Trans/Block bolts
asmo
SLC, Ut
The rear ones go threw the starter, just noticed your local are you on utdsm.org? also I work at the mitsu dealership in the automall pm me if you need any parts.
Brunoboy
San Bruno,CA Home of SFO
The rear iirc doesn't go through the starter it's under the car facing the passenger side of the car right at te end of the tranny meeting the block surface.
OMFGeofffff
Burnsville, MN
From the rear of the engine, near the firewall:
1. small bolt, 12mm head, above the xfer case, running from the engine block side, through a non-tapped hole, into a tapped hole in the tranny
2. starter bolt, 14mm head, sandwiching the bellhousing plate between the bellhousing and starter
3. starter bolt, 14mm head, sandwiching the bellhousing plate between the bellhousing and starter
4. top rear tranny bolt, 14mm head, holds the coolant pipe bracket to the bellhousing, threads into block
5. top front tranny bolt, 14mm head, threads into block
6. bellhousing plate bolt, 10mm head, holds bellhousing plate to the bellhousing
7. front tranny bolt, 14mm head. Down near the slave cyl. MUST be in place, or you'll break things.
8. bottom - 12mm head, flywheel inspection plate cover bolt
Here's a picture of the rear most bolt.
The8er
Salt Lake City, UT
Ahhh!! Yes!! Exactly what I was looking for./ubbthreads/images/graemlins/worthy.gif I'm pretty sure its the one that is in the rear that goes back into the tranny #1. I'm guessing it's smaller and fits through the threaded hole in the block??
Sorry got tied up/side tracked with other projects last week but I thank you all for your help.
