compressor outlet gasket question
AnotherNewb
Orlando, FL
Any kind will do. What color is your J-pipe? /ubbthreads/images/graemlins/grin.gif
AnotherNewb
Orlando, FL
I will use a light film of sealer on the j pipe side of the gasket, but I have successfully sealed turbo outlets without a gasket using only sealer. One more tip is I like to let the silicone set up for a little bit, like 15 min before installing the gasket. It allows it to " thicken" a bit and prevents it from squeezing out. Remember, I said thin film. If it squeezes out your using too much.
RTV is for sealing connections without a gasket.
Gasket sealant is for sealing paper gaskets.
Either use just RTV or the paper gasket with sealant. For pressurized connections I prefer to use a paper gasket with sealant.
yeti
san diego california
Ok I used just the gasket it was a metal gasket so I don't know.
I got pictures of it, it bolted up and fine and sealed it but kinda blocked the flow of the turbo outlet (visually)
Should I post pics I'm not very sure if it will effect the flow that much.
It covering the turbo outlet by about a half inch maybe less
jepherz
KC, Missouri
Are you sure you put it on the correct way? The outlet of the turbo isn't directly centered with relation to the two bolt holes...
turbofonz
Granby, MA
I haven't used a gasket there in years. Just RTV it. But yeah, that gasket isn't on the right way.
yeti
Quoting turbofonz:
Really rtv is that strong??
I know it says you can on the package , but I still wondered.
524of1000
San Antonio, Tx
I've only used RTV there. Granted I only push about 17psi at the moment, I've yet to have a boost leak there.
