Turbo timer install !
xaisomboun
Minnesota
Ok so I just recently bought the APEXi pen style turbo timer with a 1g harness and attempted to hook it up.
I want to make sure Im doing this right so if anyone could tell me what Im doing wrong go right ahead!
1: Found the key cylinder harness and plugged the turbo timer inbetween them.
2: Ground the black wire to the chassis since Im not going to be using the o2/, A/F reading anytime soon.
3: Where should I get a constant 12v power source?? Do I run it directly from the battery or is there any other place?
Brunoboy
San Bruno,CA Home of SFO
the plug and play should already power the TT up and give it a voltage to look after. the only thing you should need to hook up is either RPM, Ground and E-Brake. where I take the chassis ground and E-brake and ground both.
citymunky
Chesapeake, VA
if you have a plug&play 1g hardness, then no. Connect ground and try your new Turbo timer out.
Brunoboy
ground the E-brake and chassis ground wire together.......
Diego
I never got mine to count though.. it will stay at :30 no matter how much I get into it... I remember having one that counted.. /ubbthreads/images/graemlins/dunno.gif
