is this a vr4 4g63t?
vince232
Bacoor
hi guys im new in modifying cars. i just bought a 4g63t for a good deal and the owner said it came from an eclipse. but some are saying it is from a 6th gen vr4
so now i have the engine installed in a lancer and i find it somewhat slow. so i want to identify first which car did the engine really came from and start from there what upgrades to get
can you help me identify which car did this really come from? thanks here are the pics of the engine and turbo
stock engine except for the pipings. we needed to mod it to maximize the benefit from the evo 3 hood that i got
Indianapolis, IN
What all did you transfer onto the engine? the Intake Manifold and Thermostat housing do not look like 6th Gen Galant or 1g Eclipse in the US.
vince232
Bacoor
not so sure. what i know is that the engine is all stock except from the stainless pipes.
they needed to mod the pipes so it can fit in a lancer and maximize the benefit from the air vents of the evo 3 hood.
i also know the ecu code which is e2t37876
FlyingEagle
THE Ottawa
Picture of the ECU circuit board and numbers on the board and case.
Is there an Eprom chip in the ECU (a special socket is installed and can allow removal of the Eprom chip for this)?
Picture of the circuit board with particular attention to the large cylinders (capacitors) because they are very suspect if they have not been inspected and if found to be original, replaced in short order.
We can tell you what ECU you have by the numbers, and what if any chip is installed.
Also, if your ECU has two circuit boards, then that is also a defining feature.
We have a bunch of questions and pictures will speak 1000 words, so we can definitely give you a hand!
Picture of the left side (when standing in front of the car) of the cylinder head. (should be a designation of the type of head - 16, 18, 20 to indicate 1.6L, 1.8L etc)
Intake looks like the Evo3 style.
Picture of your mass airflow sensor sticker (this tells us what type it is) and whether there is a honeycomb anti turbulence device still installed inside.
Picture of the top of the fuel injectors (blue, yellow, pink, grey - this is what we are looking for, and shape - the picture will tell us that).
Once we know what head you have and what intake, we can tell you if the gaskets between the two should even line up.
Also, can you tell us if the motor mounts are located on the transmission bellhousing/case or the motor block?
If it looks like motor mounts are on the transmission side, then be sure to look and see if the block has any mounting points that would have been used previously to mount the engine.
Thom is spot on, because I also, have never seen that thermostat housing or outlet setup.
Once we know what motor you have, ECU running it, and MAF and any chip compensation, then we may be able to point you in the direct of any massive discrepancies (parts that should not be used together or just maintenance and checking all base settings/boost leaks, etc).
Your BOV (blow off valve) could be installed incorrectly or not working properly, vent filter on the side of the rocker cover should be recirculated, PCV valve could be sticking, spark plugs could be in need of changing, base timing could be off, mass airflow sensor could be mismatched, injectors could be the wrong size for what the ECU wants them to be, the list continues. This is why we have to start with what you have and move forward!
FlyingEagle
THE Ottawa
I just spotted a setup very similar to this (lancerman) as he was posting on the colt site.
The motor even had the same thermostat/outlet setup installed, and it was on a Summit van aka the RVR.
I was at work when I posted, and likely missed the four extra photos.
Will still be good news to confirm the other details I mentioned above, just so our new member can find out exactly where his setup stands. Nothing better than tuning around unknown variables. /ubbthreads/images/graemlins/banghead.gif
vince232
Bacoor
hi allanl so are you positive that this is a jdm rvr?
haha i started this thread since there are guys who says this are from vr4
brisvr4
brisbane australia
Yep, as per above posts this is from a RVR sports gear auto.
vince232
Bacoor
Is it this click
Or the hypersport which i think is above 200hp
Also can i fit a td05 without changing injectors? Or i need to upgrade the injectors first?
vince232
Bacoor
Please guys tell me the engine i got is this
The Hyper Sports Gear R trim package in Japan used the drivetrain of the first Mitsubishi Galant VR-4; the 4G63T 2.0 L 16V DOHC turbo straight-4 mated to either a four-speed auto or a five speed manual which was not offered in North America. Open front and rear differentials were used on vehicles equipped with 4WD. Power output was rated at 170–184 kW (231–250 PS; 228–247 hp
AllanL
NV
Quoting vince232:
if you base it only on the valve cover, it is a galant vr4 valve cover.
all other parts of the engine indicate otherwise.
your ecu is from an RVR HSG [Hyper Sports Gear] 4G63.
MAF is 609.
turbo is probably a TD04HL-13T.
injectors part number is MD186379 INP-018 [black top 450cc like the 95~99 Eclipse?].
before upgrading anything, do all the maintenance items first.
going bigger on the turbo [without any other upgrades] is not a 'wise' first step...
just my honest opinion...
vince232
Bacoor
Hmm so this is a jdm right? 230ps? Is it a 7 bolt?
Aside from changing all the filters belts and oil. What should i change first before the turbo?
vince232
Bacoor
Ah. Oh yeah im done with all of that.thought i needed to change some other parts before the turbo. Im aiming for maybe about 250 to 280hp
Hoping i only need to change turbos. Injectors and a good tune
strokin4dr
Savannah, GA
Post some pics of the lancer. Where did you buy the engine and hood?
vince232
Bacoor
here. bought a galant 7g with the said 4g63t for about 1200 usd then bought a lancer for another 1200 usd then transfered the engine to the lancer
inside the hood
