Galant VR-4 Forums » Galant VR-4 » Newbies » 16g turbo and super 20g
galantgs
Galant VR-4 org Post #: 1001488 posted 06/25/11 12:42 AM     Remind Me!  Send Private Message   Edit Post
Will the hotside of a 16g fit on the super 20g? Help...
| | | IP: (107.62.146.71) | Report this post to a Moderator
dsm10o0
Member ++
705/2000
556/1000
Galant VR-4 org Post #: 1001490 posted 06/25/11 12:53 AM     Remind Me!  Send Private Message   Edit Post
Is it a td05 or a td06 20g? If its a td05, itll fit.
91 VR-4 705/2000
92 VR-4 556/1000
03 Evo 8 -New toy
05 Nissan Armada toy hauler
Posts: 680 | From: San Jose CA | Member Since: 06/16/10 | IP: (24.23.203.127) | Report this post to a Moderator
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 1001491 posted 06/25/11 12:56 AM     Remind Me!  Send Private Message   Edit Post
it also depends on wat kind of 16g you have.... it will fit ONLY in B16g and E316g... NOT in S16g
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 601 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (108.68.109.184) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1001537 posted 06/25/11 10:53 AM     Remind Me!  Send Private Message   Edit Post
^^ Why do you say that? They'll all fit as long as it's a td05h hotside.
Ryan W.
Posts: 433 | From: Granby, MA | Member Since: 09/27/06 | IP: (71.192.230.179) | Report this post to a Moderator
Tre3zy
637/2000
Galant VR-4 org Post #: 1001539 posted 06/25/11 11:07 AM     Remind Me!  Send Private Message   Edit Post
i was talking about this one.... i think they were saying that if you use a S16G hotside that the new 20gwheel will hit the back plate and will need to be machined...
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
donniekak
Member ++
Galant VR-4 org Post #: 1001568 posted 06/25/11 02:08 PM     Remind Me!  Send Private Message   Edit Post
That isn't what a hotside is. The hotside is the turbine housing. As long as a turbo has a tdo5h turbine, you can run it with any td05h turbine housing. A 14b, small 16g, big 16g, evo 3 16g, 18g, 20g, can all use the same turbine housing, as long as they run the td05h turbine.
Posts: 743 | From: surprise az | Member Since: 01/01/09 | IP: (24.56.32.42) | Report this post to a Moderator
Brunoboy
Jesus Clips
352/1000
556/1000
Galant VR-4 org Post #: 1001573 posted 06/25/11 02:36 PM     Remind Me!  Send Private Message   Edit Post
By using a small 16g hotside, Since its still a tdo5h hotside, Cant you pair it with a 20g tdo5 wheel and comp housing?
dsmtuners thread on conversion
and by using these pieces.
20g tdo5h comp wheel and comp housing.
556/1000 KG 8/10/13 .... Sold
352/1000 Summit White sold in 2011 and was totaled by new owner......
92 Eclipse Gsx R.I.P
96 Eclipse Gsx Sold
Edited by brunoboy (06/25/11 03:33 PM)
Posts: 2880 | From: San Bruno,CA Home of SFO | Member Since: 04/25/08 | IP: (74.51.145.216) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1001626 posted 06/25/11 06:48 PM     Remind Me!  Send Private Message   Edit Post
my understanding is you can only use a 20G compressor wheel on the 'super back' turbo cores/cartridges, ie small and big 16G. The 14B and earlier TD05H's don't have the extra space machined from the core.
Posts: 2080 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.43.104) | Report this post to a Moderator
Galant VR-4 org Post #: 1001630 posted 06/25/11 07:01 PM     Remind Me!  Send Private Message   Edit Post
also I've ordered the 20G wheel, machined Evo III compressor housing and genuine MHI rebuild kit from kando-dynamic aka kinugawa turbo and found their service very quick, however the Evo III compressor housing is obviously a copy, but the quality looks to be just as good as the original compressor housing. I am unsure of the origin of the compressor wheel, but I assume it isn't genuine MHI.
As my original VR-4 turbo is a 'big 16G' using the 'super back' style wheel, the 20G wheel simply swapped in place. You will not be able to fit a 20G (or even a big 16G wheel) on a 14B turbo core/cartridge, UNLESS you machine out the core to suit the larger diameter/shape of the underside of the big 16G/20G wheels. I am not sure about the small 16G which is why I haven't mentioned it yet - to be honest I don't think I've ever seen a small 16G turbo, all the Evolution VR-4s, Lancer Evo1/2/3 I have come across have big 16G turbos. I think perhaps the small 16G is an American thing rather than on JDM vehicles. I would have assumed being a 16G they too would be a 'super back' wheel, but those links above are suggesting otherwise.
donniekak
Member ++
Galant VR-4 org Post #: 1001677 posted 06/26/11 12:35 AM     Remind Me!  Send Private Message   Edit Post
Again people, this is a hotside. And a td05h hotside clamps onto any td05h turbo.
For the people converting turbo's. The big 16g, evo3 16g, 18g, and 20g, all have 68mm exducers. So any bearing housing/backplate, for those turbo's can be used for any other of the group, with just a compressor housing change.
1 registered and 18 anonymous users are browsing this forum.
Generated in 0.252 seconds in which 0.226 seconds were spent on a total of 14 queries. Turbo powered.
