knock/CEL
NickDromez
Berkeley, CA
so i have a CEL. i pulled the codes, 1 for MAF, 1 for coolant temp sensor out of range and 1 for knock sensor circuit problem. but this question is about the knock sensor as its my first priority. can somebody help point me to where the knock sensor is located at on the block? maybe im blind but i cant find it. also, my knock sensor is only about 9k miles old, should i replace it while im at it even though its still newish? im also guessing ill need some new wiring, does anybody know where i can get the proper wiring for a knock sensor? thanks
AnotherNewb
Orlando, FL
The knock sensor is underneith the intake manifold, screwed into the block. Inspect it for melted goo and make sure its not loose or has a damaged harness.
NickDromez
Berkeley, CA
thanks to both of u. i shoulda checked the "how to" first
