90 Oil Cooler
Hertz
Chicago, IL
Can someone identify what the tab is adjacent to the filter port on the 90 cooler?
It is broken in this pic, but I'm not sure it is a necessary piece.
OldHairyBastard
Northern Chicagoland Area
It almost looks like it is just a bad casting. My filter doesn't have that on it.
toybreaker
iconoclast
I think it was a tab for a harness clip to keep the oil pressure switch/sender wiring harness from getting fouled up in the accessory belts. /ubbthreads/images/graemlins/dunno.gif
That style has the extra small port on the bottom side for the oil pressure gauge sensor. That broken piece had a hole to attach a clip to hold the harness for the gauge sensor. Not normally used on a GVR4, but you could.
CP
West Simsbury, CT
You don't need that tab. I broke it off of my last one too. Don't worry about it; it serves no purpose.
OldHairyBastard
What car/motor did that come off of? What is the part #? I just want to see which one is cheaper from the dealer and if they are still available.
CP
West Simsbury, CT
Brand new from JNZ for around $60.
MD132912 is the one that has the extra sender hole tapped and has that bracket. I bought a new one maybe 1.5 years ago.
3Diamond
Vancouver
Does caps even have the 90's oil filter housing? I couldn't find it when i was looking for the hose part#'s.
OldHairyBastard
Thanks. It makes it nice and easy to just ask for the part number.
Yes, it does. Section 12-110, item 04102A. Then select by the date of production. The 90 style is the first part listed.
This is the harness that clips on there.
