy,HKS will the OEM hold up fine to the abuse ii throw at it?
385/2000 click
IanM
Galant VR-4 org Post #: 1009538 posted 08/05/11 05:37 PM     Remind Me!  Send Private Message   Edit Post
I would say that aftermarket belts such as HKS are purely for bling factor. You had mentioned your build will be budget oriented, so I doubt something like that would appeal to you. I would go OE.
You may want to try looking at something used as for as shortblocks go. Here is a good start- And I'm sure you could find a few other 4G63-Based Forums on the net (with a classifieds sect).
That being said, I'm positive you could also find a lot of members making tons-o-power from the stock bottom end.
Later!
Generated in 0.331 seconds in which 0.262 seconds were spent on a total of 14 queries. Turbo powered.
