Part under mass air flow meter
rodgalant
New member
mru
Hi,
Can anyone tell me which sensor is under my air flow meter? Or identify the part number.
The engine is a 4G63 for a galant super saloon 04 1997cc EA2A
Regards
Toronto, ON, Canada
You must live in a region where leaded fuel is still sold, therefore your car does not have an O2 sensor nor catalytic converter. That part is your fuel mixture adjustment trim-pot, because the ECU cannot rely on feedback information from the O2 sensor to adjust the air/fuel ratio on the go. On older models this is usually mounted to the firewall or near the throttle body somewhere. Basically I would just leave it alone unless your car is obviously running too rich or too lean.
