I did this job last night... had my GVR4 alternator replacement cherry popped. Not quite as easy as folks make it sound, IMHO. Just hand tools, cramped. cold garage, etc. Biggest PITA was the proximity of the oil filter to the alt. pivot bolt. It makes it very hard to see where it is the first time you do it, and pretty hard to thread the pivot bolt back for installation.
I'd recommend doing an oil change the same time as your alt. removal. /ubbthreads/images/graemlins/crazy.gif Sounds silly but having the oil filter off would make the bottom of the alt. much more accessible.
Also did the PS pump and brackets method of removal. Even had to move a little relay mounted on a bracket near at the top corner of the radiator to make sure I wouldn't damage radiator fins on its way out. Not looking forward to doing that job again. Once A/C comes out of this car, I'm going to seriously consider the alt. relocation bracket. The factory location is so dang close to the exh. manifold the poor little alt. has little chance of a long healthy life.
-Jim B.
280/1000
1432/2000
