Galant VR4 Gates Racing Accessory Belts
FlyingEagle
THE Ottawa
Looking to replace all three accessory belts on my engine.
Timing belt is new OEM.
My motor is a 6 bolt, GVR4 import with a C53A AC compressor (uses same as, GVR4 tensioner assembly circa 91.06.1-92.05.3).
Found the Gates Racing belts (Blue top surface) in the following flavors:
A/C - AcDelco 4K360 installed now
K040360RB (C53A length) E.L. = 917 mm
K040365RB (GVR4 length) E.L. = 928 mm
ALTERNATOR
K040390RB E.L. = 993mm
Non-Racing series Not Blue top
POWER STEERING
9265 AUTO V-BELT XL E.L. = 673mm
GVR4 specification for belts per ASA:
AC to CK = MB439336 = 920mm effective length 4PK920
ALT to WP to CK = MD187458 = 995mm effective length
PS to WP = MD178430 = 660mm effective length
Have any of you installed these belts and if so, how are they doing so far?
My motor will see mainly street use but I like the idea of a belt designed for a higher output engine.
I can go with OEM belts too.
Gates lists the belts as remaining stock only, and I have leads at my fingertips currently.
As a side note, what belt tension checking tools are people using currently?
I'd like to invest in one or two for work and home use but haven't seen a belt tool used in a long time ... back to the V belt style days. Not sure what tensions are mandated on these little style belts, as I go by feel/stretch distance and ear (time to check tension and pulleys on higher mileage systems).
Here's a few tensioner checkers and the belt/pulley wear indicator, I found online:
Gates:
Wear indicator tool - Click me
Tension tester 100-320LB Gates 91132 Belt Tension Tester
Tension tester #2 Auto and LD 50-150LB Gates 91107 Belt Tension Tester
Tension tester #3 30-150LB Carbon Drive Gates Tension Gauge
FlyingEagle
THE Ottawa
Also found it interesting that there is an OEM heavy duty replacement utilizing Kevlar, which is designed for the Evo9 but it fully 4g63 backwards compatible:
Per RTMRacing:
Click
I would have gladly paid $20 more to get the uprated version.
I'm running OEM out of the bag, so I'm not worried but I don't find out about new things until much later.
raptorWagon
Oak Harbor, WA
I just simply see no point to a kevlar belt, it is a consumable after all. Regardless of how fancy and "updated" it may be, it will still be replaced every 60k miles.
FlyingEagle
THE Ottawa
Got the belts and they look good. Came with a pair of Gates Racing stickers for effect. Maybe this will help my car go like a banshee and not sound like one!
I'll update when it is warm enough to fart around with this stuff in the garage.
