Galant VR-4 Forums » Galant VR-4 » Newbies » Wiper Motor Help
Wiper Motor Help
TheWolf
Newbie
Galant VR-4 org Post #: 1242964 posted 06/13/18 10:33 PM     Remind Me!  Send Private Message   Edit Post
I have a 1987 JDM Galant VR4
The wiper motor quit. I canít seem to figure out how to disconnect it from the linkage. There must be a trick or tip that I am missing. If anyone has some advice to offer i would be most appreciative.
Posts: 15 | From: Streamwood, IL | Member Since: 04/09/18 | IP: (69.47.206.78) | Report this post to a Moderator
91vr4auto
Newbie
Galant VR-4 org Post #: 1242968 posted 06/14/18 01:32 AM     Remind Me!  Send Private Message   Edit Post
There's a 10mm(?) nut on the end of the motor spindle that holds the linkage captive. You will need to pop out the inspection cover above it to get at it because it isn't easy to get to.
Posts: 14 | From: New Zealand | Member Since: 01/29/18 | IP: (49.225.196.97) | Report this post to a Moderator
TheWolf
Newbie
Galant VR-4 org Post #: 1242973 posted 06/14/18 05:47 AM     Remind Me!  Send Private Message   Edit Post
I was able to get that far. Can barely get to the nut. Curious if there is a trick to getting that little bastard off.
91vr4auto
Newbie
Galant VR-4 org Post #: 1242974 posted 06/14/18 07:48 AM     Remind Me!  Send Private Message   Edit Post
It was a hassle, as the spindle wants to rotate as you're trying to loosen it. I think I used a 1/4" ratchet with an deep socket, and held on to the wiper arm to stop the spindle rotating. Getting the arm back on in the correct position is a barrel of laughs as well.
TheWolf
Newbie
Galant VR-4 org Post #: 1242975 posted 06/14/18 08:42 AM     Remind Me!  Send Private Message   Edit Post
I was able to get the nut off through the access hole, but the motor is screwed onto the assembly. Is there no other way to detach it from the linkage to get it out? I tried to upload a photo but apparently I am not smart enough to do that either...smh
Posts: 15 | From: Streamwood, IL | Member Since: 04/09/18 | IP: (152.133.8.197) | Report this post to a Moderator
Galant VR-4 org Post #: 1242977 posted 06/14/18 08:48 AM     Remind Me!  Send Private Message   Edit Post
You have to make sure your photo is less than 2 mB in size, then it should work. Hassle in today's world with huge size pictures.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10606 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
TheWolf
Newbie
Galant VR-4 org Post #: 1242982 posted 06/14/18 11:22 AM     Remind Me!  Send Private Message   Edit Post
91vr4auto
Newbie
Galant VR-4 org Post #: 1242995 posted 06/14/18 11:28 PM     Remind Me!  Send Private Message   Edit Post
I undid the four bolts holding the wiper motor assembly to the car to allow a better shot at it, then wiggled the arm off the spindle where you've drawn the circle. It's splined and a very snug fit, but it did come off eventually.
Posts: 14 | From: New Zealand | Member Since: 01/29/18 | IP: (49.225.193.86) | Report this post to a Moderator
TheWolf
Newbie
Galant VR-4 org Post #: 1242996 posted 06/15/18 12:36 AM     Remind Me!  Send Private Message   Edit Post
Well. Finally got it off the arm. After the second try putting on the new one I still couldnít get the position right. I took it off and called it a night. And have to go to the hardware store to replace the nut that dropped into the 7th dimension. Barrel o laughs. For sure. Thanks for the assist folks. Im getting closer
0 registered and 24 anonymous users are browsing this forum.
Generated in 0.024 seconds in which 0.007 seconds were spent on a total of 13 queries. Turbo powered.
