Galant VR-4 Forums » Galant VR-4 » Newbies » No Start [FIXED]
No Start [FIXED]
kdott96
733/2000
Galant VR-4 org Post #: 1236782 posted 04/25/17 08:46 PM     Remind Me!  Send Private Message   Edit Post
On Sunday my vr4 turned off at a red light, and refused to turn back on ever since. The battery and alternator are good, and it does attempt to start, but never does. Any ideas?
Edited by kdott96 (04/26/17 08:05 PM)
Posts: 34 | From: Queens, NYC | Member Since: 03/02/16 | IP: (2604:2000:a0c7:e) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1236784 posted 04/25/17 09:28 PM     Remind Me!  Send Private Message   Edit Post
bad coolant temp sensor, blown fuel pump, bad CAS, bad ISC motor causing the ecu to burn out, blown head gasket, snapped timing belt.
138/2000
Posts: 3518 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1236785 posted 04/25/17 10:03 PM     Remind Me!  Send Private Message   Edit Post
Coolant sensor is good
CAS is good bc it worked on my GSR
Even double checked the relays, and nothing wrong there
Head gaskets/timing belt is perfectly fine
I have a strong suspicion that the ECU burned out, because the car would give me trouble starting prior to this.. just not to sure how to get around to fixing it
91' G-GSR
91' GVR-4 733/2000
Galant VR-4 org Post #: 1236793 posted 04/26/17 07:36 AM     Remind Me!  Send Private Message   Edit Post
Validate the three needs to run:
Got fuel?
Got spark?
Got compression?
Rule out what you have and concentrate on what you don't.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10636 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1236794 posted 04/26/17 09:07 AM     Remind Me!  Send Private Message   Edit Post
Also, get the manual, there is a PDF somewhere, and it has a walkthrough in the fuel section just for this situation.
Posts: 374 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1236801 posted 04/26/17 08:04 PM     Remind Me!  Send Private Message   Edit Post
Thank you mates, here was the problem:
(excuse the blurr, camera was not cooperating)
91' G-GSR
91' GVR-4 733/2000
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1236816 posted 04/28/17 06:47 AM     Remind Me!  Send Private Message   Edit Post
Looks like a blade fuse blown in half? Why is that in the trunk? Isn't even on the side of the fuel pump. All fuses should be as close to the battery as possible.
1992 Nile black w/sunroof
Posts: 5826 | From: central Indiana | Member Since: 08/06/02 | IP: (128.210.106.178) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1236817 posted 04/28/17 09:22 AM     Remind Me!  Send Private Message   Edit Post
Technically it was close to the battery (it was placed in the trunk), but when I got the car I moved it back to the front
91' G-GSR
91' GVR-4 733/2000
Generated in 0.319 seconds in which 0.308 seconds were spent on a total of 14 queries. Turbo powered.
