Galant VR-4 Forums » Galant VR-4 » Newbies » Pull engine to replace oilpump?
gvr4144
144/2000
Galant VR-4 org Post #: 1236635 posted 04/17/17 08:37 AM     Remind Me!  Send Private Message   Edit Post
Hey guys, I'm doing a timing belt and headgasket overhual because of a crank seal leak. I was planning on doing the oilpump aswell. My question is weather or not I have to pull the block to put a new oil pump on?
Usdmgang
1997 GST Spyder- dd 93k
1997 GST- sold
GVR4 144/2000- race car
Posts: 168 | From: loveland Colorado | Member Since: 01/26/14 | IP: (166.137.126.57) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1236637 posted 04/17/17 09:04 AM     Remind Me!  Send Private Message   Edit Post
I would assume not since people have performed the BSE with the motor in. I assume you already have the balance shafts gone? You will have to drop the pan for sure to un-bolt the oil pickup tube.
Thom
Posts: 680 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
gvr4144
144/2000
Galant VR-4 org Post #: 1236638 posted 04/17/17 09:34 AM     Remind Me!  Send Private Message   Edit Post
I still have my balance shaft belt for drivability. I couldn't find anything if someone has done it with the bs.
Usdmgang
1997 GST- sold
"Just to be pedantic!"
Galant VR-4 org Post #: 1236639 posted 04/17/17 09:39 AM     Remind Me!  Send Private Message   Edit Post
If you still have the balance shafts it will be hard to do it in place, as when you pull the oil pump the rear shaft comes out with it and you'll find the driver's side frame rail is in the way.
How many miles has the engine done? Is there a reason you need to replace the oil pump, such as low pressure etc? If the oil pump is working fine currently I would just leave it in place and replace the crank seal and call it a day. The oil pump is hardly a wear item like the water pump or timing belt etc. It should last the entire life of the engine.
Posts: 2043 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (23.91.152.223) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1236641 posted 04/17/17 01:08 PM     Remind Me!  Send Private Message   Edit Post
Yup, just replace the seals. It can be done in car, but I wouldn't bother unless there was something actually wrong with the oil pump itself.
-Mark
1051
Posts: 11858 | From: Yakima, WA | Member Since: 04/29/01 | IP: (71.83.231.158) | Report this post to a Moderator
gvr4144
144/2000
Galant VR-4 org Post #: 1236643 posted 04/17/17 03:13 PM     Remind Me!  Send Private Message   Edit Post
It's an aftermarket high volume pump made by I think Toga or something like that. The motor has about 17k but the oil pump has seemed to always whine under acceleration since I've owned the car. About 10k miles. I just really would like to go with an oem for logevity.
Usdmgang
1997 GST- sold
Galant VR-4 org Post #: 1236645 posted 04/17/17 04:32 PM     Remind Me!  Send Private Message   Edit Post
Follow these instructions - click
You'll need to remove the transfer case and drop the exhaust and oil pan and lower the engine down a bit.
gvr4144
144/2000
Galant VR-4 org Post #: 1236646 posted 04/17/17 05:39 PM     Remind Me!  Send Private Message   Edit Post
Quoting turbowop:
Yup, just replace the seals. (It can be done in car), but I wouldn't bother unless there was something actually wrong with the oil pump itself.
I like Marks optimism saying it can be done lol. Seeing how I do already have a kevlar bs belt and I wanna keep the bs for smoother idle/driving, I'm going to go for it.
Usdmgang
1997 GST- sold
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1236651 posted 04/18/17 01:23 AM     Remind Me!  Send Private Message   Edit Post
It's not just optimism. I've done it.
Back in '03. Balance shaft removal. I can't remember if it's needed or not but I pulled the whole front cover and oil pump off the engine. Hard to believe but I've still never had the shortblock out of my car.
-Mark
1051
Galant VR-4 org Post #: 1236667 posted 04/19/17 10:33 AM     Remind Me!  Send Private Message   Edit Post
What are you saving from not pulling the engine? The only reason I wouldn't pull it is if I didn't have a hoist.
Posts: 1375 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2604:2000:1480:8) | Report this post to a Moderator
gvr4144
144/2000
Galant VR-4 org Post #: 1236715 posted 04/21/17 01:46 PM     Remind Me!  Send Private Message   Edit Post
I don't have a garage is the main reason..
Usdmgang
1997 GST- sold
Posts: 168 | From: loveland Colorado | Member Since: 01/26/14 | IP: (173.46.78.140) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1236716 posted 04/21/17 02:19 PM     Remind Me!  Send Private Message   Edit Post
Quoting gvr4144:
Remove them. There's no noticeable decrease in "drivability" with them removed, but there is a marked improvement in "reliability".
97 CBR900RR
2012 Hyundai Veloster
Posts: 3505 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.88.86) | Report this post to a Moderator
1 registered and 19 anonymous users are browsing this forum.
Generated in 0.024 seconds in which 0.004 seconds were spent on a total of 13 queries. Turbo powered.
