Galant VR-4 Forums » Galant VR-4 » Newbies » Evap smoker for boost leak testing
Nebraska
1099/2000
Galant VR-4 org Post #: 1239025 posted 08/12/17 08:37 PM     Remind Me!  Send Private Message   Edit Post
Has anybody tried this? Did it work good?
I think I want this one...seems pretty choice!
Clicky-click-click
1099/2000 Summit white
"Do it once, Do it right."
Edited by Nebraska (08/12/17 10:47 PM)
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1239036 posted 08/13/17 02:44 PM     Remind Me!  Send Private Message   Edit Post
Just curious if this method will still work for the smaller leaks...these evap smokers have like 1 psi regulator to push the smoke. Is this a bad idea for a turbo car?
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (66.87.143.9) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1239044 posted 08/13/17 11:09 PM     Remind Me!  Send Private Message   Edit Post
I made my own and used a small portable tyre inflation compressor to push the smoke in. It worked great and caused no issues.
It's not going to find leaks that only show up at high boost levels, but good for the small stuff and saves trying to spray soapy water into hard to reach areas when boost leak testing.
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 119 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (58.28.212.87) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1239045 posted 08/14/17 12:31 AM     Remind Me!  Send Private Message   Edit Post
That's good to hear, did you use mineral oil?
Also, I think I have boost leak near the injectors or intake mani - head seal is non existent.
My system completely bleeds from 20psi to 0 in about 5-6 seconds.
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (66.87.142.192) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1239047 posted 08/14/17 03:23 AM     Remind Me!  Send Private Message   Edit Post
Yep, common leaks are:
- Injector seals where they sit into the head
- Throttle body shaft seals
- Throttle body gaskets
And then everything else, but those are nearly always an issue in these cars.
Generated in 0.012 seconds in which 0.002 seconds were spent on a total of 13 queries. Turbo powered.
